Hyundai
86
176,834
Landoll Bendi Forklift B3-30 AC Series 5 Maintenance Manual F-985-0219
Brand: Landoll Bendi
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Bendi B3/30 AC Series 5 Forklift
Part Number: F-985-0219
Publication Date: 2024
Number of Pages: 130 Pages
Introduction, Safety, and Specifications
Getting Started
Introduction​
Operating Instructions​
Service Training​
Required Tools​
Decal Identification
Replacement Parts
General Maintenance Instructions
Lockout/Tagout
Battery Safety
Charging Safety​
Tilt Cylinder​
Mast Service Safety​
Lifting and Blocking the Forklift
Emergency STOP
Towing the Forklift
Specifications
Lubrication Specifications​
Torque Specifications​
Fluid Capacities​
General Torque Specifications (rev. 4/97)
UNC SAE Torque Specifications​
UNF SAE Torque Specifications​
Metric Torque Specifications:
Metric Torque Specifications​
Hydraulic Fitting Torque Specifications
37 degree JIC, ORS, and ORB​
Parker® Brand Fittings​
Aeroquip® Brand Fittings​
Gates® Brand Fittings​
Planned Inspection and Maintenance
Overview
Cleaning and Inspecting the Forklift
Tools and Equipment Required​
Safety Equipment Required​
Inspection Program
Maintenance Program
Inspection and Maintenance Responsibilities
Operators Daily Checklists​
Inspection Practices​
Inspection and Maintenance Practices for Authorized Facilities ONLY​
Preparing for Inspection or Maintenance​
Performance Testing​
Completing Performance Testing​
Operator Daily Pre-Shift Inspection Checklist - Bendi B3-30 AC/DS Series 5
1st 100 Hour Technicians Inspection Checklist - Bendi B3-30 AC/DS Series 5
500 Hour Technicians Inspection Checklist - Bendi B3-30 AC/DS Series 5
2000 Hour Technician Inspection Checklist - Bendi B3-30 AC/DS Series 5
4500 Hour Technician Inspection Checklist - Bendi B3-30 AC/DS Series 5
Tires and Wheels​
Chunking (Chipping) or Embedded Objects​
Undercutting and Uneven Wear​
Flat-spotting​
To Extend Tire Life​
ESD Strap​
Fork Inspection
Rated Capacity and Load Center​
Cracks​
Positioning Lock​
Wear​
Fork Marking​
Overhead Guard
Hydraulic Cylinders and Valves​
Hydraulic Hoses, Tubing and Fittings​
Check Hydraulic Fluid Level​
Battery
Checking the Battery​
Using a Hydrometer​
Specific Gravity Correction​
Check Fluid Level​
Battery Restraint System and Roll-out (Optional)​
Check the Brake Fluid Level
Identification Plate and Safety Warning Decals
Seat Adjustments
Seat Adjustment​
Rake Adjustment​
Seat Belt
Electrical Connections
Key Switch
Dash Display
Accelerator Pedal, Directional Switch & Backup Alarm
Service Brakes
Seat Switch
Horn
Mast Controls
Lift​
Tilt Control​
Side Shift​
Mast Racking​
Lights
Speed Switch
Steering - Check Operation
Emergency STOP
Return to Neutral
General Mast Inspection
Mast Chains​
Chain Inspection​
Chain Lubrication​
Chain Adjustment​
Check Primary Lift Chain​
Measuring Chain Stretch​
Check Lift Operation​
Load Backrest​
Front Plate​
Check Tilt Cylinder​
Side Shift Cylinder​
Checking for Leaks​
Forklift Lubrication
Tilt Cylinder Clevis​
Fork Positioner Lubrication (Option)​
Steering Knob Lubrication​
Hydraulics
Change the Pressure Filter​
Checking and Adjusting Hydraulic Pressure​
Change Hydraulic Fluid​
Service Disc Brakes
Wheel Bearings
Major Structural Points
Rust Or Corrosion​
Gearbox
Check Planetary Gearbox​
Nuts, Bolts and Screws
Stop Block
Troubleshooting
General Bendi B3-30 AC/DS Troubleshooting Charts
AUDIBLE PROBLEMS​
PERFORMANCE PROBLEMS​
PUMP PROBLEMS​
Corrective Maintenance
Battery
Battery Storage​
Battery Roll-out Option and Restraint System​
Roll-out Battery Tray Option​
Replacing the Battery​
To Replace a Battery:​
Removal:​
Installation:​
Cleaning the Battery​
When properly maintained, the battery will remain relatively clean and dry. Occasionally it may be necessary to remove excessive electrolyte. If this happens, remove the battery from the truck and clean with a solution of baking soda and water. (one ...​
Charging a Wet Battery​
Mast And Front End
Removing the Forks​
Repairing Forks​
Load Testing Forks​
Straightness of Blade and Shank​
Fork Angle​
Difference in Height Between Fork Tips​
Measuring Fork Thickness and Distortion​
Adjusting Degree of Tilt​
Mast Removal​
Removing Front Plate Assembly​
Removing the Tilt Cylinder​
Floor Plate
Floor Plate Removal and Assembly​
Tires and Wheels
Removing/Replacing the Drive Wheel​
Disassembling and Inspecting Rear Wheel Bearings​
Replacing the Braking Tires​
Assembling Rear Wheel Bearings​
Brake System Service​
Check Service Drum Brakes​
Checking/Changing Brake Shoes​
Repairing Brake Wheel Cylinders​
Hydraulic Brake Drums​
Measure Brake Drum Diameter​
Replacing Brake Drum Assemblies​
Parking Brake Assembly​
Parking Brake Lever​
Replacing Parking Brake Lever Assembly​
Checking Parking Brake Adjustment​
Adjusting Parking Brake Cable​
Replacing the Parking Brake Cable​
Parking Brake Switch​
Checking Parking Brake Switch​
Replacing Parking Brake Switch​
Service Brakes
Brake Pedal Assembly​
Brake Pedal​
Service Brake Linkage​
Service Brake Switch​
Master Cylinder
Replacing Master Cylinder​
Bench Bleed the Master Cylinder​
Check Master Cylinder Fluid Level​
Bleeding Brakes​
Service Brake Pedal Assembly​
Replacing Any Other Hydraulic Brake Component​
Drivetrain
Traction Motor, and Gear Box​
Service the Gear Box​
Gearbox Replacement​
Traction Drive Motor Service​
Accelerator Pedal
Replacing Accelerator Module​
Electrical
Fuses​
Electrical Static Discharge​
Electrical Controls and Levers​
Replacing Levers​
Replacing a Complete Control Panel​
Hydraulic Components
Hydraulic System Maintenance​
Changing Hydraulic Fluid​
Change the Hydraulic Fluid Filters​
Steering Motor Service​
Load Sense Steering System​
Power Steering System Maintenance​
Hydraulic Pump Service​
Replacing the Hydraulic Pump and Motor​
Front Rotation Assembly​
Removing the Steering Actuator​
Steer (Front Rotation) Sensor​
To Center the Steer Sensor​
To Adjust and/or Replace the Steer Sensor​
Hydraulic Control Valve Assembly​
General​
Hydraulic Control Valve and Switches Removal​
Spool Section Rebuild​
Hydraulic Lift Sensor​
Hydraulic Fittings and Hoses​
Check Hydraulic Functions​
Steering Column/Dash Assembly
Remove the Display Panel​
Key Switch​
Rocker (On/Off) Switches​
Steering Wheel Removal​
Steering Column (Console) Removal​
Steering Orbital Control Unit​
Horn Service​
Removing the horn​
Truck Lighting​
Headlights​
Brake and Tail Lights​
Back Up Alarms​
Overhead Guard, Lighting and Alarms​
Seat Switch Replacement
Replacing the Switch and Cable​
Bendi B3/30 AC Calibration and Programming
Controller Theory of Operation
1314 Bendi B3/30 Controller Software Program Installation and Operation
Software Installation Procedure
1314 Software Features and Functionality
Menu​
Tool Bar​
Views Navigation Bar​
Working Area​
Status Bar​
Communicating with the Bendi B3-30 Series 5 Controllers
Bendi B3-30 Series 5 Parameters​
Programming Bendi B3-30 Series 5 Controllers​
Programming Bendi B3-30 Series 5 Traction and Pump Controllers
Programming Bendi B3-30 Series 5 Front I/O Modules
Curtis Controller Troubleshooting
Program Troubleshooting Chart
Master Controller
Program
Landoll Traction​
Multimode Functions​
Hour Meter​
Maintenance Due​
1- Speed Mode​
Response​
Fine Tuning​
Current Limits​
Battery​
Monitor
Landoll​
Deep Reach/Hi-Lift​
Learned Throttle and Brake Parameters​
1356 I/O Module​
1356 Valve Module​
Inputs​
Outputs​
Battery​
Motor​
Controller​
Cutbacks​
Vehicle​
CAN Status​
Controller Maintenance
Controller Cleaning
Supplier Provided Documentation
Lift Technologies Mast Service Manual
