Hyundai
86
178,635
Landoll Drexel Forklift SL30 AC-2 SL40 AC-2 SL50 AC-2 Maintenance Manual F-936-2311 2025
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Drexel SL30 AC-2, SL40 AC-2, SL50 AC-2 Forklift
Part Number: F-936-2311
Publication Date: 2025
Number of Pages: 142 Pages
Introduction, Safety, and Specifications
Getting Started​
Introduction​
Operating Instructions​
Service Training​
Tools or Equipment Required​
Replacement Parts​
Understanding Safety Statements​
Special Safety Notices​
Decal Identification​
General Maintenance Instructions​
Safety Guidelines​
Lockout/Tagout​
Battery Safety​
Charging Safety​
Hydraulic System​
Mast Service Safety​
Tilt Cylinder​
Lifting and Blocking the Forklift​
Emergency STOP Button​
Towing the Forklift​
Specifications​
Lubrication Specifications​
General Torque Specifications​
Hydraulic Fitting Torque Specifications​
Inspections and Preventative Maintenance
Inspection Introduction​
Receiving Forklift Inspection​
Items Furnished with the Forklift​
Safety Equipment Required​
Inspection Program​
Daily Inspection Checklist​
Inspection Responsibilities​
Operator’s Daily Checklists​
Operator Daily Pre-Shift Inspection Checklist​
1st 100 Hour Technicians Inspection Checklist​
500 Hour Technicians Inspection Checklist​
1000 Hours Technician Inspection Checklist​
2000 Hour Technician Inspection Checklist​
4000 Hour Technician Inspection Checklist​
Inspection Practices​
Inspection Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Inspecting the Forklift​
Brakes​
Parking Brake​
Covers and Counterweights​
Nuts, Bolts and Screws​
Counterweights​
Decals and Placards​
Electrical Inspection​
Battery​
Checking the Battery​
Charging the Battery​
Accelerator Pedal, Directional Switch & Backup Alarm​
Hydraulic System Inspection​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Hydraulic Fluid Check​
Hydraulic Inspection​
Replace High Pressure Hydraulic Fluid Filter​
Mast and Front End​
Fork Inspection​
General Mast Inspection​
Mast Maintenance​
Load Roller Maintenance​
Chain Inspection​
Chain Maintenance​
Chain Lubrication​
Chain Adjustment​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Mast Racking​
Tilt Cylinder​
Operator’s Compartment​
Major Structural Points​
Seat Adjustments​
Electrical Connections​
Key Switch​
Dash Display​
Joystick​
Mast Controls​
Lift​
Tilt Control​
Sideshift​
Pivot Controls​
Wire Guidance Button​
Auxiliary Hydraulic Function​
Lights​
Battery Restraint System and Rollout (Optional)​
Powertrain and Steering​
Tires​
Wheel Bearings​
Gearbox​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Hydraulic Problems​
Brake Problems​
Electrical Problems​
Audible Problems​
Visible Problems​
Maintenance and Repair
Overview​
Forklift Lubrication​
Tilt Cylinder Clevis​
Bearing Pad Lubrication​
Fork Positioner Lubrication (OPTIONAL)​
Grease Steering Axle​
Mast and Front Plate Assemblies​
Forks​
Repairing Forks​
Load Testing Forks​
Straightness of Blade and Shank​
Fork Angle​
Difference in Height Between Fork Tips​
Measuring Fork Thickness and Distortion​
Mast​
Removing the Mast From the Forklift​
Swingarm Assembly​
Removing Carriage Weldment Assembly​
Removing the Tilt Cylinder​
Removing the Pivot Cylinder​
Removing the Traverse Drive Motor​
Removing Main Rotation Pin Bearings​
Removing Traverse Pin Weldment​
Removing Cam Followers​
Sideshift Stops​
Swingarm Assembly​
Carriage Assembly​
Hydraulic Hose Carrier and Rack Installation​
Brake System Service​
Brake Caliper Assembly​
Changing Brake Pads​
Replacing the Brake Caliper Assembly​
Repairing Brake Caliper Pistons​
Disc Brake Rotors​
Measure Thickness of Rotor​
Check Lateral Run-Out (Warping)​
Replacing Brake Rotor Assemblies​
Parking Brake Assembly​
Parking Brake Lever​
Checking Parking Brake Adjustment​
Parking Brake Switch​
Replacing Parking Brake Switch​
Replacing the Parking Brake Cable​
Parking Brake Caliper Assembly​
Changing Parking Brake Pads or Replacing Parking Brake Caliper​
Replacing Any Other Hydraulic Brake Component​
Hydraulics​
Change Hydraulic Fluid​
Clean or Replace Suction Screen​
Hydraulic Motor and Pump​
Change Hydraulic Fluid Filter​
Hydraulic Control Valve Assembly​
Checking Hydraulic Pressure​
Adjusting Hydraulic Pressure​
Replacing Hydraulic Control Valve​
Drive System​
Load Wheel Assembly​
Gearbox and Traction Drive Motor​
Replacing the Gearbox​
Replacing the Traction Drive Motor​
Steering Axle Assembly​
Disassembling and Inspecting Rear Axle Mounting Blocks​
Disassembling and Inspecting Wheel Bearings​
Assembling Wheel Bearings​
Disassembling and Inspecting Steering Axle​
Assembling Steering Axle​
Axle Installation​
Hydraulic Fittings and Hoses​
Electrical​
Replacing Complete Control Panel​
Replacing Controllers​
Replacing VMC Vehicle Master Controller​
Steering Column/Dash Assembly​
Remove the Display Panel​
Key Switch​
Rocker (On/Off) Switches​
Joystick​
Replacing the Joystick​
Accelerator and Brake Pedals​
Brake Pedal Assembly​
Brake Pedal​
Service Brake Linkage​
Brake Light Switch Adjustment​
Brake Light Switch Replacement:​
Master Cylinder​
Replacing Master Cylinder​
Bench Bleed the Master Cylinder​
Bleeding Brakes​
Service Brake Pedal Assembly​
Floor Plate Removal​
Accelerator Pedal Assembly​
Replacing Linear Accelerator Module​
Steering​
Steering Wheel​
Steering Column (Console)​
Steering Orbital Control Unit​
Direction Control Switch​
Horn​
Removing the Horn​
Seat Switch​
Seat Switch Replacement​
Safety Features​
Overhead Guard, Lighting, and Alarms​
Back Up Alarms​
Replacing Hydraulic Tank​
Calibration Programming
Dashboard Calibration​
Main Menu​
“No Run” Diagnostics​
Master Setup​
Traction Setup​
Pump Setup​
Clock Set​
Error Log​
Clear Error Log​
Password Setup​
Throttle, Brake and Steer Calibration​
Wire Guidance Calibration​
Error Codes​
Supplier Provided Documentation
Disclaimer​
