Hyundai
86
176,834
Landoll Bendi Forklift B3-30 AC Series 5 Operators Manual F-898-0119
Brand: Landoll Bendi
Type of Machine: Forklift
Model: Landoll Bendi B3/30 AC Series 5 Forklift
Part Number: F-898-0119
Publication Date: 2014
Number of Pages: 90 Pages
Introduction
Vehicle Description​
Included with the Bendi B3-30 AC:​
Receiving​
Items Furnished With Your Forklift​
Items Required​
Tools & Test Equipment​
Preparing the Forklift​
Inspecting the Forklift​
Towing the Forklift​
Lubrication Specifications​
Safety
Getting Started​
Operator Training​
Bendi Forklift Safety Statements​
Understanding Safety Statements​
Site Supervision​
Terminology and Illustrations Used​
Decals​
Operator Safety​
Tipping​
Speed​
Battery Safety​
Charging Safety​
Hydraulic System​
Service Repair​
Available Options​
Fork Positioner​
Fire Extinguisher​
In Case of a Fire​
Additional Publications​
Vehicle Familiarity
Overview​
Forklift Identification​
Data Plate​
Series Serial Number Code​
Forklift Familiarity​
Frame​
Major Structural Points​
Brake System​
Brake Pedal​
Braking by Plugging​
Parking Brake​
Check the Brake Fluid Level​
Electrical System​
Traction​
Steering System​
Accelerator Pedal​
Steering Column​
Key Switch​
Steering Wheel and Tilt Clamp Lever​
Dash​
Operator Switches​
Dash Display​
Tires and Wheels​
Inspection​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat Spotting​
To Extend Tire Life​
Emergency Stop​
Directional Control Switch​
Static Return to Off​
Horn​
Hydraulic System​
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Check Hydraulic Fluid Level​
Mast Controls​
Mast Assemblies​
Mast Operation​
Lift Lever​
Tilt Lever​
Sideshift Lever​
Seat​
Seat Adjustments​
Seat Switch​
Seat Belt​
Forks​
Rated Capacity and Load Center​
Fork Inspection​
Fork Marking​
Available Options​
Cold Storage (Freezer Package)​
Lights and Alarms​
Battery
Battery Inspection​
Checking Battery Acid/Electrolyte Level​
Checking Specific Gravity​
Removing the Battery​
Battery Roll Out and Restraint System​
Roll Out Battery Removal​
Roll Out Battery Installation​
Charging the Battery​
Charging Procedure​
Operating Your Bendi
Overview​
Principles of Forklift Operation​
Basic Operating Procedures​
Getting On and Off the Forklift​
Driving Position​
Proper Seating Position and Travel Procedure​
Turning and Intersections​
Stopping​
Stopping Distance​
Parking​
Faults​
Diagnostics​
Understanding Stability​
Basic Principles​
Knowing the Rated Capacity​
Counterweight​
Determining the Load Weight​
Center of Gravity​
Load Center​
Maximum Fork Lift Height​
Tilting Considerations​
Tipping​
Longitudinal Tipping​
Lateral Tipping​
Lateral or Longitudinal Tipping​
Setting the Forks​
Fork Positioner​
Retrieving a Load​
Transporting a Load​
Traveling on Inclines​
Unloading The Forklift​
Dockboards and Forklifts​
Attachments​
Workplace Conditions​
Working in Hazardous Environments​
Daily Inspection
Inspections Overview​
Maintenance Schedule​
Daily Checklist​
Operator Daily Pre-Shift Inspection Checklist​
