Landoll Drexel Forklift SLT30-2 AC SLT35-2 AC Operators Manual F-1007-2403 2025
Brand: Landoll Drexel
Type of Machine: Forklift
Model: Landoll Drexel SLT30-2 AC, SLT35-2 AC Forklift
Part Number: F-1007-2403
Publication Date: 2025
Number of Pages: 100 Pages
Introduction
Introduction
Forklift Description
Receiving
Items Furnished With Your Forklift
Items Required
Tools & Test Equipment
Preparing the Forklift
Inspecting the Forklift
Towing the Forklift
Recommended Lubricants
Technical Specifications
SafetyGetting Started
Operator Training
Drexel Forklift Safety Statements
Understanding Safety Statements
Site Supervision
Terminology and Illustrations Used
Operator Safety
Lockout/Tagout
Battery Safety
Available Options
Fork Positioner
Fire Extinguisher
In Case of a Fire
Additional Publications
Vehicle FamiliarityOverview
Data Plate
Serial Number Code
Forklift Components
Serial Number for Mast and Frame
Before Operating
Forklift Rated Capacity
Major Structural Points
Frame
Overhead Guard
Electrical Static Discharge (ESD) Straps
Operator Controls
Brake Pedal
Brake by Plugging
Check the Brake Fluid Level
Battery
Check Steering
Accelerator Pedal
Steering Column
Key Switch
Steering Wheel and Tilt/Telescope Clamp
Dash
Operator Switches
Tires and Wheels
Inspection
Chunking (Chipping) or Embedded Objects
Undercutting and Uneven Wear
Flat-Spotting
To Extend Tire Life
Emergency Stop
Joystick
Directional Rocker Switch
Static Return to Off (SRO) Function
Horn
Landguide Wire Guidance System
Auxiliary Hydraulic Function
Hydraulic Cylinders and Valves
Hydraulic Hoses, Tubing and Fittings
Check Hydraulic Fluid
Mast Operation
Lift Lever
Tilt
Sideshift
Pivot
Seat Adjustments
Seat Switch
Seat Belt
Steering Wheel
Forks
Rated Capacity and Load Center
Fork Inspection
Fork Marking
Available Options
EE Series (Electrical Enclosure)
Cold Storage (Freezer Package)
Lights and Alarms
BatteryBattery Information
Checking the Battery
Check Battery Acid/Electrolyte Level
Checking Specific Gravity
Removing the Battery
Battery Rollout Tray
Battery Restraint Arm
Charging the Battery
Operating Your Forklift SafelyOverview
Principles of Forklift Operation
Basic Operating Procedures
Getting On and Off the Forklift
Driving Position
Proper Seating Position and Travel Procedure
Turning and Intersections
Stopping
Parking
Understanding Stability
Basic Principles
Knowing the Rated Capacity
Counterweight
Determining Weight of the Load
Center of Gravity
Load Center
Maximum Fork Lift Height
Tilting Considerations
Tipping
Longitudinal Tipping
Lateral Tipping
Lateral or Longitudinal Tipping
Speed
Setting the Forks
Fork Positioner (OPTION)
Retrieving a Load
Handling a Load
Transporting a Load
Traveling on Inclines
Unloading the Forklift
Dockboards and Forklifts
Workplace Conditions
Working in Hazardous Environments
Atmospheric/Electrical
Chemical Hazards
Daily InspectionInspections Overview
Maintenance Schedule
Operator Daily Pre-Shift Inspection Checklist
Tire Inspection
Lift Chains
Primary Lift Chain (Duplex, Triplex and Quadplex Masts)
Electrical Fastener Connections
Forks
Hydraulic Fluid
Operator Controls
Lift/Lower/Sideshift Controls
Tilt Control
Sideshift Control
Directional Control
To Check SRO:
Operator’s Compartment
Steering
Steering Column Tilt and Telescope
Dash Display
Seat, Seat Belt, Slides, and Switch
Rust and Corrosion
Safety Decals
Data Plate
Unusual Noises
Daily Checklist
- Bendi Landoll Forklift Series III Part & Operators, Maintenance Manual
- Drexel Landoll Forklift SLT22 SLT30 SLT35 Service & Part Maintenance Manual
- Bendi Landoll Forklift Bulletins & Misc Service Manual
- Bendi Forklift B30 B40 AC DS Maintenance Manual F-649-R0 2015
- Landoll Bendi Forklift Model B3-30 AC DS Parts Manual
- Drexel Landoll Forklift FL40-FL60 EX Service & Part Maintenance Manual
- Bendi Forklift Series IV Electrical Diagram, Service, Operators, Parts & Maintenance Manual 2004
- Landoll Bendi Forklift Model B40i4 Parts Manual
- Landoll Bendi Forklift 3 AC Serie Service Manual De
- Bendi Landoll Forklift B40-IC Tier II Part & Operators, Maintenance Manual
- Bendi Forklift B40 Series 4 Specification Manual
- Landoll Bendi Forklift Service Parts Manual CD
- Drexel Landoll Forklift SL30SE-SL40SE-SL50SE Service & Part Maintenance Manual
- Landoll Bendi Forklift 3 AC Serie Operator's Manual De
- Landoll Bendi Forklift 3 AC Serie Parts Manual
