Landini Tractor Trekker 4-105 To 4-110 FM (CP04) Operators Manual 6621074A4 2021
Brand: Landini
Model: Landini Tractor
Trekker 4-105 STD ; Trekker 4-115 STD
Trekker 4-085 F/M ; Trekker 4-095 F/M
Trekker 4-105 F/M ; Trekker 4-110 F/M
Engine:
Deutz C4DT69 Engine - Trekker 4-105 STD
Deutz C4DT74 Engine - Trekker 4-115 STD
Deutz 2.9 TCD L4 Stage 5 Engine - Trekker 4-085 F/M
Deutz 2.9 TCD L4 Engine - Trekker 4-095 ; 4-105 ; 4-110 F/M
Part Number: 6621074A4
Publication Date: 2021
Number of Pages: 290 Pages
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty Service
Safety
Safety Notes
Regular Use
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Warning And Caution
Safety - Decals
Safety - Following A Safety Program
Safety - Cab
Safety Precautions
Personal Protection Devices (Dpi)
Check Your Equipment
Cleaning The Tractor
Save The Environment
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor.
Working In Safety
Beware Of Other People
Risk Of Overturning
To Avoid Side Overturning
To Avoid Back Overturning
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Highway Code Regulations
Safety - After Use
Further Notes
Tractor's Lifting Points
Tractor Access
Fuel Tank Filling
Risks From Noise
Positions Of The Safety Decals
Controls - Cab
Main Instruments And Controls
Controls On The Left Side Of The Driver's Seat
Controls On The Right Side Of The Driver's Seat
Controls On The Right Side Of The Turret
Ignition Switch
Led And Backlighting Functions On Switches
Tractor Warning Lamp Usage
Slow Moving Vehicle (Smv) Symbol
Controls On The Left Side Of The Control Turret
Battery Master Disconnect Switch
Pedal Controls
Miscellaneous
• Tool Box
• Electric Sockets
Operator's Seat
Seat Belt
Operator Present Sensor
Central Controls On Control Turret
Rear Window Wiper
Cab Roof Components
Controls For Cab Temperature
Setup With Heating Only
Radio
Additional Cab Features
Instruments And Programming
Instruments - Instrument Panel
Display Operation
Alarm Management Priority Display
Main Display
Clock/Work Timer
Service Interval
Alarm From Operator Present Sensor On Seat
Counters
Calibrations
Engine Controller Menu
Dpf Filter Regeneration
Adjustment Of Screen, Lamps And Indicators Brightness
Constant Engine Rpm Rate
Alarms
Transmission Display Area
Power Take-Off Menu
Accessories Menu
• Implement Width
• Euro/Nao Market
• Clock
• Service Interval
• Functionality (Indicator Lights/Indicators/Display On Lcd)
• Management Of Operator Present Control
Operation
General Operation
Run In Procedure
Starting Procedure
Tractor Start-Up
Stopping The Tractor
Engine Stopping
Running In
Cold Temperature Operation
Cold Weather Starting (Under 0°C) (Cold Engine)
Turning Off The Engine
Parking The Tractor
Gearshift Clutch
Gearbox
• Gearbox With Reverse Shuttle And Creeper
•• Speed Tables (Gearbox With Reverse Shuttle And Creeper)
• Gearbox With Reverse Shuttle And Overdrive
•• Speed Tables (Gearbox With Reverse Shuttle And Overdrive)
Stopping And Parking The Tractor
Power Take-Off
• Power Take-Off Engagement / Disengagement
• Pto Speed Selection
• Independent Power Take-Off
Steering-Brake Clutches
Stationary
Engine Set Point
Tractor Transport
• Road Pads
Tow Equipment - Front Pull Hook
Drawbar
• Drawbar Positions
Rear Hitch
• Sensitivity Adjustment
• Top Link Of The Rear Hitch
Auxiliary Control Valves
• F/M Versions
• Free Discharge (Per F/M Versions)
• For Std Versions
Quick Couplers
• Connecting Rear Hoses
• Disconnecting Hoses And Implements
Rear Three-Point Hitch
• Implement Hitching Device
• Three-Point Linkage
• Lower Links Adjustment
Roll-Over Safety Frame - F/M Setups
Ballast
Regular Service Intervals
Routine Maintenance Table
Recommendations Before You Service
Lubrication And Maintenance
Running In
Servicing Intervals
Miscellaneous Checks
Lubrication/Greasing
General Tractor Inspection
Fuel Tank Filling
Engine Oil Specifications
Approved Fuels
Protective Agent For The Cooling System
Access For Inspection And Maintenance
Variable Maintenance (Every 10 Hours Or Daily)
Cab Filter - Variable Maintenance
General Maintenance
Preparing For Long Idle Periods
Fire Prevention
Electric System
Electric System - Battery
Battery System Servicing
Beams
Bulb Replacement
Fuses And Relays
7-Pin Power Socket For Trailer
Auxiliary Power Socket
Diagnostic Connectors
Specifications
Weights And Dimensions
Electric System
Clutch
Power Take-Off
Steering Clutches
Brakes
Track Frames - Suspensions - Tracks
Front Ballast Weights
Hydraulic Hitch
Three-Point Linkage
Towing Attachments
Fuses
Optional Extras
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Alphabetical Index
Regulation (Eu) N. 167/2013
Air Conditioner
Ballast
Battery
Beams
Cleaning
Controls - Cab
Decal Positions, Weo Countries
Dpf
Dpf Filter Regeneration,
Drawbar
Electric System
Engine, Starting And Stopping
Equipment, Check
Fuel
Fuses And Relays
How To Transport The Tractor
Indicator Lights
Instrument Cluster
Instrument Panel
Instruments
Lights, Replacement
Lubricants
Maintenance
Maintenance At Request, Overview Of
Operation
Parking The Tractor
Power Take-Off, Precautions
Precautions
Pre-Delivery Claims
Protection From Noise
Protective Clothing
Radio
Risk Of Overturning
Risks From Noise
Road Transport
Rops Frame
Running In
Running In
Running In Of Tractor
Running In, Recommendations
Safety
Safety
Safety - Cab
Safety Decal Locations - All Markets
Safety Frame
Safety Notes
Safety, Working In Safety
Safe Use Of The Tractor
Seat Belt
Specifications
Starting Procedure
Starting The Tractor
Stationary
Stationary Button
Stationary, Tractor
Stopping The Engine
Systems, Checks
Technical Specifications
Temperature, Controls In The Cab
Tractor Transport
Tractor, Turning Off The Engine
Use Of The Tractor
Use Of The Tractor On Public Roads
Warning And Caution
Warranty
Working In Safety
Brand: Landini
Engine:
Introduction
Warranty Claim
Spare Parts Warning
If You Move
Safety
Safety Notes
Regular Use
Safety - Decals
Safety - Cab
Safety Precautions
Working In Safety
Working In Safety
Risk Of Overturning
Road Transport
Safety - After Use
Further Notes
Tractor Access
Fuel Tank Filling
Risks From Noise
Controls - Cab
Ignition Switch
Pedal Controls
Miscellaneous
• Tool Box
• Electric Sockets
Operator's Seat
Seat Belt
Rear Window Wiper
Cab Roof Components
Radio
Display Operation
Main Display
Clock/Work Timer
Service Interval
Counters
Calibrations
Alarms
Power Take-Off Menu
Accessories Menu
• Implement Width
• Euro/Nao Market
• Clock
• Service Interval
Operation
General Operation
Run In Procedure
Starting Procedure
Tractor Start-Up
Engine Stopping
Running In
Parking The Tractor
Gearshift Clutch
Gearbox
Power Take-Off
Stationary
Engine Set Point
Tractor Transport
• Road Pads
Drawbar
• Drawbar Positions
Rear Hitch
• F/M Versions
• For Std Versions
Quick Couplers
Ballast
Running In
Servicing Intervals
Fuel Tank Filling
Approved Fuels
General Maintenance
Fire Prevention
Electric System
Beams
Bulb Replacement
Fuses And Relays
Specifications
Electric System
Clutch
Power Take-Off
Steering Clutches
Brakes
Hydraulic Hitch
Three-Point Linkage
Towing Attachments
Fuses
Optional Extras
Noise Levels
Vibration Levels
Weights
Alphabetical Index
Air Conditioner
Ballast
Battery
Beams
Cleaning
Controls - Cab
Dpf
Drawbar
Electric System
Equipment, Check
Fuel
Fuses And Relays
Indicator Lights
Instrument Cluster
Instrument Panel
Instruments
Lights, Replacement
Lubricants
Maintenance
Operation
Parking The Tractor
Precautions
Pre-Delivery Claims
Protective Clothing
Radio
Risk Of Overturning
Risks From Noise
Road Transport
Rops Frame
Running In
Running In
Safety
Safety
Safety - Cab
Safety Frame
Safety Notes
Seat Belt
Specifications
Starting Procedure
Stationary
Stationary Button
Stationary, Tractor
Stopping The Engine
Systems, Checks
Tractor Transport
Use Of The Tractor
Warning And Caution
Warranty
Working In Safety
- Landini Tractor 105,115,130,145,165 Service Manual
- Landini 8860 Parts Catalog
- Landini 9880 Parts Catalog
- Landini 8500 Accessories And Application Miscellaneous Parts Catalog
- Landini 105,115,130,145,165 Service Manual
- Landini 7860 Parts Catalog
- Landini 14500 Accessories And Application Miscellaneous Parts Catalog
- Landini 6500 Accessories And Application Miscellaneous Parts Catalog
- Landini Power_Farm_95 Parts Catalog
- Landini 6880 Parts Catalog
- Landini Mistral_55 Parts Catalog
- Landini 105 115 130 145 165 Service Manual
- Landini 8830 Accessories And Application Miscellaneous Parts Catalog
- Landini 7880 Parts Catalog
- Landini Tractor Legend 105 - 165 Training Manual and Wiring Diagram
