LGMG Mobile Elevating Work Platform SR5390D Service and Repair Manual SM-2537110181
Brand: LGMG
Type of Machine: Mobile Elevating Work Platform
Type of Manual: Service and Repair Manual, Electric and Hydraulic Diagrams
Model: LGMG SR5390D Mobile Elevating Work Platform
Part Number: SM-2537110181
Number of Pages: 110 Pages
Chapter 1 Safety
Brand: LGMG
Chapter 1 Safety
1.1 Compliance
1.2 Before maintenance
1.3 Safety considerations for maintenance
1.4 After maintenance
Chapter 2 Specifications2.1 About this chapter
2.2 Torque specifications
2.3 Key procedure table
Chapter 3 Repair3.1 About this chapter
3.2 Platform assembly
3.2.1 How to replace PCU
3.2.2 Removing the platform assembly
3.2.3 Removing the extension platform assembly
3.3 Scissor assembly
3.3.1 How to disassemble the scissor assembly
3.3.2 Replacing the platform scissor slider
3.3.3
3.3.4 Replacing the chassis scissor slider
3.3.5 Replacing the upper/lower lift cylinder
3.3.6 Replacing the cylinder valve block
3.3.7
3.4 Chassis assembly
3.4.1 Replacing the GCU assembly
3.4.2 Removing the hydraulic oil tank
3.4.3 Replacing the float cylinder
3.4.4 Replacing the tire
3.4.5 eplacing the outrigger cylinder
3.4.6
3.4.6 How to remove the front axle assembly
3.4.7 Removing the rear axle assembly
3.4.8 How to remove the engine
Chapter 4 Commissioning4.1 About this chapter
4.2 Starting calibration
4.2.1 No-load calibration
4.2.2 Rated load calibration
4.2.3 Inclination calibration
4.2.4 Leveling and calibrating the outrigger
4.2.5 Adjusting the lift travel switch
4.3 Valves
4.3.1 Control manifold of upper lift cylinder
4.3.2
4.3.2 Control manifold of lower lift cylinder
4.3.3 Travel control manifold
4.3.4 Lift control manifold
4.3.5 Oscillating control manifold
4.3.6 Outrigger cylinder valve
4.3.7 Replacing the outrigger cylinder valve
4.3.8 Replacing the upper/lower lift cylinder valve block assembly
4.3.9
4.3.9 Adjustment method of relief valve
4.4 Testing
4.4.1 Testing the coil
4.4.2
4.4.2 Adjusting the lifting pressure
4.4.3
4.4.3 Adjusting the steering pressure
4.4.4 Adjusting the pressure of float cylinder
4.4.5 Adjusting the outrigger level
4.5 LPG mode-gas leak test
4.6 LPG mode-machine performance test
Chapter 5 Appendix5.1 About this chapter
5.2 Compliance
5.3 Before troubleshooting
5.4 System menu
5.5 Fault code and diagnostics
5.5.1 Fault cold and troubleshooting guide
5.6 Platform overload diagnosis
5.7 Schematic diagram
5.7.1 Machine structure
5.7.2 Electrical component positions
5.8 Pin number definition
5.8.1 PCU pin number definition
5.8.2 GCU pin number definition
5.9 Troubleshooting of electrical system
5.9.1 Diagnostic chart
5.10 Schematics
5.10.1 Electrical schematic
5.10.2 Hydraulic schematic
5.11 Wiring diagram
5.12 Diagram of common symbols
5.12.1 Diagram of common electrical part symbols
5.12.2 Diagram of common hydraulic part symbols
- Merlo Telescopic Handler P39 P40 P60 CDC Part Manual & Wiring Diagram
- Fantuzzi CS 45 KM HD Operator & Maintenance Manual
- FANTUZZI FDC 18 K5 Operator and Maintenance Manual
- Isuzu 4JG2 Engine Service Manual
- SMV Forklift A Series Service Manual German
- DanTruck Spare Part List
- Kalmar Ottawa T2 Terminal Tractors Maintenance Manual_241691
- Ingersoll Rand VR-642B Telehandler Parts Manual_EN
- Taylor Forklift T-180S-360L,TXH300L,TXH350L,TXH400L,TXB180S-300L Maintenance Manual
- PSI Power Solutions International 6.0L Engine Workshop Manual
- GM 2007 4.3L GM Engine IMPCO Emission Certified Fuel Service Manual
- Daedong 3F183T Common Rail Direct Injection-Engine Workshop Manual
- Hoist Material Handling Lift Truck Service Part Manual PDF
- Hyster and Yale KG 4.X Generator
- PSI HHI-3.0L Base Engine Service and Repair Manual
