Laverda Combine 28.60 LXE Parts Catalog 27941500
Brand: Laverda
Type of Machine: Combine
Model: Laverda 28.60 LXE Combine
Serial Number: 318000001 - 318000187
Part Number: 27941500
Number of Pages: 676 Pages
Engine Installation
Engine Air Cleaner
Exahaust Silencer
Radiator Filter
Radiator Elements
Filter Transmission Radiator
Power Take-Off
Brakes Elements
Tow Hook
Crawler Tracks
Front Axle
Powered Rear Axle Four Wd
Rear Axle Support
Rear Axle - Adjustable
Reducers
Shift Levers
Brakes
Parking Brake Elements
Iron Shoe (6 Roller)
Rubber Shoe (6 Roller)
Crawer Tracks
Chain Elements
Hydrostatic Pump
Hydrostatic Pump Elements
Pump Drive
Gear Box
Hydrostatic Motor
Hydrostatic Motor Elements
Oil Tank
Multifunctions Lever For Hydrostatic Traction
Front Elevator
Reverser
Elevator Transmission
Front Elevator (With Feeder Roller) Page.4
Feeder Roller
Feeder Roller Elements
Cutter Bar Lifting
Thresher
Frame
Drum Housing
Drum Variator
Drum Variator Elements
Drum With Bars
Peg Drum
Beater Behind Drum
Concave Control Drive
Concave
Spike Tooth Concave
Conveying Concave
Thresing Mechanism Drive
Multi Crop Separator
Straw Walkers
Straw Walkers Case
Rear Body
Straw Walker
Parts For Normals Soils
Straw Walker Drive
Swather Rake
Cleaning
Grain Pan
Grain Pan Drive
Shaker Shoe
Lower Shaker Shoe
Upper Shaker Shoe
Grain Elevator (Normal)
Tailings Elevator (Normal)
Fan
Fan Variator
Fan Variator Elements
Grain Elevator (Anthwear)
Tailings Elevator (Anthwear)
Fan Speed Variator Digital Control
Upper Sieve, Adjustable
Lower Sieve
Tank And Fairings
Grain Tank
Tank Feed
Case Elements
Grain Tank Unloading Auger
Lower Case Elements
Upper Case Elements
Swing-Type Control Ram And Pipings
Swivel
Body, R.H. For Engine
Body, L.H. For Engine
Engine Cover
Engine Access Ladder
Adjusting Plate Control
Guard
L.H. Front Side Wall Guard
R.H. Front Side Wall Guard
R.H. Rear Side Wall Guard
L.H. Rear Side Wall Guard
Drive's Platform
Steering Coolumn
Platform Support
Ladder Footboard
Platform Footboards
Cab Installation
Cab - Climatized Cab
Cab - Roof Panel
Cab - Door, Left
Cab - Door, Right
Cab - Framing
Cab - Under Roof
Cab - Headlights
Cab - Conditioner Elements
Cab - Air Conditioning System
Hydraulic Drive Elements
Control Reel Variator
Valve-Chest
Valve-Chest Elements
Reel Circuit Hydraulic
Drive Hydraulic Circuit
Cutter Bar Levelling System
Connections For Hydraulics Pipes
Drive
Eletric System
Front Lighting Compenents
Rear Lighting Components
Control Circuits
Starting Circuits
Valve-Chest Control Circuits
Digital Instrumentation
Beacon Light With Cab
Operations Control Monitor
Auxliary Light
Battery Disengaging Device
Back-Up Lamp
Tools And Decal
Number Plate Holder
Support
Transfers
Tool Box
Variations
Ceca Rep. Version
Denmark-Sweden Version
Germany Version
Wheels Block
Switzerland Version
Front Axle Spacer (Mm. 250)
Rasp-Bar Concave
Upper Sieve Adjiustable
Additional Electric System For Flip-Up Maize Head.
Muddy Soil Guards
Straw Chopper - Drive
Straw Chopper - Drive Clutch
Straw Chopper - Supports
Straw Chopper - Body
Straw Chopper - Chopper Drum
Straw Chopper - Deflectors
Chaff Spreader - Drive
Chaff Spreader - Supports
Chaff Spreader - Body
Canvas For Straw Walker Body
Ballst Weight On Rear Axle
Weight Tray On Rear Tyres
Ballst Weight On Rear Body
Spike Tooth Concave With 2 Complete Thresing Sect
Speed Reduction
Equipment For Small Seeds
Equipment For Soy
Elevator Cleaning Blades
Front Wheels
Chaff Spreader - Guards
Brand: Laverda
Engine Installation
Engine Air Cleaner
Exahaust Silencer
Radiator Filter
Radiator Elements
Power Take-Off
Brakes Elements
Tow Hook
Crawler Tracks
Front Axle
Rear Axle Support
Reducers
Shift Levers
Brakes
Crawer Tracks
Chain Elements
Hydrostatic Pump
Pump Drive
Gear Box
Hydrostatic Motor
Oil Tank
Front Elevator
Reverser
Feeder Roller
Cutter Bar Lifting
Thresher
Frame
Drum Housing
Drum Variator
Drum With Bars
Peg Drum
Beater Behind Drum
Concave
Spike Tooth Concave
Conveying Concave
Straw Walkers
Straw Walkers Case
Rear Body
Straw Walker
Straw Walker Drive
Swather Rake
Cleaning
Grain Pan
Grain Pan Drive
Shaker Shoe
Lower Shaker Shoe
Upper Shaker Shoe
Fan
Fan Variator
Lower Sieve
Tank And Fairings
Grain Tank
Tank Feed
Case Elements
Lower Case Elements
Upper Case Elements
Swivel
Engine Cover
Guard
Drive's Platform
Steering Coolumn
Platform Support
Ladder Footboard
Platform Footboards
Cab Installation
Cab - Roof Panel
Cab - Door, Left
Cab - Door, Right
Cab - Framing
Cab - Under Roof
Cab - Headlights
Valve-Chest
Drive
Eletric System
Control Circuits
Starting Circuits
Auxliary Light
Back-Up Lamp
Tools And Decal
Number Plate Holder
Support
Transfers
Tool Box
Variations
Ceca Rep. Version
Germany Version
Wheels Block
Switzerland Version
Rasp-Bar Concave
Muddy Soil Guards
Speed Reduction
Equipment For Soy
Front Wheels
