Hyundai
86
176,834
Landoll Bendi Forklift B3-30 AC Maintenance Manual F-560-0410
Brand: Landoll Bendi
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Bendi B3/30 AC Forklift
Part Number: F-560-0410
Publication Date: 2010
Number of Pages: 174 Pages
Introduction, Safety & Planned Maintenance
Before You Begin (Please Read)​
Introduction​
Operating Instructions​
Service Training​
Tools Needed​
Replacement Parts​
General Maintenance Instructions​
For your Safety​
Lock Out/Tag Out​
Battery Care and Charging​
Battery Removal and Installation​
Hydraulic System​
Towing the Truck​
General Safety Tips:​
Towing Vehicle Requirements​
Towing a Truck in the Reverse Direction​
Lifting and Blocking the Truck​
Mast Service Precautions​
Disconnecting the Tilt Cylinder​
Mast Removal​
Cleaning the Truck​
Maintenance Introduction​
Inspection Sheets​
Lubrication Specifications​
Torque Specifications​
Fluid Capacities​
General Torque Specifications (R 4/97)​
Torque Specified in Foot Pounds​
Hydraulic Fitting Torque Specifications​
Hydraulic Fittings Torque Specified​
General Bendi AC Troubleshooting Chart​
Tires, Brakes and Drivetrain
Floor Plate​
Floor Plate Removal and Assembly​
Visual Inspection​
Replacing the Drive Tire​
Disassembling and Inspecting Rear Wheel Bearings​
Replacing the Braking Tires​
Assembling Rear Wheel Bearings​
Brake System​
Brake System Service​
Check Service Drum Brakes​
Repairing Brake Wheel Cylinders​
Hydraulic Brake Drums​
Measure Brake Drum Diameter​
Replacing Brake Drum Assemblies​
Parking Brake Assembly​
Parking Brake Lever​
Replacing Parking Brake Lever Assembly​
Parking Brake Switch​
Replacing Parking Brake Switch​
Replacing the Parking Brake Cable​
Brake Pedal Assembly​
Master Cylinder​
Replacing Master Cylinder​
Bench Bleed the Master Cylinder​
Check Master Cylinder Fluid Level​
Bleeding Brakes​
Service Brake Pedal Assembly​
Traction Motor, and Gear Box​
Removing the Drive Wheel​
Checking Drive Wheel Gearbox​
Servicing the Drive Train Assembly​
Gearbox Replacement​
Traction Drive Motor Service​
Accelerator Pedal​
Adjusting Accelerator Pedal​
Hydraulic Oil, Motors, Pumps, and Cylinders
Hydraulic Components​
Hydraulic System Maintenance​
Check Hydraulic Oil Level​
Changing Hydraulic Oil​
Change the Hydraulic Oil Filter​
Checking and Adjusting Hydraulic Pressure​
Steering Motor Service​
Load Sense Steering System​
Power Steering System Maintenance​
Check Power Steering​
Filling and Air Bleeding the Power Steering System​
Steer Motor Maintenance​
Parts Disassembly and Inspection​
Hydraulic Pump Service​
Replacing the Hydraulic Pump and Motor​
Hydraulic Steer Motor Replacement​
Checking Steer Pump Pressure​
Hydraulic Control Valve Assembly​
General​
Hydraulic Control Valve and Switches Removal​
Spool Section Rebuild​
Hydraulic Lift Sensor​
Hydraulic Fittings and Hoses​
Check Hydraulic Functions​
Steering Column/Dash Assembly​
Remove the Display Panel​
Key Switch​
Rocker (On/Off) Switches​
Steering Wheel Removal​
Steering Column (Console) Removal​
Steering Orbital Control Unit​
Electrical Contactors​
Batteries - Care and Replacement​
Checking Batteries​
Battery Care​
Charging the Battery​
Battery Removal​
Battery Installation​
Electrical Static Discharge​
Electrical Controls and Levers​
Direction Control Lever​
Check the Return-to-Neutral​
Replacing a Complete Control Panel​
Horn Service​
Seat Assembly​
Seat Switch​
Check Driver’s Seat Switch​
Truck Lighting​
Headlights​
Brake and Tail Lights​
Back Up Alarms​
Overhead Guard, Lighting and Alarms​
Side Shift Circuit Maintenance​
Check Side Shift Circuit Performance​
Steering Potentiometer Replacement​
Fuses​
ESD Strap​
Bendi B3/30 AC Calibration and Programming
Controller Theory of Operation​
1314 Bendi AC Controller Software Program Installation and Operation​
1314 Installati on Procedur e​
1314 Update Proced ure​
Communicatin g with Bendi AC Controllers​
Additiona l 1314 Controlle r Features​
Controller Fault History​
Landoll_TM_S Parameters​
Landoll_P_S Parameters​
CURTIS CONTROLLER TROUBLESHOOTING​
Controller Maintenance​
Controller Cleaning​
PROGRAMMER MENUS​
Truck Lubrication and Chain Maintenance
Lubricating the Truck​
Tilt Cylinder Clevis​
Main Rotation Bearings​
Fork Positioner Lubrication, Non-Side Shifting (Option)​
Chain Lubrication​
Chain Adjustment​
Measuring Chain Stretch​
Check Primary Lift Chain​
Check Lift Operation​
Checking and Adjusting Degree of Tilt​
Removing the Tilt Cylinders​
Removing the Mast From Truck​
Supplier Provided Documentation
Lift Technologies Mast Service Manual​
Models 30D/35D/40D/50D/55D/60D​
Table of Contents - page 5​
