Hyundai
86
176,834
Landoll Bendi Forklift AC Series 6 Maintenance Manual F-857-0119
Brand: Landoll Bendi
Type of Machine: Forklift
Type of Manual: Maintenance Manual
Model: Landoll Bendi AC Series 6 Forklift
Applicable to B30 AC, B40 AC, B40 VNA, B40 HL, B40 AC-DR, B55 AC, B50 HL, B50 AC-DR
Part Number: F-857-0119
Publication Date: 2021
Number of Pages: 144 Pages
Introduction, Safety, and Specifications
Before You Begin​
Introduction​
Operating Instructions​
Service Training​
Required Tools​
Models Covered*​
Decal Identification​
Replacement Parts​
General Maintenance Instructions​
Safety Guidelines​
Lock Out/Tag Out​
Battery Safety​
Charging Safety​
Hydraulic System​
Lifting and Blocking the Forklift​
Tilt Cylinder Repair​
Mast Service Precautions​
Emergency STOP​
Towing the Forklift​
Specifications​
Lubrication Specifications​
Torque Specifications​
Fluid Capacities​
General Torque Specifications (rev. 4/97)​
UNC SAE Torque Specifications​
UNF SAE Torque Specifications​
Metric Torque Specifications​
Hydraulic Fitting Torque Specifications (REV. 10/97)​
Parker® Brand Fittings​
Aeroquip® Brand Fittings​
Gates® Brand Fittings​
Inspections
Inspection Introduction​
Initial Inspection​
Items Furnished with the Forklift​
Items Required​
Tools and Test Equipment​
To Prepare the Forklift​
Daily Inspection Checklist​
Operator Daily Pre-Shift Inspection Checklist - Bendi Series 6​
Daily Inspections​
Safety Warnings and Manual​
Data Plate​
Wheels and Tires​
ESD Straps​
Parking Brake​
Service Brakes​
Check the Brake Fluid Level​
Forks​
Mast Racking​
Hydraulic Oil​
Hydraulic Cylinders, Hoses, and Fittings​
Battery​
Specific Gravity Correction​
Battery Restraint System​
Operator Controls​
Seat​
Scheduled Maintenance
Scheduled Inspections and Maintenance Requirements​
Tools and Equipment Required​
Cleaning and Inspecting the Forklift​
Inspection and/or Maintenance​
Performance Testing​
1st 100 Hours or 2 Week Checklist​
Mast Chains​
Measuring Chain Stretch​
Check Primary Lift Chain​
Check Lift Operation​
Load Backrest​
Wheels and Tires​
Hydraulic Oil Check​
Steering Actuator​
Front Plate​
Planetary Gear Box​
500 Hour or Monthly Inspections​
Hydraulic Maintenance​
Battery​
Controllers and Wire Connections.​
Steering​
Brakes​
Wheels and Tires​
Motors and Gearboxes​
General Mast Inspection​
Forks​
Major Structural Points​
Rust Or Corrosion​
Overhead Guard​
Forklift Lubrication​
Tilt Cylinder Fixed End Bearing​
Fork Positioner Lubrication (Option)​
2000 Hour or Yearly Inspections​
Brake Fluid Change​
Change Planetary Gear Box Oil​
4500 Hour Inspection​
Hydraulic Oil Change​
1st 100 Hour Technicians Inspection Checklist - Bendi Series 6​
500 Hour Technicians Inspection Checklist - Bendi Series 6​
2000 Hour Technician Inspection Checklist - Bendi Series 6​
4500 Hour Technician Inspection Checklist - Bendi Series 6​
Troubleshooting
Preliminary Procedures​
Troubleshooting Charts​
Visual Problems​
Audible Problems​
Hydraulic Problems​
Brake Problems​
Electrical Problems​
Troubleshooting Codes​
Corrective Maintenance
Corrective Maintenance​
Battery​
Replacing the Battery​
Charging a Wet Cell Battery​
Battery Restraint System and Roll-out Option​
Mast and Front End​
Removing the Forks​
Repairing Forks​
Load Testing Forks​
Mast Removal​
Removing Front Plate Assembly​
Removing the Tilt Cylinder​
Floor Plate Removal​
Tires​
Tire Inspection​
Extending Tire Life​
Brakes​
General Information​
Check Service Disc Brakes​
Required Tools​
Disc Brake Rotors​
Parking Brake System​
Parking Brake Assembly​
Parking Brake Lever​
Checking the Parking Brake Switch​
Replacing Parking Brake Switch​
Replacing the Parking Brake Cable​
Parking Brake Caliper Assembly​
Changing Parking Brake Pads or Replacing Parking Brake Caliper​
Brake Pedal​
Replacing the Rotary Pot​
Brake Hydraulics​
Replacing Master Cylinder​
Bench Bleed the Master Cylinder​
Check Master Cylinder Fluid Level​
Bleeding Brakes​
Replacing Any Other Hydraulic Brake Component​
Electrical​
Electrical Static Discharge​
ESD Strap​
Direction Control Switch​
Check the Return-to-Neutral​
High Current Connections Definition​
Hydraulics​
Check Hydraulic Functions​
Hydraulic Oil​
Hydraulic System Components​
Replacing the Hydraulic Pump and Motor​
Hydraulic Control Valve Assembly​
Hydraulic Control Valve and Switches Removal​
Hydraulic Lift Spool Sensor​
Hydraulic Fittings and Hoses​
Side Shift Circuit​
Steering​
Steering Wheel Removal​
Steering Column (Console) Removal​
Steering Orbital Control Unit​
Front Rotation Assembly​
Removing the Steering Actuator​
Steer (Front Rotation) Sensor​
Steering Column and Dash Display Assembly​
Powertrain​
Inspecting the Drive System​
Rear Wheel Assembly​
Replacing the Gear Box​
Replacing the Traction Drive Motor​
Load Axle​
Accelerator Pedal Assembly​
Safety Features​
Horn Service​
Replacing the Seat Switch and Cable​
Seat Switch​
Overhead Guard, Lighting and Alarms​
Fuses​
Calibration and Programming
Dash Display Key Legend​
Dash Display Parameters​
Forklift Calibration​
1314 Software Program Installation and Operation​
Software Installation Procedure​
1314 Software Features and Functionality​
Main Features​
Communicating with Bendi Series 6 Controllers​
Programming the Bendi Series 6 Controllers​
Programming the Bendi Series 6 Master, Pump and Slave Controllers​
Truck Type Setup​
Programming Bendi Series 6​
Front and Valve I/O Modules​
Master Controller​
Program​
Truck Selection 1-B30, 2-B40, 3-B40VNA, 4-B5X​
Landoll Traction​
Hour Meter​
Maintenance Due​
1- Speed Mode​
Response​
Fine Tuning​
Current Limits​
Battery​
Monitor​
Landoll​
Inputs​
Outputs​
Battery​
Motor​
Controller​
Vehicle​
CAN Status​
Supplier Documents
Lift Technologies Mast Service Manual​
