Liebherr Axial Piston Pump LH30VO 028 to 100 Operating Instruction
Brand: Liebherr
Type of Machine: Axial Piston Pump
Type of Manual: Operating Instruction
Model: Liebherr LH30VO 028 to 100 Axial Piston Pump
Number of Pages: 123 Pages
1 Symbols and safety instructions
4 Sealing work
Commercially available tools
Brand: Liebherr
1.1 Symbols in the repair manual
1.2 Safety instructions
1.3 Target group
1.4 Limitation of liability
1.5 Personal protective equipment
1.6 Operating and maintenance areas
1.7 Machine safety / Functional safety
1.8 Signs
2 Tools2.1 Commercially available tools T = Tool
2.2 Special tool LT = Liebherr tool
2.3 Instructions for the use of tools
3 Overview of repair kits and seal kits4 Sealing work
4.1 Seal kit, complete
4.2 Tools
4.3 Seal kit for base unit
4.4 Seal kit for regulating valve
4.5 Sealing the connecting plate
4.6 Sealing the drive shaft
4.7 Sealing the regulating valve
4.8 Sealing the through drive
5 RK bearing5.1 Overview
5.2 Tools
5.3 Replacing tapered roller bearing (housing)
5.4 Replacing tapered roller bearing (connecting plate)
5.5 Checking the bearing pre-load / measuring method 1
5.6 Checking the bearing pre-load / measuring method 2
5.7 Replacing bearing shell (housing)
6 RK regulation6.1 Overview
6.2 Replacing the regulation
7 RK driving gear7.1 Overview
7.2 Tools
7.3 Removing the driving gear
7.4 Replacing the central spring
7.5 Checking the driving gear
7.6 Installing the driving gear
8 Settings8.1 General information
8.2 Regulating valve overview
8.3 Measuring tools/adjustment tools
8.4 LS0DA- control
8.5 LS1DA- control
8.6 DF-DA- control
8.7 DE2/4/6/8- control (falling characteristic)
8.8 Testing/adjustment tasks
8.9 Checking/adjusting the LS0 / LS1 regulating valve
8.10 Checking/adjusting the DA- regulating valve
8.11 Checking/adjusting the DF- regulating valve
8.12 Checking/adjusting the DE2/4/6/8- regulating valve
AppendixCommercially available tools
- Liebherr Diesel Engines 904-926 Service Manual
- Liebherr Software Diagnostic Without Dongle
- LIEBHERR R900 R902 R912 R922 R932 R942 Service Repair Manual
- LIEBHERR excavator A900 , R900 - A944 , R944 service manual
- Liebherr Excavator R952 R952HD R962 R972 R982 Service Manual and Diagram
- Liebherr New Engine CR and PLD Technical Information
- Liebherr Wheel Loader L544 L564 L574 WorkShop Service Manual
- Liebherr R996 Service Manual Hydraulic Excavator
- Liebherr Diesel Engine D846 A7 Maintenance Manual
- Liebherr R944C Hydraulic Excavator Shop Manual
- Liebherr Crawler Dozer PR 776-1296 Service Manual 2015
- Wheel Loader Liebherr L524 - L534 - L538 - Service manual
- Liebherr ZF Transmission Workshop Manual
- Wheel Loader Liebherr L550-L586 2plus2 - Service manual
- Liebherr Mobile Excavator A902 Parts Catalog
