Lemken Mounted Field Sprayers Sirius 10 Sirius 12 Operating Instructions 17510542
Brand: Lemken
Type of Machine: Mounted Field Sprayers
Model: Lemken Sirius 10 Sirius 12 Mounted Field Sprayers
Part Number: 17510542
Number of Pages: 254 Pages
1 General information
1.1 Liability
1.2 Guarantee
1.3 Copyright
1.4 Optional accessories
1.5 Type plate
2 Symbols used in the Operating Instructions
2.1 Hazard classes
2.2 Information
2.3 Environmental protection
2.4 Indication of passages
3 Safety measures and precautions
3.1 Target group
3.2 Intended use
3.3 Safety and warning signs
3.4 Special safety instructions
3.5 Danger areas
3.6 Residual risks
3.7 Applicable Rules and Regulations
3.8 Operation on public highways
3.9 Obligation of the operator
3.10 Safe use of the implement
3.11 Activate Street Mode
4 Effects of certain plant protection products on the implement
5 Handing over the Implement
6 Structure and description
6.1 Overview
6.2 Stands
6.3 Transport apparatus
6.4 Three-point connection
6.5 Fluid circuit
6.6 Main tank
6.7 Fresh water tank
6.8 Storage compartment
6.9 Hand washing container
6.10 Filter
6.11 Pump
6.12 Control and connection centre
6.13 Lighting
6.14 TankPilot electronic level indicator
6.15 Selector valve
6.16 Filler valve
6.17 Chemical inductor
6.18 Filler hose
6.19 Pressure measuring device
6.20 Distance measurement
6.21 Flowmeter
6.22 Electronic control system
6.23 Electrohydraulic SEH boom
6.24 Height adjustment
6.25 Pendulum suspension and slope compensation
6.26 Section control
6.27 Boom
6.28 Ground distance spacer
6.29 Nozzle holder
6.30 Nozzles
6.31 Boom lighting
7 Preparations on the tractor
7.1 Overview
8 Attaching the implement with the three-point connection
9 Attaching the implement with QuickConnect
10 Preparing the implement
10.1 Overview
10.2 Installing and checking the PTO shaft
10.3 Installing the correct nozzles
10.4 Installing the drop hoses
11 Operation
11.1 Operation below freezing point
11.2 Operation with drop hoses
11.3 Opening and closing the door
11.4 Storage compartment
11.5 Operating terminal
11.6 Filling and emptying the hand washing container
11.7 Filling and emptying the clean water tank
11.8 Filling the main tank with water
11.9 Cleaning empty canisters
11.10 Cleaning gun on the induction hopper
11.11 Flushing the induction system
11.12 Folding out the spraying boom
11.13 Trial operation of the implement
11.14 Boom lighting
11.15 All-round light
11.16 Working with the implement
11.17 Folding in the spraying boom
11.18 Spraying with drag hoses
11.19 System cleaning with partially filled main tank
12 Cleaning
12.1 General
12.2 Emptying the main tank
12.3 Emptying the fresh water tank
12.4 Emptying the hand washing container
12.5 Internal cleaning
12.6 External cleaning
12.7 Cleaning the filter
13 Detaching the implement
13.1 General information
13.2 Before the implement is detached
13.3 Attaching transport rollers or receptacles
13.4 Detaching the implement
14 Winter storage
14.1 Before the start of the season
15 Maintenance and repairs
15.1 Special safety instructions
15.2 Environmental protection
15.3 Greasing
15.4 Maintenance intervals
15.5 Oils and lubricants
15.6 Drive shaft
15.7 Lubrication points
15.8 Safety straps
15.9 Tightening torques
15.10 Check the connections to the tractor
15.11 Sensors
15.12 Pump
15.13 Filter
15.14 Test connections
15.15 Deflector
15.16 Information in case of faults and malfunctions
16 Troubleshooting
16.1 Emergency switch
17 Technical data
17.1 Dimensions and weights – basic implement
17.2 Receptacles for forklift truck tines
17.3 Three-point connection
17.4 Tank volume
17.5 Drive shaft
17.6 Boom
17.7 Pumps
17.8 Spraying fluid system
17.9 Flowmeter
17.10 Oil hydraulics
17.11 Electronic pressure display
17.12 Filter
18 Appendix
18.1 General information about nozzles
18.2 Nozzle field of application
18.3 Nozzle tables
18.4 Correction factors for spraying liquids with different densities
18.5 Dosage tables for liquid fertilisers
18.6 Checks and official implement inspections
19 Noise, Airborne Sound
20 Notes
20.1 Implement-specific data
20.2 Sirius 10/12 – types
20.3 Technical residues
Index
Brand: Lemken
1.1 Liability
1.2 Guarantee
1.3 Copyright
1.5 Type plate
2.1 Hazard classes
2.2 Information
3.1 Target group
3.2 Intended use
3.5 Danger areas
3.6 Residual risks
6.1 Overview
6.2 Stands
6.5 Fluid circuit
6.6 Main tank
6.10 Filter
6.11 Pump
6.13 Lighting
6.15 Selector valve
6.16 Filler valve
6.18 Filler hose
6.21 Flowmeter
6.27 Boom
6.29 Nozzle holder
6.30 Nozzles
6.31 Boom lighting
7.1 Overview
10.1 Overview
11 Operation
11.14 Boom lighting
12 Cleaning
12.1 General
14 Winter storage
15.3 Greasing
15.6 Drive shaft
15.8 Safety straps
15.11 Sensors
15.12 Pump
15.13 Filter
15.15 Deflector
16 Troubleshooting
17 Technical data
17.4 Tank volume
17.5 Drive shaft
17.6 Boom
17.7 Pumps
17.9 Flowmeter
17.12 Filter
18 Appendix
18.3 Nozzle tables
20 Notes
Index
