Hyundai
86
178,635
Landoll Drexel Forklift SLT30-2 AC SLT35-2 AC Maintenance Repair Manual F-1008-1022 2025
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Repair Manual, Wiring Diagram
Model: Landoll Drexel SLT30-2 AC, SLT35-2 AC Forklift
Part Number: F-1008-1022
Publication Date: 2025
Number of Pages: 136 Pages
Introduction, Safety and Specifications
Before You Begin​
Introduction​
Operating Instructions​
Service Training​
Required Tools​
Models Covered​
Replacement Parts​
Storage​
Special Safety Notices​
Decal Identification​
General Maintenance Instructions​
Safety Guidelines​
Lockout/Tagout​
Battery Safety​
Charging Safety​
Hydraulic System​
Mast Service Safety​
Tilt Cylinder​
Lifting and Blocking the Forklift​
Emergency STOP Button​
Towing the Forklift​
Specifications​
Lubrication Specifications​
Inspections
Inspection Introduction​
Receiving Forklift Inspection​
Items Furnished with the Forklift​
Items Required​
Safety Equipment Required​
Inspection Program​
Daily Inspection Checklist​
Inspection Responsibilities​
Operator’s Daily Checklists​
Operator Daily Pre-Shift Inspection Checklist​
1st 100 Hour Technicians Inspection Checklist​
500 Hour Technicians Inspection Checklist​
1000 Hours Technician Inspection Checklist​
2000 Hours Technician Inspection Checklist​
4000 Hours Technician Inspection Checklist​
Inspection Practices​
Inspection Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Completing Performance Testing​
Inspecting the Forklift​
Brake System​
Brake System Service​
Checking Brakes​
Check the Brake Fluid Level​
Changing Brake Fluid​
Check Service Drum Brakes​
Parking Brake​
Covers and Counterweights​
Nuts, Bolts and Screws​
Counterweights​
Decals and Placards​
Electrical Inspection​
Battery​
Checking the Battery​
Check Fluid Level​
Charging the Battery​
Charging Procedure​
Accelerator Pedal, Directional Switch & Backup Alarm​
Hydraulic System Inspection​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing, and Fittings​
Hydraulic Fluid Check​
Hydraulic Inspection​
Replace High Pressure Filter​
Change Hydraulic Fluid​
Mast and Front End​
Fork Inspection​
Rated Capacity and Load Center​
Cracks​
Straightness of Blade and Shank​
Fork Angle​
Difference in Height Between Fork Tips​
Positioning Lock​
Wear​
Fork Markings​
Measuring Fork Thickness and Distortion​
Mast Maintenance​
Load Roller Maintenance​
Chain Maintenance​
Chain Inspection​
Chain Lubrication​
Chain Adjustment​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Mast Racking​
Check the Tilt Cylinder​
Checking for Leaks​
Operator’s Compartment​
Major Structural Points​
ESD Straps​
Overhead Guard​
Seat​
Electrical Connections​
Key Switch​
Dash Display​
Joystick​
Horn​
Joystick Functions​
Mast Controls​
Lift​
Tilt Control​
Side Shift​
Pivot Controls​
Wire Guidance Button​
Auxiliary Hydraulic Function​
Lights​
Battery Restraint System and Rollout​
Rollout Battery Removal​
Rollout Battery Installation​
Powertrain and Steering​
Tires​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat-Spotting​
Extend Tire Life​
Wheel Bearings​
Steering​
Gearbox​
Check Planetary Gearbox​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Hydraulic Problems​
Hydraulic Problems​
Audible Problems​
Audible Problems​
Brake Problems​
Visible Problems​
Electrical Problems​
Wiring Diagram​
Maintenance and Repair
Overview​
Replacement Parts​
Maintenance Schedule​
To Prepare the Forklift​
Battery Removal and Installation​
Forklift Lubrication​
Tilt Cylinder Clevis​
Main Rotation Bearings​
Crosshead Lubrication​
Pivot Cylinder Clevis Pin​
Steering Gear Lubrication​
Servicing the Gearbox​
Drive Motor/Pump Motor​
Floor Plate​
Floor Plate Removal​
Accelerator Pedal​
Adjusting Accelerator Pedal​
Replacing Accelerator Pedal​
Forks​
Removing Forks​
Repairing Forks​
Load Testing Forks​
Brakes​
Drum Brakes​
Brake Adjustment​
Checking/Changing Brake Shoes​
Repairing Brake Wheel Cylinders​
Brake Drums​
Measure Brake Drum Diameter​
Replacing Brake Drum Assemblies​
Brake Pedal Assembly​
Brake Pedal​
Replacing the Brake Pedal Sensor​
Master Cylinder​
Check Master Cylinder Fluid Level​
Service Brake Linkage​
Replacing Master Cylinder​
Bench Bleeding Master Cylinder​
Service Brake Pedal Assembly​
Parking Brake​
Parking Brake Assembly​
Checking the Parking Brake​
Park Brake Installation and Mounting​
Park Brake Maintenance​
Drive System​
Drive Motor Replacement​
Checking Drive Wheel Gearbox​
Gearbox Replacement​
Replacing Wheels​
Replacing Drive Wheel​
Replacing the Load Wheel​
Load Wheel Bearing Maintenance​
Electrical​
Dash Display Removal​
Key Switch​
Steering Wheel Removal​
Steering Column (Console) Removal​
Steering Torque Feedback Device​
Inspecting the Contacts​
Replacing Controllers​
High Current Connections Definition​
Joystick​
Replacing the Joystick​
Seat Switch Assembly​
Replacing the Seat/Micro Switch​
Horn​
Replacing the Horn​
Replacing Backup Alarm​
Lighting​
Fuses​
Hydraulics​
Hydraulic Pump Service​
Replacing the Hydraulic Pump and Motor​
Hydraulic Control Valve Assembly​
Checking and/or Adjusting Pressure​
Hydraulic Fittings and Hoses​
Mast and Front End​
Removing the Mast From the Forklift​
Check Roller Clearance​
Remove Tilt Cylinder​
Removing the Pivot Cylinder​
Software
Service Tool Download and Installation​
ServiceTool​
Calibration and Programming
Dashboard Calibration​
Below are “No Run” Diagnostics​
Run Diagnostics​
Master Setup​
Traction Setup​
Pump Setup​
Set Clock​
Throttle and Brake Calibration​
Wire Guidance Calibration​
Fault Codes​
Torque Specifications
Torque Specifications​
General Torque Specifications​
Hydraulic Fitting Torque Specifications​
Supplier Provided Documentation
Disclaimer:​
Lift Technologies Mast Service Manual​
