Laverda Combine M180 Parts Catalog 6246500
Brand: Laverda
Type of Machine: Combine
Model: Laverda M180 Combine
Serial Number: ZN205512X03010001-999
Part Number: 6246500
Number of Pages: 821 Pages
Engine V834677326 49 Awf
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons - Up To Engine Serial Number B69999
Crankshaft And Pistons - Starting From Engine Serial Number C50000 Jld291001
Camshaft And Valve Mechanism
Valve Rocker Cover - Up To Engine Serial Number B65200
Valve Rocker Cover - Starting From Engine Serial Number B65230
Intake Manifold
Oil Pump And Sump - Up To Engine Serial Number C55790
Oil Pump And Sump - Starting From Engine Serial Number C55791
Oil Cooler And Filter
Closed Crankcase Ventilation (Ccv) - Up To Engine Serial Number C74540
Closed Crankcase Ventilation (Ccv) - Starting From Engine Serial Number D50000 Jld291001
Coolant Pump And Thermostat
Fuel Injection System
Electronic Engine Management
Starter Motor
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Acw4665130 49 Awf
Valve Rocker Cover
Oil Pump And Sump
Fuel Filters - Engine Type Awf
Engine Installation
Engine Installation - Fan
Engine Brackets
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank - (Components)
Fuel Tank (Components)
Fuel Tank Bracket
Drive System
Drive Belt System - Left Side
Drive Belt System - Right Side
Engine Fan - Drive
Hydrostatic Pump & Power Take-Off - Drive
Hydrostatic Pump - Drive
Rotary Filter & Dust Aspirator - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Threshing Mechanism - Drive
Straw Walker - Drive
Cylinder Variator
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Rear Axle Support
Rear Axle - 2 Wheels Drive
Hitch
Hitch - Cuna
Hitch - Rockinger
Steering Column
Steering - Hydraulic Lines
Final Drive (Components)
Gearbox
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - Hydraulic Lines
Hydrostatic Pump - Control Lever
Hydrostatic Motor
Cutting Header - Lifting
Valve Block (Components)
Cutting Header
Quick Hydraulic Couplers (Multi-Faster) - (Components)
Control Valve (Header)
Control Valve (Header) - (Components)
Grain Bin Unloading
Pipes Reel
Electrohydraulic Engagement Control Valve - With Straw Chopper
Header Additional Lifting Ram
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Work Lights - Grain Tank
Rotary Beacon
Battery & Cables
Main Harness
Harness - Fuse Carrier
Harness - Operator Platform
Harness - Cab - Roof
Harness - Engine
Harness - Control Valve
Harness - Hydraulic Oil Tank & Hydrostatic Pump
Harness - Grain Bin
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Harness - Seed Riddle - Elec. Adjustable
Return Auger - Sensors
Micro Sd Card
Cab Support Frame
Cab - Frame
Cab - Frame & Roof
Cab - Front Glass & Windscreen Wiper
Cab - Rear Glass
Cab - Right Door
Cab - Left Door
Cab - Cladding
Seat Holder
Control Console
Multifunction Lever
Rear View Mirror
Rear View Mirror - Electrically Adjustable
Mechanical Header Height Indicator
Platform - Right Side
Platform - Left Side
Access Ladder
Platform
Support Frame
Frame
Hand Rail & Sun Canopy
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box - Tools
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Engine Cover - Fitting Bracket
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Straw Hood
Rear Sheet Metal - Weight
Number Plate
Signaling Panels
Decals - Safety & Warning
Tracks (6 Rollers)
Front Wheels
Rear Wheels - Weight
Wheels Wedges
Lifting Tools
Feeding System
Tools
Shield Plate
Tilt Frame
Tilt Frame - Control Lever
Feeder Frame
Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Shields
Feeder Reverser - Lever
Drive Lever
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Rice
Threshing Mechanism - Drive Lever
Rear Beater
Concave - Control System
Concave - Rice
Concave - Deflector Plate
Concave
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Discharge Extension - With Canvas
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator - Standard
Tailings Elevator - Anti-Wear Rice
Tailings Elevator
Grain Bin And Elevator System
Grain Bin
Grain Bin - Cover
Grain Bin - Unloader Gate
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator - Standard
Grain Elevator - Anti-Wear Rice
Grain Elevator
Grain Elevator - Filling Auger
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Chaff Spreader - Fan
Chaff Spreader - Fan Drive And Pulley
Chaff Spreader - Shield & Belt Guide
Accessories - Additional Fuel Filter
Accessories - Rear Wheels - Weight
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Tracks (6 Rollers)
Accessories - Beater - Blanking Plate
Accessories - Straw Hood - Weight
Accessories - Chaff Spreader
Accessories - High Speed Kit For Chaff Spreader
Accessories - Wind Canvas
Accessories - Rear View Mirror
Accessories - Mechanical Header Height Indicator
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Seed Riddle - Elec. Adjustable
Accessories - Seed Riddle & Tailings Elevator - Elec. Adjustable
Accessories - Modular Grain Pan
Accessories - Perforated Covers For Soya Beans
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Straw Accumulation
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Straw Walker Loss
Accessories - Header Additional Lifting Ram
Conversion Kit - Wheat To Rice
Conversion Kit - Wheat To Maize
Conversion Kit - Rice To Wheat
Conversion Kit - Straw Walker - Canvas
