Hyundai
86
176,834
Landoll Drexel Forklift SLT30-2 AC SLT35-2 AC Maintenance Manual F-1008-1022
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Drexel SLT30-2 AC, SLT35-2 AC Forklift
Part Number: F-1008-1022
Publication Date: 2024
Number of Pages: 144 Pages
Introduction, Safety and Specifications
Before You Begin​
Operating Instructions​
Service Training​
Models Covered*​
Required Tools or Equipment​
Replacement Parts​
Decal Identification​
General Maintenance Instructions​
Safety Guidelines​
Lockout/Tagout​
Battery Safety​
Charging Safety​
Battery Removal and Installation​
Hydraulic System​
Mast Service Safety​
Tilt Cylinder​
Lifting and Blocking the Forklift​
Emergency STOP Button​
Towing the Forklift​
Specifications​
Inspections
Inspection Introduction​
Receiving Forklift Inspection​
Items Furnished with the Forklift​
Items Required​
Safety Equipment Required​
Inspection Program​
Maintenance Schedule​
To Prepare the Forklift​
Daily Inspection Checklist​
Inspection and Maintenance Responsibilities​
Operators Daily Checklists​
Inspection Practices​
Inspection and Maintenance Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Completing Performance Testing​
Operator Daily Pre-Shift Inspection Checklist - Drexel SLT 30/35-2 AC​
1st 100 Hour Technicians Inspection Checklist - Drexel SLT 30/35-2 AC​
500 Hour Technicians Inspection Checklist - Drexel SLT 30/35-2 AC​
1000 Hours Technician Inspection Checklist - Drexel SLT 30/35-2 AC​
2000 Hours Technician Inspection Checklist - Drexel SLT 30/35-2 AC​
4500 Hours Technician Inspection Checklist - Drexel SLT 30/35-2 AC​
Tires​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat-spotting​
To Extend Tire Life​
Fork Inspection​
ESD Straps​
Rated Capacity and Load Center​
Cracks​
Straightness of Blade and Shank​
Fork Angle​
Difference in Height Between Fork Tips​
Positioning Lock​
Wear​
Fork Markings​
Measuring Fork Thickness and Distortion​
Major Structural Points​
Rust, Corrosion or Cracks​
Overhead Guard​
Hydraulic System Inspection/Maintenance​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Hydraulic Fluid​
Replace High Pressure Filter​
Change Hydraulic Fluid​
Battery​
Battery Restraint System and Roll-out​
Roll-out Battery Removal​
Roll-out Battery Installation​
Checking the Battery​
Check Fluid Level​
Charging the Battery​
Charging Procedure​
Identification Plate and Safety Warning Decals​
Seat​
Seat Adjustments​
Seat Belt​
Seat Switch​
Electrical Connections​
Key Switch​
Dash Display​
Steering​
Accelerator Pedal, Directional Switch & Backup Alarm​
Parking Brake​
Brake System​
Brake System Service​
Checking Brakes​
Check the Brake Fluid Level​
Changing Brake Fluid​
Check Service Drum Brakes​
Joystick​
Horn​
Joystick Functions​
Mast Controls​
Lift​
Tilt Control​
Side Shift​
Pivot Controls​
Wire Guidance Button​
Auxiliary Hydraulic Function​
Lights​
Mast Maintenance​
Load Roller Maintenance​
Chain Maintenance​
Chain Inspection​
Chain Lubrication​
Chain Adjustment​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Mast Racking​
Tilt Cylinder​
Checking for Leaks​
Forklift Lubrication​
Tilt Cylinder Clevis​
Main Rotation Bearings​
Crosshead Lubrication​
Pivot Cylinder Clevis Pin​
Steering Gear Lubrication​
Servicing the Gearbox​
Drive Motor/Pump Motor​
Nuts, Bolts and Screws​
Check and tighten the following:​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Hydraulic Problems​
Audible Problems​
Brake Problems​
Visible Problems​
Electrical Problems​
Wiring Diagram​
Corrective Maintenance
Overview​
Replacement Parts​
Floor Plate​
Floor Plate Removal​
Accelerator Pedal​
Adjusting Accelerator Pedal​
Replacing Accelerator Pedal​
Forks​
Removing Forks​
Repairing Forks​
Load Testing Forks​
Brakes​
Drum Brakes​
Brake Adjustment​
Checking/Changing Brake Shoes​
Repairing Brake Wheel Cylinders​
Brake Drums​
Measure Brake Drum Diameter​
Replacing Brake Drum Assemblies​
Brake Pedal Assembly​
Brake Pedal​
Replacing the Brake Pedal Sensor​
Master Cylinder​
Check Master Cylinder Fluid Level​
Service Brake Linkage​
Replacing Master Cylinder​
Bench Bleeding Master Cylinder​
Service Brake Pedal Assembly​
Parking Brake​
Parking Brake Assembly​
Checking the Parking Brake​
Park Brake Installation and Mounting​
Park Brake Maintenance​
Drive System​
Drive Motor Replacement​
Checking Drive Wheel Gearbox​
Gearbox Replacement​
Replacing Wheels​
Replacing Drive Wheel​
Replacing the Load Wheel​
Load Wheel Bearing Maintenance​
Electrical​
Dash Display Removal​
Key Switch​
Steering Wheel Removal​
Steering Column (Console) Removal​
Steering Torque Feedback Device​
Inspecting the Contacts​
Replacing Controllers​
High Current Connections Definition:​
Joystick​
Seat Switch Assembly​
Horn​
Replacing the Horn​
Replacing Backup Alarm​
Lighting​
Fuses​
Hydraulics​
Hydraulic Pump Service​
Replacing the Hydraulic Pump and Motor​
Hydraulic Control Valve Assembly​
Checking and/or Adjusting Pressure​
Hydraulic Fittings and Hoses​
Mast and Front End​
Removing the Mast From the Forklift​
Check Roller Clearance​
Remove Tilt Cylinder​
Removing the Pivot Cylinder​
Software
Service Tool Download and Installation​
ServiceTool​
Calibration and Programming
Dashboard Truck Calibration​
Below are “No Run” Diagnostics.​
Run Diagnostics​
Master Setup​
Traction Setup​
Pump Setup​
Set Clock​
Throttle and Brake Calibration​
Wire Guidance Calibration​
Fault Codes​
Torque Specifications
Torque Specifications​
General Torque Specifications (rev. 4/97)​
UNC SAE Torque Specifications​
UNF SAE Torque Specifications​
Metric Torque Specifications​
Hydraulic Fitting Torque Specifications (REV. 10/97)​
Parker® Brand Fittings​
Aeroquip® Brand Fittings​
Gates® Brand Fittings​
Supplier Provided Documentation
Disclaimer:​
Duplex​
Lift Technologies Mast Service Manual​
Triplex​
