Laverda Combine 2450 AL Parts Catalog 27927500
Brand: Laverda
Type of Machine: Combine
Model: Laverda 2450 AL Combine
Serial Number: 277391001 - 277411003
Part Number: 27927500
Number of Pages: 717 Pages
Fuel Injection System (8110850) (Stanadyne)
Alternator 99448466 (Bosch)
Crankcase And Cylinder
Oil Sump
Covers And Bolted
Vent And Airing
Head Cylinder
Intake Manifold
Exhaust Manifold
Connecting Rod
Pistons
Flywheel
Damper
Intermediate Drive Gears And Shafts
Drive-Gearing - Tappets And Pushrods
Injection Pump Drive
Fuel Filter (4690738)
Injection Pipes
Fuel Lines
Supercharging System
Supercharging System 8108015 (Holset)
Air-Water Heat Exchanger
Oil Level Gauge
Lube Oil Pump
Lube Oil Filters
Oil Lines
Heat Exchanger
Water Pump 4796537
Cooling Lines
Temperatur Control
Fan
Starter
Starter Motor 4807376 (Marelli)
Engine Installation
Radiator Filter Intake
Engine Air Cleaner
Radiator Filter
Filter Transmission Radiator
Power Take-Off
Front Axle
Rear Axle Support
Rear Axle
Shift Levers
Brakes
Pump Elements And Brake Compansation Val
Parking Brake Elements
Tow Hook
Powered Rear Axle Four Wd
Hydrostatic Pump
Hydrostatic Pump Elements 322104500
Pump Drive
Gear Box
Hydrostatic Motor
Radiator Elements 322689900
Oil Tank
Multifunctions Lever For Hydrostatic Traction
Steering Wheel Knob
Front Wheels
Reducers
Elevator
Reverser
Elevator Transmission
Front Elevator
Cutter Bar Lifting
Feeder Roller
Feeder Roller Elements
Thresher
Frame
Drum Housing
Drum Variator
Drum With Bars
Beater Behind Drum
Concave Control Drive
Concave
Conveying Concave
Thresing Mechanism Drive
Multi Crop Separator
Straw Walkers
Straw Walkers Case
Rear Body
Straw Walker
Parts For Normals Soils
Straw Walker Drive
Swather Rake
Cleaning
Grain Pan
Grain Pan Drive
Shaker Shoe
Lower Shaker Shoe
Upper Shaker Shoe
Grain Elevator
Tailings Elevator (Normal)
Fan Variator
Fan Variator Elements
Lower Sieve
Upper Sieve, Adjustable
Elevator Front Guard
Tank And Fairings
Swivel Conveyor
Grain Tank
Tank Feed
Case Elements
Grain Tank Unloading Auger
Lower Case Elements
Upper Case Elements
Swing-Type Control Ram And Pipings
Body, R.H. For Engine
Body, L.H. For Engine
Engine Cover
Engine Access Ladder
Adjusting Plate Control
Swivel
Guard
R.H. Front Side Wall Guard
L.H. Front Side Wall Guard
R.H. Rear Side Wall Guard
L.H. Rear Side Wall Guard
Drive's Platform
Platform Support
Platform Ladder
Platform Footboards
Cab Installation
Cab - Climatized Cab
Cab - Framing
Cab - Door, Left
Cab - Door, Right
Cab - Glasses
Cab - Upholstery
Cab - Roof Panel
Cab - Under Roof
Cab - Headlights
Cab - Dashboard Harness
Cab - Air Conditioning System (Freon 'Hfc134a')
Cab - Air Conditioning System 322795200
Cab - Conditioner Elements
Steering Coolumn
Hydraulic Drive Elements (Danfoss)
Control Reel Variator
Valve-Chest
Valve-Chest Elements 322734100
Reel Circuit Hydraulic
Drive Hydraulic Circuit
Tubing System Of Longitudinal Leveling
Machine Levelling System
Cutter Bar Levelling System
Eletric System
Valve-Chest Control Circuits
Front Lighting Components
Rear Lighting Components
Control Circuits
Control Circuits (Electrical Wiring)
Control Circuits (Protezioni)
Starting Circuits
Digital Instrumentation
Beacon Light With Cab
Operations Control Monitor
Battery Disengaging Device
Tools And Decal
Tool Box
Transfers
Variations
Number Plate Holder
Cutting Table Block Quick Release Coupli
Back-Up Lamp
Straw-Lifter Rider
Straw Chopper - Drive
Straw Chopper - Body
Straw Chopper - Chopper Drum
Straw Chopper - Deflectors
Straw Chopper - Electro-Magnetic Clutch
Straw Chopper - Drive Clutch
Straw Chopper - Drive Guard
Straw Chopper - Supports
Auxiliary Light
