Hyundai
86
176,834
Landoll Drexel Forklift SL120-2 Parts Manual F-766-0222 2025
Brand: Landoll Drexel
Type of Machine: Forklift
Model: Landoll Drexel SL120-2 Forklift
Part Number: F-766-0222
Publication Date: 2025
Number of Pages: 176 Pages
Brakes
Brake Pedal and Lines​
Brake Pedal Assembly (BEFORE 10/01/2021)​
Brake Pedal Assembly (AFTER 10/01/2021)​
Drive Axle Brake Assembly​
Park Brake Components​
Covers and Doors
Covers and Doors​
Decals and Placards
Decal Placement​
Decal​
Electrical
Battery Connectors​
Control Panel - Cables​
Control Panel - Contactors​
Control Panel - Controllers​
Control Panel - Fuses​
Drive Motor​
E-Stop Button and Horn​
Heavy Cables / Battery Connections​
Crosshead Switch​
Wiring Diagram​
Hydraulics
Cylinder, Pivot​
Cylinder, Tilt​
Cylinder, Side Shift​
Hydraulic Valve Installation​
Hydraulic Valve​
Hydraulic Tank Installation​
Hydraulic Tank Assembly​
Hydraulic Pump​
Solenoid Valve Installation​
Steering Pump Installation (BEFORE 09/13/2019)​
Steering Pump Installation (AFTER 09/13/2019)​
Steering Pump Assembly (BEFORE 09/13/2019)​
Steering Pump Assembly (AFTER 09/13/2019)​
Hydraulic Pump Installation​
Hydraulic Pump Assembly​
Hydraulic Hose Installation​
Hydraulic Crosshead Hose Installation​
Side Shift Cylinder Installation​
Steer Axle Hydraulics​
Steering Column Hydraulic Hose Installation​
Steering Hydraulics​
Hydraulic Diagram​
Mast and Front End
Cam Bar/Splash Guard Installation​
Crosshead Attachments​
E-Chain Installation​
Fork Information​
Mast Information​
Lower Slide Bar Installation​
Mast Mount Bearing and Level Indicator​
Side Shift Assembly​
Splash Guard/Cam Bar Installation​
Swing Arm Assembly​
Tilt Cylinder Installation​
Operator’s Compartment
Battery Guide and Restraint​
Battery Options​
Floor Plate​
Lighting Options​
Mast Options​
Overhead Guard​
Seat Base​
Seat Assembly​
Steering Column Assembly​
Steering Column Installation​
Powertrain
Ground Straps​
Drive Assembly​
Drive Axle Installation​
Drive Axle Differential​
Drive Axle Hub Reduction​
Steer Axle Assembly​
Steer Axle Installation​
Options
EE Option​
EE Option​
Landguide​
Load Rest Option​
Load Rest Option​
Lighting Option​
Mast Options​
Options​
Tire Option​
Service Parts
Service Parts​
Glossary
Index
