Hyundai
86
176,834
Landoll Bendi Forklift B40VAC AC Series 6 Parts Manual F-1088-0323
Brand: Landoll Bendi
Type of Machine: Forklift
Model: Landoll Bendi B40VAC AC Series 6 Forklift
Part Number: F-1088-0323
Publication Date: 2023
Number of Pages: 166 Pages
Brakes
Brakes Installation​
Brake Pedal Installation​
Brake Pedal Assembly​
Covers and Counterweights
Battery Door​
Battery Disconnect Cover​
Counterweights​
Covers​
Decals and Placards
Decal Placement​
Decals​
Placards​
Electrical
Controller - Interface​
Control Panel Installation​
Control Panel Assembly​
Emergency Stop Button​
Fans​
Heavy Cables​
Horn and Steering Sensor​
Lighting Options​
Pump Motor Installation​
Wire Harness Trays​
Pump Motor​
Reverse Alarm​
Valve Harness​
Electrical Diagram​
Hydraulics
Hydraulic System Diagram​
Filter Installation​
Filter Assembly​
Lift Components​
Pump​
Steering Hydraulics​
Hydraulic Tank Components​
Tilt Components (B40VAC)​
Tilt Cylinder (B40VAC)​
Valve Installation​
Valve Spool Assembly​
Front Rotation and Mast
Fork Information​
Mast Information​
Front Plate Assembly - Installation (BEFORE 04/22/2022)​
Front Plate Assembly - Installation (AFTER 04/22/2022)​
Front Plate Assembly​
Load Backrest​
Mast Installation​
Tilt Cylinder Installation (AFTER 08/09/2022)​
Operator’s Compartment
Accelerator Pedal Assembly​
Control Levers​
Lift Lever Assembly​
Overhead Guard Installation​
Seat Base / Battery Cover​
Seat Assembly​
Steering Column and Orbital Installation​
Steering Column Assembly (BEFORE 07/07/2022)​
Steering Column Assembly (AFTER 07/07/2022)​
Powertrain
Axle Installation​
Drive Motor and Gear Box​
Drive Motor Assembly​
Drive Wheels and Tires​
Load Wheels​
Options - Battery Compartment
Battery Guides Installation​
Battery Tray, Roll Out and Slide Out Installation​
Battery Tray, Lift Out​
Battery Tray, Roll Out​
Battery Tray, Slide Out​
Battery Restraint Assembly​
Fast Charging Components​
Options
Options​
Fire Extinguishers​
Windshield and Cab Enclosures​
Operator’s Fan​
Seat Options​
Heated Seat Option​
Service Parts
Service Parts​
Glossary
Index
