Laverda Combine AL4 TECHNO Parts Catalog 3906489
Brand: Laverda
Type of Machine: Combine
Model: Laverda AL4 TECHNO Combine
Serial Number: 552900001-113, ZN205529X03000114-137
Part Number: 3906489
Number of Pages: 902 Pages
Engine V834876707 66 Awi
Engine Assemblies
Cylinder Block - Up To Engine Serial Number C68275
Cylinder Block - Starting From Engine Serial Number C69381
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons - Up To Engine Serial Number B69999
Crankshaft And Pistons - Starting From Engine Serial Number C50000 Jld291001
Camshaft And Valve Mechanism
Valve Rocker Cover - Up To Engine Serial Number B65418
Valve Rocker Cover - Starting From Engine Serial Number B65367
Intake Manifold
Oil Pump And Sump - Up To Engine Serial Number A77999
Oil Pump And Sump - Starting From Engine Serial Number B50000 Jld291001
Oil Cooler And Filter
Closed Crankcase Ventilation (Ccv) - Up To Engine Serial Number D71248
Closed Crankcase Ventilation (Ccv) - Starting From Engine Serial Number D72759 Jld291001
Coolant Pump And Thermostat - Up To Engine Serial Number Z22537
Coolant Pump And Thermostat - Starting From Engine Serial Number Z24582
Fuel Injection System
Fuel Filters - Engine Serial Number Range B50000-C71112
Electronic Engine Management - Up To Engine Serial Number A58259
Electronic Engine Management - Starting From Engine Serial Number A60804
Starter Motor
Fan Drive
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine Installation
Filters
Engine Installation - Fan
Engine Brackets
Cooling System - Cooler Hoses
Cooling System - Radiator
Cooling System - Radiator (Components)
Cooling System - Rotary Screen
Dust Aspirator
Engine Air Filter
Exhaust System
Def System
Def Tank (Components)
Fuel Tank (Components)
Fuel Tank Bracket
Air Compressor
Drive System
Drive Belt System - Left Side
Drive Belt System - Right Side
Hydrostatic Pump & Power Take-Off - Drive
Rotary Filter & Dust Aspirator - Drive
Air Conditioning - Drive
Feeder Conveyor - Drive
Feeder Reverser - Drive
Threshing Mechanism - Drive
Multi Crop Separator - Drive
Straw Walker - Drive
Cylinder Variator
Variable Speed Fan Drive
Variable Speed Fan Drive - (Components)
Shaker Shoe - Drive
Grain Bin Unloading - Drive
Straw Chopper - Drive
Front Axle
Rear Axle - Stabiliser Bar
Rear Axle Support
Rear Axle - 4 Wheels Drive
Rear Axle - 4 Wheels Drive - (Components)
Rear Axle - Tray
Tow Hook
Tow Hook - Cuna
Steering Column
Steering - Hydraulic Lines
Final Drive
Final Drive (Components)
Gearbox (Components)
Gear Lever System
Brake Pedals
Brake Master Cylinder & Brake Control Valve - (Components)
Brake Caliper - (Components)
Parking Brake - (Components)
Hydraulic Oil Tank
Hydraulic Oil Tank - Hydraulic Lines
Hydraulic Propel
Hydrostatic Pump - Control Lever
Hydrostatic Motor
Cutting Header - Lifting
Flow Capacity Reduction Solenoid Valve - (Components)
Cutting Header
Cutting Table Flotation
Lateral Header Flotation Control Valve - (Components)
Rear Axle - 4 Wheels Drive - Equa-Trac Valve
Control Valve (Header)
Control Valve (Header) - (Components)
Grain Bin Unloading
Pipes Reel
Electrohydraulic Engagement Control Valve - With Straw Chopper
Electrohydraulic Engagement Control Valve - Without Straw Chopper
Electrohydraulic Engagement Control Valve - (Components)
Hydraulic Levelling - Pump
Hydraulic Levelling - Distributor (Components)
Hydraulic Levelling
Hydraulic Levelling - Front Lift
Hydraulic Levelling - Rear Lift
Manual Levelling
Central Lubrification
Front Lighting
Rear Lighting
Rear Lighting - Reverse Gear
Work Lights - Grain Tank
Rotary Beacon
Battery & Cables
Harness - Fuse Carrier
Harness - Cab
Harness - Operator Platform
Harness - Control Console
Harness - Multifunction Lever
Harness - Gearbox Sensors
Harness - Engine
Harness - Control Valve
Harness - Hydrostatic Pump
Harness - Multi Crop Separator
Harness - Grain Bin
Harness - Hydraulic Levelling
Harness - Straw Hood
Harness - Straw Chopper
Harness - Straw Walker Loss
Return Auger - Sensors
Agritronicplus
Cab Support Frame
Cab Substructure
Cab - Roof
Cab - Front Glass & Windscreen Wiper
Cab - Rear Glass
Cab - Right Door
Cab - Left Door
Cab - Cladding
Seat Holder
Seat & Passenger Seat
Control Console - Switches
Multifunction Lever
Feeder Reverser - Lever
Rear View Mirror
Platform - Right Side
Platform - Left Side
Access Ladder
Air Conditioning
Air Conditioning - Hydraulic Lines
Frame - Lower
Frame - Beater
Frame - Straw Walker
Tool Box
Tool Box - Bracket
Stone Trap
Front Guards - Right Side
Front Guards - Left Side
Front Guards - Shaker Shoe
Rear Guards - Left Side
Engine Access - Deck & Ladder
Engine Access - Hand Rail
Additional Fire Extinguisher
Engine Cover
Engine Cover - Fitting Bracket
Sheet Metal - Right Side
Sheet Metal - Left Side
Sheet Metal - Rear
Sheet Metal - Straw Hood
Number Plate
Signaling Panels
Decals - Safety & Warning
Front Wheels
Feeding System
Tools
Tilt Frame
Feeder Frame
Drive Pulley
Upper Shaft
Lower Shaft
Feed Drum
Feeder Chain
Collector Drum
Shields
Lifting Cylinder
Threshing System
Thresher Concave
Thresher Concave - Wheat, Barley, Small Seeds, Rye & Oats
Thresher Concave - Grain & Maize
Thresher Concave - Sensor
Rear Beater
Concave - Control System
Multi Crop Separator - Left Side
Multi Crop Separator - Right Side
Multi Crop Separator - Gear Reducer
Multi Crop Separator - Rotor Grate
Multi Crop Separator - Rotating Separator
Straw Walker
Straw Walker - Protective Plate
Straw Walker - Camshaft
Swather Rake
Wind Canvas
Cleaning System
Shaker Shoe
Shaker Shoe - Lid
Shaker Shoe - Returns Auger
Cleaning Fan
Stratification Pan
Chaffer Frame
Chaffer Frame - Control System
Sieve Frame
Discharge Extension
Chaffer - Mechanical Adjustment Sieves
Chaffer - Maize, Cob & Mixed Crop
Sieve
Variable Speed Fan Drive - Electrical Control
Tailings Elevator
Tailings Elevator - Scraper
Grain Bin And Elevator System
Grain Bin
Grain Bin - Access Ladder
Grain Bin - Extension
Grain Bin - Unloader Gate
Connecting Box - Lower - (Components)
Connecting Box - Superior - (Components)
Grain Bin Unloading - Swivel Auger
Grain Elevator
Grain Elevator - Filling Auger
Connecting Box - (Components)
Discharge System
Straw Chopper - Control Lever
Straw Chopper - Fitting Bracket
Straw Chopper - Side Bracing
Straw Chopper - Frame
Straw Chopper - Rotor
Straw Deflector
Straw Deflector - Control Lever
Accessories - Additional Fuel Filter
Accessories - Towing Hook
Accessories - Towing Hook Cuna
Accessories - Beater - Blanking Plate
Accessories - Rear View Mirror
Accessories - Straw Chopper Deflector
Accessories - Modular Grain Pan
Accessories - Seed Riddle - Upper
Accessories - Seed Riddle - Lower
Accessories - Seed Riddle - Elec. Adjustable
Accessories - Fan Speed Reduction & Blanking Plate
Accessories - Additional Fire Extinguisher
Accessories - Refrigerator 12v
Accessories - Air Compressor
Accessories - Yield Monitor & Moisture Sensor
Accessories - Rear View Camera
Accessories - Additional Work Lights
Accessories - Wind Canvas
Conversion Kit - Wheat To Maize
