Momed80
150
35,046
Liebherr Crane LTM 1500-8.1 073182 Spare Parts Catalog 2008 EN ES
Language: English, Spanish
Brand: Liebherr
Model: Liebherr LTM 1500-8.1 Crane
Serial Number: 073182
Publication Date: 2008
Number of Pages: 1680 Pages
Cooler Installation
Radiator, Pre-Assembled
Hydr. Cooler Drive
Diesel Engine Installation
Diesel Engine, Pre-Assembled
Fuel Filter Pre-Ass.
Distributor Gear Installation
Transfer Case, Pre-Assembled
Hydraulics
Axle 1+2 With Suspension
Axle 1, Pre-Assembled
Axle 2, Pre-Assembled
Hydraulics
Axles 5+6 With Suspension
Axle 6, Pre-Assembled
Axle 5, Pre-Assembled
Tyres 16.00 R25
Tire Cpl.16.00 R25
Axle 3 With Suspension
Axle 3, Pre-Assembled
Axle 4 With Suspension
Axle 4, Pre-Assembled
Hydraulics
Axles 7+8 With Suspension
Axle 7, Pre-Assembled
Axle 8, Pre-Assembled
Steering Mechanism
Steering Lever, Pre-Assembled
Steering Hydraulics
Valve Plate, Pre-Assembled
Rope
Drive Shaft Fitting
Additional Heating
Addnl.Heating, Pre-Assembled
Fixing Parts Slewing Ring
Sliding Beam With Bearing
Sliding Beam Front,Pre-Assemb
Sliding Beam Rear, Pre-Assembl
Rope
Cable Tensioner Cpl.
Cotter Pin
Wheel Chocks With Holder
Support Plates W.Fast.Add-On
Support Plate Compl.
Spring Plug Pre-Ass.
Boom Jib Support Cpl.
Boom Jib Support Block Pre-Ass
Tool Box Add-On
Underrun Guard
Tool Box, Pre-Assembled
Tool Box
Fuel Feed
Fuel Tank Cpl.
Fuel Tank, Pre-Assembled
Hydraulic Oil Tank Extension
Oil Tank Pre-Ass.
Air Vessel Mounting
Exhaust Gas System
Air Filter System
Maneuvering Coupling In Front
Tools And Accessories
Main Tools
Add-On Unit Ladder
Spare Wheel Carrier
External Feed
Electr. For Air-Conditioning
El.Equipment Telma
Backing Warning Acoustic
Electric Slewing Sensor
Console Aux. Replenishing
Disc Wheel
Dispatch Assy.Mech.Parts
Hose Guide Pre-Ass.
Driver's Cabin Compl.
Mirror Inst. Cab
Seats Driver's Cab
Roof Console Drivers Cabin
Mirror Suspension Right
Operator Cab Accessories
Driver's Cabin Pre-Ass.
Driver's Cabin, Glazed
Rework Steering Column
Door Hinge Cpl.
Steering Column Sheathing
Roof Covering Compl.
Roof Console Compl.
Roof Console Pre-Ass.
Cross Stabilizator
Air Guide System
Steering Column Pre-Ass.
Instrument Box Cpl.
Screen Whiping System Compl.
Screen Whiping Sys. Pre-Ass.
Cover Pre-Ass.
Battery Cover Pre-Ass.
Back And Side Wall Cover, Cpl.
Base Mats
Leather Cladding
Cover. Profiles Compl.
Door Left, Cpl.
Window, Crank, Left
Door Stopper Compl.
Door Right, Cpl.
Window, Crank, Right
Tachograph
Driver's Cabin Controls
Centre Bracket Pre-Ass.
Ground Rail
Terminal Board Pre-Ass.
Wires Compl. Instruments
Dashboard Center Console Pre-A
Insertion Module
Cables,Instrument Wiring,Pre-A
Air Conditioning Plant
Electric For Driver's Cabin
Cab Wiring List
Electrical System Battery
Charger
Tire Cover Panelling
Engine Cowling Cpl.
Cover/Lid/Cap, Pre-Assembled
Additional F.Tire Cover Panell
Undercarriage Elec. System
Cable List Electrical System
Double Horn Pre-Ass.
Wiring Harness
Rotary Feed Through
Swivel Connector, Pre-Assemble
Lighting German
Wiring List For Lighting
Wiring Harness
Lamp Clamp Cpl.Rear Left
Lamp Clamp Cpl.Rear Right
Wiring Harness
Retainer Cpl.
Tail Lighting
Illumination Holder
Bumper Compl. W. Covering
El.Comp. Dispatch Assembly
Lighting Support System
Compressed Air Plant
Air Dreier, Pre-Assembled
Pneumamatic Driver's Cabin
Bulkhead Plate
Hydraulic Support
Hydraulic Axle Suspension
El.Operation Of Hydr. Valves
Housing Cpl.
Outrigger Control From Above
Switch Box Cpl.
Plate Cpl.
Hoses Carrier
Pipe Cond. Carrier
Assembly Parts F.Slewing Pltf.
Drive Assembly Cpl.
Retainer Cpl.
Drive Assembly, Pre-Assembled
Combinated Radiator
Distributor Gearbox
Pump Hoist Gear 3
Pump Hoisting Gear 2
Battery Frame
Battery Box, Pre-Assembled
Fuel Tank Cpl.
Oil Reservoir, Complete
Luffing Ram W. Pivot
Erecting Winch
Rope With Accessories
Oil Cooler Add-On
Roller Slewing Ring
Slewing Gear
Angle Threaded Bulkhead
Winch 3
Winch
Hose Holder Welded
Luffing Pulley Block
Lower Pulley Block Cpl.
Upper Pulley Block Cpl.
Basket Cpl.
Pin Compl.
Ropes For Winches 3
Winch 1
Rope With Accessories 1
Winch 2
Centralized Lubrication System
Clamp Pre-Ass.
Crane Driver's Cabin Cpl.
Basic Boom Cpl.
Crane Driver's Cabin,Pre-Assy.
Adaptor Cpl.
Control Stand
Turntable Panelling
Flap Pre-Ass.
Cover Plate Pre-Ass.
Turntable Panelling
Fall Protection
Cabin, Glazed
Internal Lining
Front Window Cpl.
Floor Mat
Windshield Wiper System
Instrument Box, Installation
Delivery Scope Instr.Cons.Ow G
Insulant Floor Plate
Door Cpl.
Internal Lock
Control Panel Crane Driv Cabin
Electr.For Slewing Gear
Dashboard, Pre-Assembled Right
Mounting Parts Instr.
Electr. For Control Stand
Electric For Armrest Left
Electric For Armrest Right
Electric Fan Attachment
Heating Crane Driver's Cabin
Add Heating Superstructure
Counterweight
Base Plate Pre-Ass.
Add Counterweight
Clamping Screw Cpl.
Turnbuckle Complete
Clamping Screw Cpl.
Fastening Pipe
Counterweight Frame Cpl.
Central Lubricating System
Ladder Attachment
Exhaust Gas System
Air Filter System
Cent. Lubric. System Superst.
Work Floodlight
Air Cond. Unit Superstructure
Air Cond. Evaporator Rfk
Noise Insulation Upper Carriag
Liccon Console Lcd2
Foil Keypad Pre-Ass.
Housing Pre-Assembled
Interior Housing Pre-Ass.
Fan Plate Pre-Ass.
Sub-Assembly Carrier
Fan Unit
Electr. System F.Slewing Platf
Wiring List F.Slewing Platform
Wiring Harness
Electric For Battery Box
Electric For Winch 1
Terminal Box Lighting Hoist.Ge
Electric For Winch 2
El. For Supplementary Heating
Wiring List Cabin Glazed
Cable List Driver's Cabin
Additional Electrics
Electric For Winch 3
Dashboard Roof, Pre-Assembled
Electric For Glazed Cabin
Terminal Box Cpl.
Complement Electr., Cab
Lead
Operator Panel Ballast
Cabling Control Panel Consol
Electr. For Work Area Light
El.F.Step Plate, Pre-Assembled
Electr.F.Aircraft Warning Ligh
Bus Pcb
Switch Cupboard Cpl.
Assembly Parts Mounting Panel
Swing Frame Relay
Switch Cabinet
Cabling Mounting Plate
Ground Rail
Cover Compl.
Hydr
Hydr.Winch 3
Hose Lines 3
Pipelines
Additional Hydraulics Winch
Hoselines Ty3-Guying
Pipelines Teles. Boom Guying
Additional Hydr. Ta-Bracket
Pipeline Winch
Hose Lines
Addnl. Hydraulics Ballasting
Hoses Ballasting
Addnl. Hydr. F. Erecting Winch
Hoses Superstructure
Pipe Conducts Superstr.
Basic Boom Cpl.
Deflection Part Cpl.
Pivot Section, Pre-Assembled
Bearing Shoe, Pre-Assembled
Clamp Pre-Ass.
Telescopic Section 1 Pre-Assem
Telescopic Sect.2 Pre-Assembl
Telescopic Sect.3 Pre-Assemb
Rope Pulley Cpl.
Rope Pulley Compl.
Telescopic Unit
Assembly Unit
Roller Pre-Assembled
Rope Pulley Cpl.
Tn-Tf Adapter
Tf Adapter
Add. Bracket Ty-Guying
Spacer Ty-Guying System
Eccentric Ty-Guying
Mounting Pre-Ass.
Support Pre-Ass.
N Pivot Section
Flap Compl.
N Head Section
Na Intermediate Section
Pin Compl.
Ni Reducing Section
Mechanical Extension System
Limit Switch Bracket
Roller Cpl.
Articulated Head
Na Frame 1
Na Frame 2
Roller Cpl.
Na Frame 3
Pulley Block, Pre-Assembled
Rod Cpl.
Telescopic Boom Guying
Winch
Bracket Compl.
Pipe Compl.
Pull Rods
Console Compl.
Tools
Rod Cpl.
Ty-Frame Pre-Ass.
Cross Shackle Cpl.
N Overrun Protection
Frame
Support Pre-Ass.
Rods For Lattice Jib
Pull Rods
Rod Cpl.
Pull Rods
Rod Cpl.
Bracket Compl.
Mast Stub N-Head
Rope Pulley Cpl.
Undercarr.Addnl.Elec.Equipt.
Lead
Electr. Ty-Frame Pre-Ass.
Terminal Box Cpl.
Terminal Box
Wiring Harness
Retainer Left Pre-Ass.
Retainer Right Pre-Ass.
Electrical Equipment For Jib
Electric Wind Warning Tele
Working Floodlight Pivot Piece
Lead
Terminal Box Cpl.
Electr. F.Extending Mechanism
Electric Aircraft Protection
Lead
Electric F.Base Section
Sensor Install.Telescop.Mechan
Terminal Box
Electr. For Head Section
Cable Drum Compl.
Shaft Compl.
Sensor Assembly Basic Boom
Front Axle Suspension
Mech.Auxiliaries For Lighting
Electric For Pivot Section N
Terminal Box Cpl.
Cable Drum Compl.
Electr. For N-Head Section
Lead
Electrics Tension Dynamometer
Sensor N-Head Piece
Hydr.F.Telescopic Boom
Hook Block
Valve
Eddy Current Brake
Multi-Disk Brake
Spring Loaded Brake
Spring-Type Cylinder
Membrane Cylinder
Handbrake Valve
Air Dryer
Relay Valve
Triple-Stop Cylinder
Directional Control Valve
Brake Valve
Hydro Motor
Variable Displacement Motor
Additional Valve
Aeration Filter
Return Filter
Change-Over Block
Valve Block
Axle Locking Valve
Control Block
Solenoid Valve
Valve Block
Pressure Limiting Valve
Pretensioning Valve
Axle Locking Valve
Flow Control Valve
Steering Block
Variable Pump
Telescopic Cylinder
Luffing Cylinder
Ballast Extension Ram
Steering Axle
Rigid Axle
Steering Axle
Angular Gear
Steering Rod
Axle Strut
Steering Rod
Auxiliary Winch
Oil Air Cooler
Air Filter
Water Heating System
Circulating Pump
Three-Way Tap
Air Compressor
Driving Gear
Planetary Gear
Built-In Valve
Proportional Magnet
Filter Cover
Air Actuation Section
Terminal Board
Expansion Valve
Brake
Handle Cpl.
Add-On Parts
Planetary Gear It
Synchromesh
Pump
Control
Storage
Cylinder Head Cpl.
Terminal Board
Control Unit
Driving Gear
Terminal Board
Driving Gear
Variable Pump
Control Unit
Foot Rocker
Gear Cam Limitswitch
Battery Main Switch
Master Switch
Ignition Starter Switch
Flashing Alarm Light
Cable Reel
Length Indicator
Sliding Window
Drivers Seat
Co-Driver's Seat
Drivers Seat
Lube Oil Pump Preass.
Intermediate Wheel
Cylinder
Oil Cooler, Pre-Assembled
Power Take-Off
Piston Cooling
Rocker Lever Block
Rocker Arm Pre-Ass.
Lubricating Oil Pump
Oil-Level Gauge
Ladder-Type Frame
Final Control Valve
Lube Oil Filter
Pressure Adapter
Crankcase Breather
Oil Sump
Thermostat Housing
Suction Pipe
Crankshaft Bearings
Main Rod
Flywheel
Driving Pieces
Crankshaft Pre-Ass.
Cylinder
Valve
Locking Pieces
High Pressure Pump
Locking Pieces
Heating Flange
Fuel-Prefilter Ass.
Pressure Adapter
Oil Module
Power Unit Support
Ajdusting Plate
Piston Cooling
Locking Pieces
Delivery Pump
Air Suction
Pipeline
Flywheel Housing
Transport Device
Coolant Pipe Bend
Power Unit Support Attachment
Generator, Pre-Assembled
Transport Device
Cylinder Head Cover
Control Parts
Heater Connection
Locking Pieces
Fuel Fine-Filter Assembly
Fuel Filter Module
Fastening Piece
Connecting Line
Exhaust Nozzle
Counter Bracket
Rocker Arm Bracket Cpl.
Power Take-Off
Locking Pieces
Air Compressor
Connecting Line
Additional Kit
Generator Attachment
Power Take-Off
Starter
Piston
Camshaft Cpl.
Atl Attachment
Flange
Locking Pieces
Lead
El.Equipment Fly Jib
Oil Filler Inlet
Ventilation Connecting Piece
Oil Measuring Device
Planetary Gear
Drum Fixation
Winch Frame
Lead
Planetary Gear
Oil-Gauging Instrument
Guy Device
Compact Rope Winch
Rope Drum
Slewing Gear
Hydraulic Cylinder
Add-On Parts
Reverse Run
It As-Tronik
Housing
Rk Temperature Sensor
Add-On Parts
Converter Housing
Oil Feed
Rep.Transmission Actuator
Housing
Compact Rope Winch
Fuse Box Small
Control Element
Drive Shaft
Axle Locking Valve
Suspension Cylinder
Steering Cylinder
Strut Cylinder
Pocket Lock
Control Block
Equalizing Reservoir
Exhaust Pipe
Crank Shaft Attaching Parts
Cooling Water Air Bleeding
Oil Sump
Oil-Level Gauge
Starter
Oil Drain Plug
Flywheel Housing Mounting
Leak Oil Return Line
Locking Pieces
Exhaust Pipe
Rocker Arm Bracket Pre-Ass.
Crankcase
Crankcase Cpl.
Connection Stub
Hydt.Tube
Crankcase Breather
Sealing Set Oil Cooler
Seal Kit Cylinder Head
Seal Kit Injection Nozzle
Mounted Part
Control Gear
Lifting Device
Locking Pieces
Fan Attachment
Connecting Piece Pre-Ass.
Housing
Fuel Line
Connection Piece
Control Parts
Crankshaft Bearings
Generator
Pipeline
Engine Control Sensors
Injector
Atl Attachment
Cover Plate
Air Conditionng Compressor
Basic Engine
Rs Crankshaft Bearing Kpl.
Air Suction Pipe
Rk Injection Nozzle
Injection Nozzle W.Fastening
Heat Protection Sheet
Rocker Arm Pre-Ass.
Rocker Lever Block
Fuel-Prefilter Ass.
Thermostat Housing Assembly
Thermostat Housing Pre-Ass.
Connection F.Water Pipe
Outlet Manifold Add-On
Diesel Engine
Fuel Lines
Backleakage Line Ass.
Connecting Line Add-On
High Pressure Pump Pre-Ass.
Control Box Annexe
Suction Nozzle Add-On
Piston Cpl.140
Seal Kit Aggregate Carrier
Gearwheel Pre-Ass.
Camshaft Cpl.
Drive For High Pressure Pump
Installation Cylinder Head
Rocker Arms Device Cpl.
Cylinder Head Cover Assembly
Air Compressor W/ Mount.Parts
Vent Tube Assembly
Cooling Water Pipe Assembly
Intermediate Gear Assembly
Repair Kit Pipe Line
Cable Boom Mounting
Pipeline Installation
Connection Housing
Exhaust Gas Recirculation
Constr.Kit Compr.Air Condit.
High Pressure Pipe Assembly
Crankcase Pre-Ass.
Crankcase Cpl.
Rk Oil Return Pipe
Diesel Engine
Flywheel Assembly
Locking Pieces
Exhaust Gas Recircul.Attachm.
Cylinder Head Pre-Ass.
Manifold For Water Cpl.
Seal Kit Crankcase Breather
Seal Kit Locking Parts
Seal Kit Oil Sump
Seal Kit Cylinder
Seal Kit Oil Module
Seal Kit High Pressure Pump
Seal Kit Connecting Line
Seal Kit Air Compressor
Seal Kit Thermostat Housing
Sealing Set Water Pump
Seal Kit Exhaust Manifold
Seal Kit Exhaust Gas Recircul.
Seal Kit Turbocharger Mounting
Seal Kit Flywheel Housing
Seal Kit Output Shaft
Water Pump, Pre-Assembled
Seal Kit
Seal Kit Fuel Line
Fuel Prefilter
Transparent Container
Switchgear
Driven Steering Axle
Driving Axle
Pressure Sheet
Regulator
Regulator Element
Radiator Unit
Fuel Prefilter
Final Drive
Fuel Fine Filter
Control Block
Torque Converter
Switchgear
Turbine Shaft
Clutch
Control
El
Oil Sump
Oil Filler Inlet
Convertor
Drive Shaft
Jackshaft
Main Shaft
Control
Gv Circuit
Gb-Case
Gp Circuit
Coupling
Control Block
Synchromesh
Control Block
Adjustment
Numerical Index
Alphabetical Index (En)
Alphabetical Index (Es)
