Laverda Combine 2350 LX Parts Catalog 27908500
Brand: Laverda
Type of Machine: Combine
Model: Laverda 2350 LX Combine
Part Number: 27908500
Number of Pages: 805 Pages
Alternator 99448466 (Bosch)
Crankcase And Cylinder
Oil Sump
Covers And Bolted
Vent And Airing
Head Cylinder
Intake Manifold
Exhaust Manifold
Connecting Rod
Pistons
Flywheel
Damper
Intermediate Drive Gears And Shafts
Drive-Gearing - Tappets And Pushrods
Injection Pump Drive
Fuel Injection System (8110850)
Fuel Filter (4690738)
Injection Pipes
Fuel Lines
Supercharging System
Supercharging System 8109562 (Holset)
Air-Water Heat Exchanger
Oil Level Gauge
Lube Oil Pump
Lube Oil Filters
Oil Lines
Heat Exchanger
Water Pump 4796537
Cooling Lines
Temperatur Control
Fan
Starter
Starter Motor 4807376 (Marelli)
Engine Installation
Engine Air Cleaner
Exhaust Silencer
Radiator Filter
Filter Transmission Radiator
Power Take-Off
Rear Axle - Adjustable
Front Axle
Rear Axle Support
Rear Axle - Fixe
Reducers
Shift Levers
Brakes
Pump Elements And Brake Compansation Val
Brakes Elements
Parking Brake Elements 320975800
Tow Hook
Crawler Tracks
Iron Shoe
Rubber Shoe
Chain Elements
Hydrostatic Pump
Hydrostatic Pump Elements 322104500
Pump Drive
Gear Box
Hydrostatic Motor
Hydrostatic Motor Elements 89508952
Radiator Elements 322689900
Oil Tank
Multifunctions Lever For Hydrostatic Traction
Front Wheels
Elevator
Elevator Transmission
Front Elevator
Cutter Bar Lifting
Feeder Roller
Feeder Roller Elements
Reverser
Thresher
Frame
Drum Housing
Drum Variator
Drum With Bars
Peg Drum
Beater Behind Drum
Concave Control Drive
Concave
Spike Tooth Concave
Maize Concave And Sun Flower
Conveying Concave
Thresing Mechanism Drive
Multi Crop Separator
Straw Walkers
Parts For Normals Soils
Straw Walkers Case
Rear Body
Straw Walker
Straw Walker Drive
Swather Rake
Cleaning
Grain Pan
Grain Pan Drive
Shaker Shoe
Lower Shaker Shoe
Upper Shaker Shoe
Grain Elevator
Tailings Elevator (Normal)
Fan Variator
Fan Variator Elements
Grain Elevator (Anthwear)
Tailings Elevator (Anthwear)
Fan Speed Variator Digital Control
Upper Sieve
Lower Sieve
Upper Sieve, Adjustable
Tank And Fairings
Grain Tank
Tank Feed
Case Elements
Grain Tank Unloading Auger
Lower Case Elements
Upper Case Elements
Swing-Type Control Ram And Pipings
Swivel
Body, R.H. For Engine
Body, L.H. For Engine
Engine Cover
Engine Access Ladder
Swivel Conveyor
Adjusting Plate Control
Guard
R.H. Front Side Wall Guard
L.H. Front Side Wall Guard
R.H. Rear Side Wall Guard
L.H. Rear Side Wall Guard
Drive's Platform
Steering Coolumn
Platform Support
Platform Ladder
Platform Footboards
Cab Installation
Cab - Climatized Cab
Cab - Framing
Cab - Door, Left
Cab - Door, Right
Cab - Glasses
Cab - Upholstery
Cab - Roof Panel
Cab - Under Roof
Cab - Headlights
Cab - Dashboard Harness
Cab - Air Conditioned
Cab - Air Conditioning System (Freon Hfc134a)
Cab - Conditioner Elements
Ladder Footboard (Normal Wheel Track)
Ladder Footboard (Ladder Release)
Hydraulic Drive Elements (Danfoss)
Control Reel Variator
Rear Wiew Mirrors
Valve-Chest
Valve-Chest Elements
Reel Circuit Hydraulic
Drive Hydraulic Circuit
Cutter Bar Levelling System
Connections For Hydraulics Pipes
Eletric System
Front Lighting Components
Valve-Chest Control Circuits
Rear Lighting Components
Control Circuits
Control Circuits (Protezioni)
Starting Circuits
Digital Instrumentation
Beacon Light With Cab
Operations Control Monitor
Battery Disengaging Device
Back-Up Lamp
Tools And Decal
Tool Box
Transfers
Variations
Number Plate Holder
Ceca Rep. Version
Denmark-Sweden Version
Swivel Stop
Elevator Front Guard
Germany Version
Wheels Block
Switzerland Version
Front Axle Spacer (Mm. 250)
354_4wd Front Axle - Uzbekistan Version
355_4wd Front Axle - Uzbekistan Version
356_4wd Front Axle - Uzbekistan Version
357_4wd Front Axle - Uzbekistan Version
358_4wd Front Axle - Uzbekistan Version
359_4wd Front Axle - Uzbekistan Version
Parts For Sandy Soils
Anthwear Parts
Ladder Footboard (Reduced Wheel Track)
Ladder Footboard
Front Elevator Support Kit (Barre 6.60)
Addition.Electric System For Flip-Up Maize Header
Thermostarter
Muddy Soil Guards
Straw-Lifter Rider
Straw Chopper - Drive
Straw Chopper - Body
Straw Chopper - Chopper Drum
Straw Chopper - Deflectors
Straw Chopper - Electro-Magnetic Clutch
Straw Chopper - Drive Clutch
Straw Chopper - Drive Guard
Straw Chopper - Supports
Canvas For Straw Walker Body
Chain Drive For Drum
Ballst Weight On Rear Axle
Weight Tray On Rear Tyres
Ballst Weight On Rear Body
Spike Tooth Concave With Two Complete Thresing
Bars Mais-Mix
Concave Mais-Mix
Upper Sieve, Corn - Cob - Mix
Drum Bar Plates
Equipment For Small Seeds
Equipment For Soy
Speed Reduction
Drive Belts And Drive Chains (Left-Hand)
