Hyundai
86
176,834
Landoll Bendi Forklift B40-50AC Series 6 Parts Manual F-1084-2306
Brand: Landoll Bendi
Type of Machine: Forklift
Model: Landoll Bendi B40-50AC Series 6 Forklift
Applicable to B40HL, B40LF, B40DR, B50HL, B50DR
Part Number: F-1084-2306
Publication Date: 2023
Number of Pages: 190 Pages
Brakes
Brakes Installation​
Brake Caliper Assembly​
Brake Lines​
Brake Pedal Installation​
Parking Brake Caliper Assembly​
Brake Pedal Assembly​
Parking Brake Installation​
Covers and Counterweights
Battery Door​
Battery Disconnect Cover​
Counterweights​
Covers​
Decals and Placards
Decal Placement​
Decals​
Placards​
Electrical
Controller - Interface​
Control Panel Installation​
Control Panel Assembly - Before 06/03/2019​
Control Panel Assembly - After 06/03/2019​
Emergency Stop Button​
Fans​
Heavy Cables​
Horn and Steering Sensor​
Lighting Options​
Pump Motor Installation​
Wire Harness Trays​
Pump Motor​
Reverse Alarm​
Valve Harness​
Electrical Diagram​
Hydraulics
Hydraulic System Diagram​
Filter Installation​
Filter Assembly​
Lift Components​
Pump​
Steering Hydraulics​
Hydraulic Tank Components​
Tilt Components​
Valve Installation​
Valve Spool Assembly​
Front Rotation and Mast
Fork Information​
Mast Information​
Axle Installation​
Front Plate Assembly - Installation​
Front Plate Assembly (Before 02/05/2020)​
Front Plate Assembly (After 02/05/2020)​
Load Backrest​
Mast Installation (B40HL, B50HL)​
Mast Installation (B40DR, B50DR)​
Operator’s Compartment
Accelerator Pedal Assembly​
Control Levers​
Lift Lever Assembly​
Two Function Control Lever​
Overhead Guard Installation​
Seat Base / Battery Cover​
Seat Assembly​
Steering Column and Orbital Installation​
Steering Column Assembly​
Steering Column Assembly (AFTER 07/07/2022)​
Powertrain
Drive Motor and Gear Box​
Drive Motor Assembly​
Gearbox Assembly, RR USA Planetary 29.3:1 (BEFORE 05/01/2019)​
Gearbox Assembly, RR USA Planetary 29.3:1 Ground Gear (AFTER 02/03/2021)​
Drive Wheels and Tires (B40HL, B40DR)​
Drive Wheels and Tires (B50HL, B50DR)​
Load Wheels​
Options - Battery Compartment
Battery Guides Installation​
Battery Tray, Roll Out and Slide Out Installation​
Battery Tray, Lift Out​
Battery Tray, Roll Out​
Battery Tray, Slide Out​
Battery Restraint Assembly​
Fast Charging Components​
Options
Options​
Fire Extinguishers​
Windshield and Cab Enclosures​
Operator’s Fan​
Landview​
Overhead Guard with Door and Mesh​
Seat Options​
Heated Seat Option​
Service Parts
Service Parts​
Glossary
Index
