Hyundai
86
176,834
Landoll Drexel Forklift FL40 AC EX FL60 AC EX Maintenance Manual F-748-R1
Brand: Landoll Drexel
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Drexel FL40 AC EX, FL60 AC EX Forklift
Part Number: F-748-R1
Publication Date: 2016
Number of Pages: 214 Pages
Introduction, Safety, and Specifications
Introduction​
Operating Instructions​
Service Training​
Tools Needed​
Replacement Parts​
General Maintenance Instructions​
For Your Safety​
LockOut/TagOut​
Battery Safety Rules​
Hydraulic System​
Cleaning & Inspecting the Forklift​
Towing the Forklift​
General Safety Tips:​
Towing Vehicle Requirements​
Towing a Forklift in the Reverse Direction​
Battery Removal and Installation​
Good Battery Care Recommendations:​
Hydraulic System​
Lifting and Blocking the Forklift​
Prior to Tilt Cylinder Repair​
Mast Service Precautions​
Mast Removal​
Lubrication Specifications​
Torque Specifications​
Fluid Capacities​
Inspections and Preventative Maintenance
Inspection Introduction​
Inspection Checklists​
Operator Daily Pre-Shift Inspection Checklist​
1st 100 Hour Technicians Inspection Checklist​
500 Hour Technicians Inspection Checklist​
1000 Hour Technician Inspection Checklist​
2000 Hour Technician Inspection Checklist​
4500 Hour Technician Inspection Checklist​
Preventative Maintenance Requirements​
Tools or Equipment Required​
Preparing for Inspection or Maintenance​
Performance Testing​
Daily Inspection​
Inspect Tires​
Parking Brake​
Brake System Service​
Parking Brake​
Check Lift Operation​
Fork Inspection​
Rated Capacity and Load Center​
Cracks​
Fork Angle​
Wear​
Measuring Fork Thickness and Distortion​
Checking Hydraulic Oil Level​
Check Hydraulic Functions​
Power Steering System​
Seat Switch​
Battery Discharge Indicator (BDI)​
Battery​
Using a Hydrometer​
Charging a Wet Cell Battery​
Battery Restraints System (Slide out Option Only)​
Safety Warnings​
Seat Belt​
Major Structural Points​
Rust or Corrosion​
Overhead Guard​
1st 50 Hours​
Mast Chains​
Gearbox​
Servicing the Gearbox​
500 Hour Inspection​
General Mast Inspection​
Check Tilt Cylinder Racking​
Tilt Cylinder Racking and Tilt Degree Settings​
Tilt Degree Adjustment​
Accelerator/Direction Control​
Mast Operation​
Mast Racking​
Mast Lubrication​
Mast Chain Adjustment​
500 HR Inspection and Maintenance​
Forklift Lubrication​
Hydraulic Filter​
2000 Hour Inspection​
Planetary Gearbox​
Steer Axle​
Major Bolt Connections​
Check Primary Lift Chain​
4500 Hour Inspection​
Changing Hydraulic Fluid​
Troubleshooting and Corrective Maintenance
Preliminary Procedures​
Troubleshooting Charts​
Frayed or broken control wires.​
WARNING​
Corrective Maintenance​
Mast and Front Plate Assemblies​
Forks​
Mast Assembly​
Removing the Tilt Cylinder​
Checking and/or Adjusting Pressure​
Drive System​
Removing Drive Wheels​
Gearbox and Traction Drive Motor​
Motor Compartment Lid Removal​
Removing the Drive Motor​
Installation of the Drive Motor​
Parking Brake​
Parking Brake​
Park Brake Service​
Hydraulic Motor​
Hydraulic Pump Motor​
Replacing Hydraulic Pump​
Hydraulic Pump Drive Shaft​
Replacing Hydraulic Filter​
Hydraulic Control Valve Assembly​
Checking Main Hydraulic Pressure​
Replacing the Hydraulic Control Valve​
Accelerator/Brake Pedal Service​
Accelerator/Brake Pedal Replacement​
Steering Wheel Replacement​
Steering Wheel Removal​
Steering Column Replacement​
Steering Orbital Replacement​
Direction Control/Horn Button​
Flashing Strobe Light​
Back-Up Alarm/Horn Replacement​
Replacing the Gearbox​
Steering Axle Assembly​
Removing Rear Axle​
Disassembling and inspecting Rear Axle Mounting Blocks​
Checking Steer Wheels​
Disassembly of Wheel Hub​
Reassembly of Wheel Hub​
Disassembly of Steering Knuckle​
Reassembly of Steering Knuckle​
Removal of Steer Cylinder​
Installation of Steer Cylinder​
Axle Installation​
Hydraulic Fittings and Hoses​
Controller Enclosure
Control Enclosure​
Theory of Operation​
Power Management​
Fuses​
Contactors, BDI, Horn Control Card, 36-24V DC-DC Converter​
Controllers​
Intrinsically Safe Barriers​
Full Free Lift 2-Stage Mast
MD35D/40D/50D/55D/55ND/60D​
Full Free Lift 3-Stage Mast
MT30D/35D/40D/50D/55ND/60D​
