702,019
Laverda Combine 255 REV Parts Catalog 27985500
Brand: Laverda
Type of Machine: Combine
Model: Laverda 255 REV Combine
Serial Number: 551700030 – 551700044
Part Number: 27985500
Number of Pages: 795 Pages
Engine Iveco Nef Tier 3
Rocker Shaft
Intake Manifold
Engine Breathers
Cylinder Head Covers
Oil Sump
Front C.Case Cover
Flywheel Housing
Bedplate
Complete Engine
Crankcase
Starter Motor
Rear C. Case Cover
Pipe
Temperatur Control
Engine Air Intake
Pump
Fuel Lines
Engine Suspension
Cables
Covers
Power Take Off
Generator
Water Lines
Thermostat
Water Pump Drive
Oil Filters
Oil - Water Heat Exchanger
Oil Dipstick
Oil Pump
Lube Oil Lines
Turbocharger
Supercharging Lines
Electronic Control Unit
Fuel Filter 4612230
Injection Pump Assy
Accumulator Hydraulic
Nozzles
Engine Flywheel - Damper
Vibration Damper
Timing Parts
Crank Shaft - Connecting Rods
Thrust Ring Set
Piston Assy - Piston Rings - Piston Pin
Exhaust Manifold
Engine Installation
Engine Air Cleaner
Exahaust Silencer
Radiator Filter
Radiator Elements
Filter Transmission Radiator
Power Take-Off
Radiator Filter Intake
Traction
Front Axle
Powered Rear Axle Four Wd
Rear Axle Support
Rear Axle-Adijustable
Reducers
Shift Levers
Brakes
Pump Elements And Brake Compensation Valve
Brakes Elements
Axle Shaft
Tow Hook Rockinger
Crawler Tracks (6 Roller)
Rollers Elements And Idler Wheels
Chain Elements
Crawler Tracks (7 Roller)
Hydrostatic Pump
Hydrostatic Pump Elements
Pump Drive
Gear Box
Hydrostatic Motor
Hydrostatic Motor Elements
Oil Tank
Multifunctions Lever For Hydrostatic Tract.
Multifunctions Lever For Hydrostatic Traction
Elevator
Elevator Transmission
Front Elevator
Cutter Bar
Cutter Bar Lifting
Reverser
Drum
Frame
Drum Housing
Drum Variator
Drum With Bars
Peg Drum
Beater Behind Drum
Concave Control Drive
Concave
Spike Tooth Concave
Maize Concave And Sun Flower
Conveying Concave
Thresing Mechanism Drive
Without Multi Crop Separator
Straw Walkers
Straw Walker Case
Rear Body
Straw Walker
Parts For Normals Soils
Straw Walker Drive
Swather Rake
Straw Chopper-Body
Straw Chopper-Drive
Straw Chopper-Supports
Straw Chopper-Chopper Drum
Straw Chopper-Spreader Housing
Straw Chopper-Deflectors
Straw Chopper-Straw Chopper Exclusion Device
Straw Chopper-Drive Clutch
Straw Chopper-Drive Guard
Straw-Chopper-Body Stiffener
Straw Chopper-Electric System
Cleaning
Grain Pan
Grain Pan Drive
Shaker Shoe
Lower Shaker Shoe
Upper Shaker Shoe
Grain Elevator (Normal)
Tailings Elevator (Normal)
Fan
Fan Variator
Fan Variator Elements
Grain Elevator (Anthwear)
Tailings Elevator (Anthwear)
Upper Sieve Adijustable
Lower Sieve
Grain Tank And Fairings
Grain Tank
Rectactable Grain Tank Extension
Tank Feed
Case Elements
Grain Tank Unloading Auger
Lower Case Elements
Upper Case Elements
Swivel
Body, R.H. For Engine
Body, L.H. For Engine
Engine Cover
Engine Access Ladder
Wall Guard
R.H. Front Side Wall Guard
L.H. Front Side Wall Guard
Body Right
L.H.Rear Side Wall Guard
Driv's Platform
Platform Support
Drive's Platform
Ladder Footboard
Platform Footboards (Left)
Platform Footboards (Right)
Cab-Climatized Cab
Cab-Roof Panel
Cab - Door, Left
Cab - Door, Right
Cab - Framing
Cab - Under Roof
Cab - Headlight
Cab - Unicontrol
Cabine Elements
Cab Installation
Cab - Rear View Mirrors
Ladder Footboards
Steering Coolumn
Valve-Chest
Elements Distributor
Valve-Chest Elements
Reel Circuit Hydraulic
Drive Hydraulic Circuit
Connecting For Hydraulic Pipes
Drive
Electric System
Front Lighting Components
Control Circuits
Starting Circuits
Valve-Chest Control Circuits
Digital Instrumentation
Beacon Light With Cab
Operations Control Monitor
Auxiliary Light
Battery Disengaging Device
Back-Up Lamp
Tools And Transfers
Tool Box
Number Plate Holder
Support
Support Tools Box
Transfers
Straw-Lifter Rider
Elevatoe Cleaning Blades
Variations
Caea Republic Version
Denmark - Sweden Version
Elevator Front Guard
Germany Version
Wheels Block
Switzerland Version
Russia Version
Front Axle Spacer
Rasp-Bar Concave
Electrical Adijustment Deflectors
Parts For Sandy Soils
Upper Sieve Adijustable (Mais)
Front Elevator Support Kit
Cutter Bar Levelling System
Additional Electric System For Flip-Up Maize
Muddy Soil Guards
Chaff Spreader - Drive
Chaff Spreader - Supports R.
Chaff Spreader - Supports L.
Chaff Spreader - Body
Chaff Spreader - Guards
Canvas For Straw Walker Body
Front Wheels
Chain Drive For Drum
Ballst Weight On Rear Axle
Weigth Tray On Rear Tyres
Ballst Weight On Rear Body
Spike Tooth Concave With Two Complete Thresing
Bars Mais-Mix
Concave Mais - Mix
Upper Sieve, Corn - Cob - Mix
Drum Bar Plates
Equipment For Small Seeds
Equipment For Soy
