Landoll Drexel Forklift R60i5 Operators Manual F-1029-0221
Brand: Landoll Drexel
Type of Machine: Forklift
Model: Landoll Drexel R60i5 Forklift
Part Number: F-1029-0221
Publication Date: 2021
Number of Pages: 116 Pages
Introduction
Introduction
Forklift Description
Receiving
Items Furnished With Your Forklift
Tools & Test Equipment
Preparing the Forklift
Inspecting the Forklift
Cleaning and Inspecting the Forklift
Storage/Shipping
Forklift Storage
Towing the Forklift
Landoll R60i5 Forklift Towing Instructions:
Lubrication Specifications
Torque Specifications
Fluid Capacities
General Torque Specifications (rev. 4/97)
UNC SAE Torque Specifications
UNF SAE Torque Specifications
SafetyGetting Started
Operator Training
Drexel Forklift Safety Statements
Understanding Safety Statements
Site Supervision
Terminology and Illustrations Used
Decal Locations
Operator Safety
Lock Out/Tag Out
Tipping
Speed
Liquefied Petroleum Gas Engine
Service Repair
Available Options
Fork Positioner
Fire Extinguisher
In case of a fire
Additional Publications
Vehicle FamiliarityOverview
Forklift Identification
Data Plate
Series Serial Number Code
Serial Number for Mast and Frame
Forklift Overview
Forklift Rated Capacity
Frame
Master Disconnect
Steering Column
Key Switch
Tilt Lever
Dash Display
Switch Panel
Joystick
Directional Control Switch
Return to Off
Horn
Traction
Features
Safety Interlock
Battery
Hydrostatic Drive
Auxiliary Pump Circuit
Steering
Hydraulic Fan
Filtration and Cooling
Mast Valve
Mast Controls
Mast Lift
Mast Tilt
Mast Side Shift
Mast Pivot
Mast Lift Assemblies
Mast Operation
Lift
Tilt
Side Shift
Pivot
Seat Adjustments
Seat Switch
Forks
Rated Capacity and Load Center
Fork Inspection
Fork Marking
Available Options
Lights and Alarms
Liquefied Petroleum Gas (LPG) Cylinder Options
Operator’s Compartment
Driver’s Controls
Foot Control Pedals
Hand Operated Levers
Joystick Controls
Rear View Mirror
Driver’s Seat
Steering Wheel
Steering Column
Switch Panel
Dash Display
Forks
Fork Inspection
Fork Marking
LP Gas EngineLiquefied Petroleum (LP) Gas Engine
Engine Care
Precautions for LP Gas Engines
Engine Coolant
Battery
Engine Oil
Checking Engine Oil
Air Filter
LPG Tank Removal
Refilling an LPG Tank
Installing an LPG Tank
Operating Your ForkliftOverview
Principles of Forklift Operation
Basic Operating Procedures
Getting On and Off the Forklift
Driving Position
Turning and Intersections
Stopping
Parking
Understanding Stability
Basic Principles
Tilting Considerations
Knowing the Rated Capacity
Counterweight
Determining the Load Weight
Center of Gravity
Load Center
Maximum Fork Lift Height
Tipping
Longitudinal Tipping
Lateral Tipping
Lateral or Longitudinal Tipping
Setting the Forks
Retrieving a Load
Handling a Load
Transporting a Load
Traveling on Inclines
Unloading the Forklift
Dock Boards and Forklifts
Workplace Conditions
Working in Hazardous Environments
Atmospheric/ Electrical
Chemical Hazards
Daily InspectionInspections Overview
Maintenance Schedule
Engine Compartment Access
Tires and Wheels
Inspection
Chunking (Chipping) or Embedded Objects
Undercutting and Uneven Wear
Flat-spotting
To Extend Tire Life
Lift Chains
Forks
Electrical Fastener Connections
Hydraulic Cylinders, Fittings and Hoses
Hydraulic Oil
Operator Controls
Tilt Control
Side Shift Control
Directional Control
Static Return to Off (SRO) Function
Steering
Steering Column Tilt and Telescope
Dash Display
Seat, Belt, Slides and Switch
Major Structural Points
Rust and Corrosion
Overhead Guard
Safety Decals
Data Plate
Unusual Noises
General Lubrication
Recommended Lubricants
Daily Checklist
Operator Daily Pre-Shift Inspection Checklist
- Bendi Landoll Forklift Series III Part & Operators, Maintenance Manual
- Drexel Landoll Forklift SLT22 SLT30 SLT35 Service & Part Maintenance Manual
- Bendi Landoll Forklift Bulletins & Misc Service Manual
- Bendi Forklift B30 B40 AC DS Maintenance Manual F-649-R0 2015
- Landoll Bendi Forklift Model B3-30 AC DS Parts Manual
- Drexel Landoll Forklift FL40-FL60 EX Service & Part Maintenance Manual
- Bendi Forklift Series IV Electrical Diagram, Service, Operators, Parts & Maintenance Manual 2004
- Landoll Bendi Forklift Model B40i4 Parts Manual
- Landoll Bendi Forklift 3 AC Serie Service Manual De
- Bendi Landoll Forklift B40-IC Tier II Part & Operators, Maintenance Manual
- Bendi Forklift B40 Series 4 Specification Manual
- Landoll Bendi Forklift Service Parts Manual CD
- Drexel Landoll Forklift SL30SE-SL40SE-SL50SE Service & Part Maintenance Manual
- Landoll Bendi Forklift 3 AC Serie Operator's Manual De
- Landoll Bendi Forklift 3 AC Serie Parts Manual
