118
6,911
Landini Tractor Series 6H 6-125H 6-135H (RS2C) Service Manual 6727101A1 2023
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini Series 6H 6-125H ; 6-135H Tractor
Engine: FPT F36 Engine
Part Number: 6727101A1
Publication Date: 2023
Number of Pages: 3080 Pages
Series 6H
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
1001 - Safety
Introduction
Technical Notes
Maintain The Tractor In A Safe Way
Danger Signs
Tightening Torques
1500 - Specific Equipment Catalogue
Specific Equipment
2000 - Engine
Technical Specifications
Annexes
2002 - Exhaust Gas Treatment System
Safety
Ats System
Adblue®
3004 - Other Tanks
Adblue® Fluid Tank
3005 - Fuel Tank
4001 - Electric System
Safety
Fuses And Relays
Component Sheets
Wiring Harnesses Locations
Wiring Diagrams
4002 - Instrument Cluster Set-Up And Calibrations
Calibration From The Instrument Cluster
Calibrations With The Diagnostic Tool
5000 - Steering System - Operation
Description
Operation
6000 - Transmission
Description
Section Drawings
6001 - Engine - Transmission Coupling
Operation
6002 - Engine-Gearbox Assembly
Operation
Sections And Perspective Views
6006 - Gearbox
Operation
6012 - Rear Differential
Operation
6014 - Four-Wheel Drive
Operation
6015 - Rear Final Drives
Operation
6019 - Rear Pto
Operation
6021 - Front Axle
Operation
6025 - Front Power Take-Off
Operation
7000 - Brakes - Operation
Description
Hydraulic Trailer Brake
Distribution Valve
Trailer Air Brakes
7003 - Brakes Inspections And Adjustments
Safety
Brakes
Diagnostic Tests Of The Air Brake System
“Pick-Up Hitch”
8000 - Hydraulic Circuit - Operation
Iso And Functional Diagrams
Hydraulic Pumps
Hydraulic Power Packs
Suspended Axle
Rear Hydraulic Control Valves
Midmount Control Valves
Transmission Breather And Oil Filling
8001 - Troubleshooting For The Hydraulic System
Safety
Fault Diagnostics
Hydraulic System Diagnostic Testing
8005 - Front Hitch
Front Hitch
8007 - Rear Hitch
Rear Hitch
9004 - Air Conditioning System
Safety
Description And Operation
System Servicing
Pressure Tests
Diagnostics And Troubleshooting
9005 - Operator Seat
Safety
Description
Annexes
10000 - Diagnostics
Can Bus System
Can Error Handling
Instrument Cluster Control Unit Ec1
Transmission Control Unit Ec4
Engine Control Unit Ec6
Hitch Control Unit Ec9
Satellite Autoguide Monitor X25 Ec31
Trailer Braking Control Unit Ec35
Telematics Control Unit Ec41
Suspended Axle And Isobus Control Unit Ec43
11000 - Disassembly Procedures
Safety
Front Hitch And Pto
Bonnet
Tanks
Four-Wheel Shaft
Front Axle
Steering Column
Power Steering
Gearbox
Rear Differential
Rear Power Take-Off, 2 Speeds
Rear Power Take-Off, 4 Speeds
Rear Final Drives
Annexes
Engine Manual
Operator Seat Manual
