Hyundai
86
178,635
Landoll Drexel Forklift SL30 AC-2 SL40 AC-2 SL50 AC-2 Parts Manual F-934-2308
Brand: Landoll Drexel
Type of Machine: Forklift
Model: Landoll Drexel SL30 AC-2, SL40 AC-2, SL50 AC-2 Forklift
Part Number: F-934-2308
Publication Date: 2023
Number of Pages: 196 Pages
Brakes
Brake Components​
Parking Brake Components​
Brake Pedal Assembly​
Brake Pedal Assembly Mounting​
Covers and Counterweights
Battery Cover Components​
Counterweights SL30/40​
Counterweights SL50​
Covers​
SL50 Battery Counterweight​
Decals and Placards
Decal and Placard Placement​
Decals and Placards​
Electrical
Controller Mounting​
Contactors and Fuses (BEFORE 08/30/2021)​
Contactors and Fuses (AFTER 08/30/2021) (BEFORE 02/24/2022)​
Contactors and Fuses (AFTER 02/24/2022)​
Drive Motor Fans​
E-Stop and Side Shift Proximity Switch​
Heavy Cables​
Horn and Backup Alarm​
Lighting​
Pump Motor Breakdown​
Steering Column - Electrical​
Wiring Diagram​
Hydraulics
Hydraulic Diagram​
Hydraulic Valve​
Filter (High Pressure)​
Pivot (Swingmast) Hydraulics​
Pump and Tank Connections​
Pump and Motor Assembly​
Side Shift (Traverse) Hydraulics​
Steering Hydraulics​
Tank (Reservoir) Assembly (BEFORE 02/01/2022)​
Tank (Reservoir) Assembly (AFTER 02/01/2022)​
Tilt Hydraulics​
Pivot Cylinder Assembly​
Tilt Cylinder Assembly​
Triple/Quad Mast - Single Auxiliary Hydraulic Option​
Triple/Quad Mast - Double Auxiliary Hydraulic Option​
Mast and Front End
Crosshead Assembly​
Swingarm Assembly​
Forks​
Load Backrest​
Mast Information​
Rack Installation​
Operator’s Compartment
Accelerator Pedal and Floor​
Joystick​
Overhead Guard​
Seat Assembly​
Steering Column Assembly​
Steering Column Installation​
Powertrain and Steering
Drive Motors Installation​
Gearbox Assembly - Brevini 29:1 In-Line (BEFORE 05/06/2020)​
Gearbox Assembly, RR USA Planetary 29.3:1 (AFTER 05/06/2020) (BEFORE 02/03/2021)​
Gearbox Assembly, RR USA Planetary 29.3:1 Ground Gear (AFTER 02/03/2021)​
Drive Motor Assembly​
Steering Axle Assembly​
Steering Cylinder Assembly​
Steering Axle Mounting​
Wheels and Tires​
Options
Battery Tray​
Battery Roll-Out Tray​
Cold Storage​
EE Option Components​
Fast Charge​
Fast Charge Cover​
Fire Extinguishers​
Landguide​
Lift Limit​
Lighting​
Long Load Support​
Martin Cab​
OHG Cover Options​
Operator’s Fan​
Operator’s Protection - Right Side​
Park Brake Alarm​
Rear Storage​
Roller Guidance​
Glossary
Index
