Hyundai
86
176,834
Landoll Drexel Forklift R60i5 Maintenance Manual F-1030-2311
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Manual, Wiring Diagram
Model: Landoll Drexel R60i5 Forklift
Part Number: F-1030-2311
Publication Date: 2024
Number of Pages: 170 Pages
Introduction, Safety and Specifications
Introduction​
Operating Instructions​
Service Training​
Required Tools​
Replacement Parts​
Decal Identification​
General Maintenance Instructions​
Safety Guidelines​
Lockout/Tagout​
Battery Safety​
Hydraulic System​
Mast Service Safety​
Tilt Cylinder​
Lifting and Blocking the Forklift​
Towing the Forklift​
Landoll R60i5 Forklift Towing Instructions​
Specifications​
Lubrication Specifications​
Fluid Capacities​
Torque Specifications​
General Torque Specifications (rev. 4/97)​
Hydraulic Fitting Torque Specifications​
Inspection and Planned Maintenance
Overview​
Tools and Test Equipment​
Safety Equipment Required​
Inspection Program​
Maintenance Program​
Initial Inspection​
Daily Inspection Checklist​
Inspection and Maintenance Responsibilities​
Operators Daily Checklists​
Inspection Practices​
Inspection and Maintenance Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Completing Performance Testing​
Fuel System Check​
Operator Daily Pre-Shift Inspection Checklist - Drexel R60i5​
1st 100 Hour Technicians Inspection Checklist - Drexel R60i5​
250 Hour Technicians Inspection Checklist - Drexel R60i5​
500 Hour Technicians Inspection Checklist - Drexel R60i5​
1000 Hour Technicians Inspection Checklist - Drexel R60i5​
2000 Hour Technicians Inspection Checklist - Drexel R60i5​
4000 Hour Technicians Inspection Checklist - Drexel R60i5​
Tires​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat-spotting​
To Extend Tire Life​
Fork Inspection​
Rated Capacity and Load Center​
Cracks​
Straightness of Blade and Shank​
Fork Angle​
Difference in Height Between Fork Tips​
Positioning Lock​
Wear​
Fork Marking​
Measuring Fork Thickness and Distortion​
Major Structural Points​
Rust or Corrosion​
Overhead Guard​
Hydraulic System​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Hydraulic Fluid​
Changing Hydraulic Fluid​
Hydrostatic Filter​
Power Steering System​
Check Engine Oil Level​
Adding Engine Oil​
Changing the Engine Oil and Filter​
Battery​
Data Plate and Safety Warning Decals​
Seat​
Seat Adjustments​
Seat Belt​
Seat Switch​
Parking Brake​
Electrical​
Key Switch​
Dash Display​
Accelerator Pedal, Directional Switch & Backup Alarm​
Horn​
Joystick​
Lights​
Mast Controls​
Lift​
Tilt Control​
Side Shift​
Pivot Controls​
Mast Maintenance​
Load Roller Maintenance​
Chain Maintenance​
Mast Rollers/Sheaves​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Mast Racking​
Pivot Arm Racking​
Sideshift Cylinder​
Checking for Leaks​
Forklift Lubrication​
Mast Lubrication​
Tilt Cylinder Clevis​
Steering Knob Lubrication​
Main Rotation Bearings​
Crosshead Lubrication​
Grease Steering Axle​
Steer Axle​
Wheel Bearings​
Nuts, Bolts and Screws​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Hydraulic Problems​
Audible Problems​
Electrical Problems​
Visible Problems​
Wiring Diagram​
Wiring Schematic​
Corrective Maintenance
Overview​
Replacement Parts​
Maintenance Area​
Operator Compartment​
Floor Plate Removal​
Replacing Accelerator Pedal​
Park Brake Assembly​
Checking the Park Brake Efficiency​
Steering Column/Dash Assembly​
Replacing Steering Wheel​
Remove the Dash Display​
Replace Key Switch​
Rocker (On/Off) Switches​
Steering Column Removal​
Hydraulics​
Steering Orbital Control Unit Removal​
Tilt Cylinder Removal​
Pivot Cylinder Removal​
Control Valve Removal​
Cyclone Reservoir Removal​
Hydraulic Reservoir Removal​
Checking and/or Adjusting Pressure​
Forks​
Fork Removal​
Repairing Forks​
Load Testing Forks​
Hydraulic Diagram​
Hydraulic Diagram​
Mast and Front Load Assembly​
Mast Removal​
Racking Adjustment​
Tilt Cylinder Adjustment​
Pivot Arm Removal​
Pivot Cylinder Adjustment​
Engine​
Engine Identification​
Cylinder Numbers / Firing Order​
Spark Plugs​
Ignition Coils​
Engine Maintenance Check List​
Engine Removal​
Electrical​
Joystick​
Battery Removal and Installation​
Adjust Alternator Belt​
Alternator Removal​
Starter Removal​
Oil Pressure Sensor Replacement​
Oxygen Sensor Removal​
Hydrostat or Pump Mount Removal​
Vaporizer Removal​
Fuse Panel and Fuses Location​
Module Removal​
Spark Plug Replacement​
Lights​
Master Disconnect Switch Removal​
Wiring Diagram​
Cooling System​
Vaporizer Hoses Replacement​
Radiator Hoses Replacement​
Radiator Removal​
Steering Axle​
Steering Axle Removal​
Disassembling and Inspecting Steering Axle Mounting Blocks​
Checking Wheel Bearings​
Disassembling and Inspecting Wheel Bearings​
Assembling Wheel Bearings​
Disassembling Steering Axle​
Axle Installation​
Drive Motors​
Check Drive Motor​
Drive Motor Removal​
Safety Features​
Horn​
Horn Removal​
Backup Alarm Removal​
Replacing the Seat Switch and Cushion​
Calibration
Forklift Controller “Plus+1” Calibration and Programming​
Getting Started Using Plus+1 Software​
Plus+1 Software​
ECU Downloading and Type​
Plus+1 Service Tool Components​
Layout​
Calibration​
Speed​
Electrical Design Current (EDC)​
Engine​
Joystick​
Mast Valve​
Temperature​
Lights​
Dash Displays
Dash Display Calibration and Operation​
Splash Screen​
Clock Display​
Coolant Temperature​
Work Hours​
To Start Engine​
Service Engine Soon (SES)​
To Enable Drive​
Service Engine Immediately​
Icons Displayed​
Seat​
Park Brake​
Engine Warning​
Battery Warning​
Engine Pressure​
High Pressure Filter​
Drive Oil Level​
Drive Oil Temperature​
Engine Coolant Temperature​
Forward Drive​
Neutral Drive​
Reverse Drive​
Direction Fault​
Faults​
Function Icons​
Faults Preview Screen​
To Unlock​
Menu Access Screen​
Navigation Menu​
Calibration​
Diagnostics​
Drive Inputs.​
Drive Outputs.​
Valve Coils.​
Faults​
Faults - Vehicle​
Faults - Engine​
Clock​
Engine and Fuel
Disclaimer​
Kubota​
Kubota WG2503 E3 2.5L LPG Engine Manual, F-1117-0521​
Kubota WG1605-E3 Diagnosis Manual, F-1121-0921​
Supplier Provided Documentation
Disclaimer​
Duplex​
Lift Technologies Mast Service Manual​
Triplex​
Cascade Corporation​
