Hyundai
86
176,834
Landoll Drexel Forklift SL60 AC SL80 AC Maintenance Manual F-993-2403 2025
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Manual, Wiring Diagram
Model: Landoll Drexel SL60 AC, SL80 AC Forklift
Part Number: F-993-2403
Publication Date: 2025
Number of Pages: 150 Pages
Introduction, Safety, and Specifications
Before You Begin​
Introduction​
Operating Instructions​
Service Training​
Required Tools​
Replacement Parts​
Decal Identification​
Decals​
General Maintenance Instructions​
Lock Out / Tag Out​
Battery Safety​
Charging Safety​
Hydraulic System​
Mast Service Safety​
Tilt Cylinder​
Lifting and Blocking the Forklift​
Emergency STOP Button​
Towing the Forklift​
Specifications​
Lubrication Specifications​
Torque Specifications​
Fluid Capacities​
Inspections and Preventative Maintenance
Overview​
Tools or Equipment Required​
Safety Equipment Required​
Inspection Program​
Maintenance Program​
Inspection and Maintenance Responsibilities​
Operators Daily Checklists​
Inspection Practices​
Inspection and Maintenance Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Completing Performance Testing​
Operator Daily Pre-Shift Inspection Checklist - Drexel SL 60/80 AC​
1st 100 Hour Technicians Inspection Checklist - Drexel SL 60/80 AC​
500 Hour Technicians Inspection Checklist - Drexel SL 60/80 AC​
2000 Hour Technician Inspection Checklist - Drexel SL 60/80 AC​
4000 Hour Technician Inspection Checklist - Drexel SL 60/80 AC​
Tires​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat-spotting​
To Extend Tire Life​
Electrical Static Discharge Straps​
Fork Inspection​
Rated Capacity and Load Center​
Cracks​
Straightness of Blade and Shank​
Fork Angle​
Difference in Height Between Fork Tips​
Positioning Lock​
Wear​
Fork Marking​
Measuring Fork Thickness and Distortion​
Major Structural Points​
Rust Or Corrosion​
Overhead Guard​
Hydraulic System Inspection/Maintenance​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Hydraulic Oil​
Replace High Pressure Hydraulic Oil Filter​
Change Hydraulic Oil​
Hydraulic Pressure Filter​
Replace Pressure Filter​
Battery​
Checking the Battery​
Specific Gravity Correction​
Charging the Battery​
Battery Restraint System and Roll-out (Optional)​
Roll-out Battery Removal​
Roll-out Battery Installation​
Identification Plate and Safety Warning Decals​
Seat​
Seat Adjustments​
Seat Belt​
Seat Switch​
Electrical Connections​
Key Switch​
Dash Display​
Parking Brake​
Accelerator Pedal, Directional Switch & Backup Alarm​
Service Disc Brakes​
Checking Brake Fluid​
Check Brake Pads​
Horn​
Mast Controls​
Lift​
Tilt Control​
Side Shift​
Pivot Controls​
Wire Guidance Button​
Auxiliary Hydraulic Function​
Lights​
Steering - Check Operation​
Mast Maintenance​
Load Roller Maintenance​
Chain Maintenance​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Mast Racking​
Tilt Cylinder​
Side Shift Cylinder​
Forklift Lubrication​
Tilt Cylinder Clevis​
Main Rotation Bearings​
Bearing Pad Lubrication​
Fork Positioner Lubrication (Option)​
Steering Knob Lubrication​
Grease Steering Axle​
Wheel Bearings​
Gearbox​
Check Gearbox​
Servicing the Gearbox​
Nuts, Bolts and Screws​
Check and tighten the following:​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Visual Problems​
Audible Problems​
Hydraulic Problems​
Brake Problems​
Electrical Problems​
Corrective Maintenance
Overview​
Replacement Parts​
Floor Plate​
Floor Plate Removal and Assembly​
Accelerator Pedal​
Forks​
Removing Forks​
Repairing Forks​
Load Testing Forks​
Brakes​
Changing Brake Pads​
Replacing the Brake Caliper Assembly​
Disc Brake Rotors​
Brake Pedal Assembly​
Master Cylinder​
Bleeding Brakes​
Service Brake Pedal Assembly​
Parking Brake​
Parking Brake Assembly​
Parking Brake Lever​
Parking Brake Switch​
Replacing the Parking Brake Cable​
Parking Brake Caliper Assembly​
Replacing Any Other Hydraulic Brake Component​
Drive System​
Load Wheel Assembly​
Gearbox and Traction Drive Motor​
Replacing the Gearbox​
Replacing the Traction Drive Motor​
Electrical​
Replacing Complete Control Panel​
Replacing Single Controller Components​
Controllers and Wire Connections​
Replacing Vehicle Master Controller (VMC)​
Hydraulics​
Hydraulic Motor and Pump​
Hydraulic Control Valve Assembly​
Checking and/or Adjusting Pressure​
Replacing Hydraulic Control Valve​
Hydraulic Fittings and Hoses​
Replacing Hydraulic Tank​
Replacing the Hydraulic Pump and Motor​
Mast and Front End​
Mast Removal​
Remove Tilt Cylinder​
Removing the Pivot Cylinder​
Pivot Arm​
Crosshead​
Sideshift Chain Assembly​
Side Shift Bearing Shoe Adjustment​
Pivot Interlock Switch​
Steering Axle Assembly​
Removing Rear Axle​
Disassembling and Inspecting Rear Axle Mounting Blocks​
Disassembling and Inspecting Wheel Bearings​
Assembling Wheel Bearings​
Disassembling and Inspecting Steering Axle​
Assembling Steering Axle​
Axle Installation​
Steering Column Assembly​
Steering Column/Dash Assembly​
Replacing Steering Wheel​
Remove the Dash Display​
Key Switch​
Rocker (On/Off) Switches​
Steering Column​
Steering Orbital Control Unit​
Safety Features​
Horn​
Seat Switch​
Replacing the Switch and Cushion​
Overhead Guard, Lighting, and Alarms​
Backup Alarms​
Calibration Programming
Dashboard Forklift Calibration​
Main Menu​
“No Run” Diagnostics​
“Run” Diagnostics​
Master Setup​
Traction Setup​
Pump Setup​
Clock Set​
Throttle, Brake and Steer Calibration​
Wire Guidance Calibration​
Troubleshooting Codes​
Software
Service Tool Download and Installation​
Service Tool​
Wiring Diagram
Wiring Diagram​
Supplier Provided Documentation
Disclaimer​
Duplex​
Lift Technologies Mast Service Manual​
Triplex​
Glossary
