Hyundai
86
176,834
Landoll Drexel Forklift SL30 AC-2 SL40 AC-2 SL50 AC-2 Maintenance Manual F-936-0321
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Drexel SL30 AC-2, SL40 AC-2, SL50 AC-2 Forklift
Part Number: F-936-0321
Publication Date: 2023
Number of Pages: 142 Pages
Introduction, Safety, and Specifications
Getting Started​
Introduction​
Operating Instructions​
Service Training​
Required Tools​
Replacement Parts​
Decal Identification​
General Maintenance Instructions​
Lock Out / Tag Out​
Battery Safety​
Charging Safety​
Hydraulic System​
Mast Service Safety​
Tilt Cylinder​
Lifting and Blocking the Forklift​
Emergency STOP Button​
Towing the Forklift​
Specifications​
Lubrication Specifications​
Torque Specifications​
Fluid Capacities​
General Torque Specifications (rev. 4/97)​
UNC SAE Torque Specifications​
UNF SAE Torque Specifications​
Metric Torque Specifications:​
Metric Torque Specifications​
Hydraulic Fitting Torque Specifications​
Parker® Brand Fittings​
Aeroquip® Brand Fittings​
Gates® Brand Fittings​
Inspections and Preventative Maintenance
Overview​
Tools or Equipment Required​
Safety Equipment Required​
Inspection Program​
Maintenance Program​
Inspection and Maintenance Responsibilities​
Operators Daily Checklists​
Inspection Practices​
Inspection and Maintenance Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Completing Performance Testing​
Operator Daily Pre-Shift Inspection Checklist - Drexel SL 30/40/50 AC Series 2​
1st 100 Hour Technicians Inspection Checklist - Drexel SLAC Series 2​
500 Hour Technicians Inspection Checklist - Drexel SLAC Series 2​
2000 Hour Technician Inspection Checklist - Drexel SLAC Series 2​
4500 Hour Technician Inspection Checklist - Drexel SL 30/40/50 AC Series 2​
Tires​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat-spotting​
To Extend Tire Life​
ESD Straps​
Fork Inspection​
Rated Capacity and Load Center​
Cracks​
Positioning Lock​
Wear​
Fork Marking​
Overhead Guard​
Hydraulic System Inspection/Maintenance​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Hydraulic Oil​
Battery​
Checking the Battery​
Specific Gravity Correction​
Charging the Battery​
Battery Restraint System and Roll-out (Optional)​
Roll-out Battery Removal​
Roll-out Battery Installation​
Check the Brake Fluid Level​
Identification Plate and Safety Warning Decals​
Seat Adjustments​
Seat Adjustments​
Seat Belt​
Electrical Connections​
Key Switch​
Dash Display​
Parking Brake​
Accelerator Pedal, Directional Switch & Backup Alarm​
Service Brakes​
Seat Switch​
Mast Controls​
Lift​
Tilt Control​
Side Shift​
Pivot Controls​
Wire Guidance Button​
Auxiliary Hydraulic Function​
Lights​
Steering - Check Operation​
General Mast Inspection​
Mast Chains​
Chain Inspection​
Chain Lubrication​
Chain Adjustment​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Pivot Arm Racking​
Mast Racking​
Tilt Cylinder​
Side Shift Cylinder​
Forklift Lubrication​
Tilt Cylinder Clevis​
Bearing Pad Lubrication​
Fork Positioner Lubrication (Option)​
Steering Knob Lubrication​
Grease Steering Axle​
Hydraulics​
Replace High Pressure Hydraulic Oil Filter​
Change Hydraulic Oil​
Service Disc Brakes​
Check Brake Pads​
Wheel Bearings​
Major Structural Points​
Rust Or Corrosion​
Immediately pull forklift from service and repair if frame cracks are found.​
Gear Box​
Check Planetary Gear Box​
Servicing the Gearbox​
Nuts, Bolts and Screws​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Hydraulic Problems​
Brake Problems​
Electrical Problems​
Audible Problems​
Visible Problems​
Corrective Maintenance
Overview​
Mast and Front Plate Assemblies​
Forks​
Fork Angle​
Mast​
Mast Carriage Assembly​
Removing Carriage Weldment Assembly​
Removing the Tilt Cylinder​
Removing the Pivot Cylinder​
Removing the Traverse Drive Motor​
Removing Main Rotation Pin Bearings​
Removing Traverse Pin Weldment​
Removing Cam Followers​
Side Shift Stops​
Brake System Service​
Brake Caliper Assembly​
Changing Brake Pads​
Replacing the Brake Caliper Assembly​
Disc Brake Rotors​
Parking Brake Assembly​
Replacing Any Other Hydraulic Brake Component​
Hydraulics​
Hydraulic Motor and Pump​
Drive System​
Load Wheel Assembly​
Replacing the Gear Box​
Replacing the Traction Drive Motor​
Steering Axle Assembly​
Hydraulic Fittings and Hoses​
Electrical​
Replacing Complete Control Panel​
Replacing Single Controller Components​
Replacing VMC Vehicle Master Controller​
Steering and Pedals​
Brake Pedal Assembly​
Brake Light Switch Adjustment​
Master Cylinder​
Bleeding Brakes​
Service Brake Pedal Assembly​
Floor Plate Removal​
Reassemble in reverse order.​
Accelerator Pedal Assembly​
Steering Column/Dash Assembly​
Remove the Display Panel​
Display​
Key Switch​
Rocker (On/Off) Switches​
Steering Wheel​
Steering Column (Console)​
Steering Orbital Control Unit​
Direction Control Switch​
Horn​
Removing the Horn​
Replacing Hydraulic Tank​
Seat Switch​
Replacing the Switch and Cushion​
Overhead Guard, Lighting, and Alarms​
Back Up Alarms​
Drexel SLAC-2 Calibration Programming
Dashboard Truck Calibration​
Main Menu​
“No Run” Diagnostics​
“Run” Diagnostics​
Master Setup​
Traction Setup​
Pump Setup​
Clock Set​
Wire Guidance Calibration​
Error Codes​
Supplier Provided Documentation
Disclaimer:​
Duplex​
Lift Technologies Mast Service Manual​
Triplex​
