Landini Tractor Trekker4 4-085 To 4-120 F-M (CP05) Operators Manual 6696772A2 2022
Brand: Landini
Model: Landini Trekker4 Series Tractor
4-085 F ; 4-095 F ; 4-105 F ; 4-110 F ; 4-120 F
4-085 M ; 4-095 M ; 4-105 M ; 4-110 M ; 4-120 M
Engine:
Deutz-AG TCD 2.9 L4 HT Engine - 4-085 Tractor
Deutz-AG TCD 2.9 L4 Hp Engine - 4-095 ; 4-105 ; 4-110 ; 4-120 Tractor
Part Number: 6696772A2
Publication Date: 2022
Number of Pages: 310 Pages
Section 1 Contents
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty Service
Safety
Section 2 Safety Notes
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Caution And Warning
Safety - Decals
Safety - Follow A Safety Program
Safety - Frame
Safety - Cab
Safety Precautions
Personal Protective Equipment (Ppe)
Check Your Equipment
Cleaning The Tractor
Save The Environment
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor
Working In Safety
Watch Out For Other People
Risk Of Overturning
To Avoid Overturning Sideways
To Avoid Overturning Backwards
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Safety - After Use
Highway Code Regulations
Further Notes
Tractor Lifting Points
Tractor Access
Cab Emergency Exit
Fuel Tank Filling
Risks From Noise
Positions Of The Safety Decals
Section 3 Controls - Cab
Main Instruments And Controls
Controls On The Left Side Of The Driver's Seat
Controls On The Right Side Of The Driver's Seat
Controls On The Right Side Of The Turret
Ignition Switch
Led And Backlighting Functions On Switches
Tractor Warning Lamps Operation
Slow Moving Vehicle (Smv) Symbol
Controls On The Left Side Of The Control Turret
Battery Cut-Off Switch
Pedal Controls
Tool Box
Electric Sockets
Operator's Seat
Seat Belt
Operator Present Sensor
Cab Roof Components
Controls On Cab Roof Left Side
Controls On Cab Roof Right Side
Air Conditioner Control
Rear Wiper
Cab Ventilation
Cab Temperature Controls
Set-Up With Heating Only
Additional Cab Functions
Cab Rear Window
Sunshade
Radio
Section 4 Instruments And Programming
Buttons
Display Operation
Operating Menu
Parameter Changes
Alarm Management Priority Display
Main Display
Clock/Work Timer
Service Interval
Seat Sensor Alarm (Operator Presence)
Counters
Calibrations
Engine Control Unit Menu
Dpf Filter Regeneration
Brightness Adjustment Of Screen, Lamps And Indicators
Constant Engine Rate
Alarms
Transmission Display Area
Power Take-Off Menu
Accessories Menu
Implement Width
Euro/Nao Sales Market
Clock
Service Interval
Functionality (Indicator Lights/Indicators/Displays On Lcd)
Pressure In Trailer Air Brake Circuit
Selected Pto Speed Rate
Operator Presence Management
Section 5 Operation
General Operation
Before Starting The Engine
Recommendations For Running In
Run In Procedure
Operation
Starting Procedure
Tractor Start-Up
Stopping The Tractor
Engine Stopping
Running In
Cold Temperature Operation
Engine Block Coolant Heater (If Equipped)
Engine Oil Sump Heater (Option At Your Dealer's)
Fuel Heater (Option At Your Dealer's)
Cold Weather Starting (Cold Engine)
Turning Off The Engine
Parking The Tractor
Engine Clutch
Gearbox
Gearbox With Shuttle And Creeper
Speed Tables (Gearbox With Shuttle And Creeper)
Gearbox With Shuttle And Overdrive
Stopping And Parking The Tractor
Rear Pto
Independent Power Take-Off
Steering-Brake Clutches
Hand Brake
Stationary
Constant Engine Rate (Engine Set Point)
Tractor Transport
Road Pads
Transport By Truck Or Rail
Tow Equipment - Front Pull Hook
Drawbar
Rear Hitch (Mechanical Control)
Els (Ergonomic Lift System) (If Equipped)
Sensitivity Adjustment
Top Link Of Rear Hitch
Auxiliary Control Valves
Operation Of The Rear Control Valves
Use Of The Rear Mechanical Control Valves
Free Discharge
Single/Double Acting Selection (Mechanical Control Valves)
Flow Diverter
Front Quick Couplers
Quick Couplings
Connection Of Rear Hoses
Disconnecting Hoses And Implements
Rear Three-Point Hitch
Implement Hitching Device
Three-Point Linkage
Lower Links Adjustment
Rops Frame
Section 6 Ballast
Front Ballast Weights
Assembly Of Front Ballast
Section 7 Maintenance
Routine Maintenance Table
Recommendations Before You Service
Environment
Diesel Engine Catalytic Converter
Anti-Particulate Filter (Dpf)
Regeneration
Power Drop
Overrun Of The Power Drop
Plastic And Resin Parts
Safety Precautions
Sealed Units
Diesel Anti-Particulate Filter Replacement
Running In
How To Prevent Pollution
Engine Cooling System
Lubrication
General Tractor Inspection
Refuelling The Tractor
Fuel Tank Filling
Engine Oil Specifications
Change Intervals For Lubricant Oil
Viscosity
Winter Operation With Diesel Fuel
Quality Of The Water
Protective Agent For The Cooling System
Adblue® (Urea Solution Aus 32)
Access For Inspection And Maintenance
Variable Maintenance (Every 10 Hours Or Daily)
Check Level In The Adblue® Or Def Reservoir (If Equipped)
General Maintenance
Air Conditioning System
General Maintenance
Fire Prevention
Troubleshooting
Section 8 Electric System
Electric System - Battery
Battery System Servicing
Beams
Bulb Replacement
Fuses And Relays
Pdu Box Fuses
Adblue™ Or Def Circuit Relay
Main Relays And Fuses
Cab Roof Fuses
7-Pin Power Socket For Trailer
Auxiliary Power Socket
Diagnostic Sockets
Section 9 Specifications - Alphabetical Index
Weights And Dimensions
Electric System
Clutch
Clutch
Gearbox
Power Take-Off
Brakes
Track Frames - Suspensions - Tracks
Front Ballast
Hydraulic Hitch
Three-Point Linkage
Towing Attachments
Supplementary Applications
Radio Technical Specifications
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Implement Attachment Points
Alphabetical Index
Regulation (Eu) No.167/ 2013 To Latest Amendment 2019/519
Brand: Landini
Engine:
Section 1 Contents
Introduction
Warranty Claim
Spare Parts Warning
If You Move
Safety
Safety - Decals
Safety - Frame
Safety - Cab
Safety Precautions
Working In Safety
Working In Safety
Risk Of Overturning
Road Transport
Safety - After Use
Further Notes
Tractor Access
Cab Emergency Exit
Fuel Tank Filling
Risks From Noise
Ignition Switch
Pedal Controls
Tool Box
Electric Sockets
Operator's Seat
Seat Belt
Cab Roof Components
Rear Wiper
Cab Ventilation
Cab Rear Window
Sunshade
Radio
Buttons
Display Operation
Operating Menu
Parameter Changes
Main Display
Clock/Work Timer
Service Interval
Counters
Calibrations
Alarms
Power Take-Off Menu
Accessories Menu
Implement Width
Clock
Service Interval
Section 5 Operation
General Operation
Run In Procedure
Operation
Starting Procedure
Tractor Start-Up
Engine Stopping
Running In
Parking The Tractor
Engine Clutch
Gearbox
Rear Pto
Hand Brake
Stationary
Tractor Transport
Road Pads
Drawbar
Free Discharge
Flow Diverter
Quick Couplings
Three-Point Linkage
Rops Frame
Section 6 Ballast
Environment
Regeneration
Power Drop
Safety Precautions
Sealed Units
Running In
Lubrication
Fuel Tank Filling
Viscosity
General Maintenance
General Maintenance
Fire Prevention
Troubleshooting
Beams
Bulb Replacement
Fuses And Relays
Pdu Box Fuses
Cab Roof Fuses
Diagnostic Sockets
Electric System
Clutch
Clutch
Gearbox
Power Take-Off
Brakes
Front Ballast
Hydraulic Hitch
Three-Point Linkage
Towing Attachments
Noise Levels
Vibration Levels
Weights
Alphabetical Index
- Landini Tractor 105,115,130,145,165 Service Manual
- Landini 8860 Parts Catalog
- Landini 9880 Parts Catalog
- Landini 8500 Accessories And Application Miscellaneous Parts Catalog
- Landini 105,115,130,145,165 Service Manual
- Landini 7860 Parts Catalog
- Landini 14500 Accessories And Application Miscellaneous Parts Catalog
- Landini 6500 Accessories And Application Miscellaneous Parts Catalog
- Landini Power_Farm_95 Parts Catalog
- Landini 6880 Parts Catalog
- Landini Mistral_55 Parts Catalog
- Landini 105 115 130 145 165 Service Manual
- Landini 8830 Accessories And Application Miscellaneous Parts Catalog
- Landini 7880 Parts Catalog
- Landini Tractor Legend 105 - 165 Training Manual and Wiring Diagram
