118
6,911
Landini Tractor Series 6 Robo-Six (RP6D) Service Manual 6723716A2 2024
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini Series 6 Robo-Six Tractor
6-135 Robo-Six ; 6-145 Robo-Six ; 6-155 Robo-Six
Engine: FPT NEF 45 Engine
Part Number: 6723716A2
Publication Date: 2024
Number of Pages: 3818 Pages
Serie 6 Robo-Six
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
1001 - Safety
Introduction
Technical Notes
Maintain The Tractor In A Safe Way
Hazard Symbols
Tightening Torques
1500 - Specific Equipment Catalogue
Specific Equipment
2000 - Engine
Technical Data
Annexes
2002 - Exhaust Gas Treatment System
Technical Data
Safety
Ats System
Adblue®
Ats Management
3005 - Tank
Fuel Tank Components
Adblue® Tank Components
4001 - Electrical System
Technical Data
Safety
Fuses And Relays
Operator's Interface Overview
Sockets Overview
Light Overview
Location Of Components
Location Of Wiring Harnesses
Wiring Diagrams
4002 - Instrument Cluster Setup And Calibrations
Calibrations Via The Instrument Cluster
Suspended Axle Calibration
Calibrations With The Diagnostic Tool
5000 - Steering System - Operation
Power Steering
Description Of The Hydraulic Circuit
6000 - Transmission - Operation
“Powershift” Assembly
Shuttle Assembly
Gearbox
Four-Wheel Drive
Bevel Gear And Differential
Rear Final Drives
Rear Pto
7000 - Brakes - Operation
Brake Circuit
Trailer Power Brake
Distribution Valve
Trailer Air Brakes
7003 - Check And Adjustments
Safety
Brakes
Diagnostic Tests Of The Air System
“Pick-Up Hitch”
8000 - Hydraulic System - Operation
Technical Specifications
Hydraulic Pumps
Hydraulic Blocks
Priority Valve
Power Steering
Hydraulic Trailer Braking
Rear Control Valves
Suspended Axle
Front Hitch
Midmount Control Valve
Rear Hydraulic Unions
Transmission Breather And Oil Filling
8001 - Troubleshooting Hydraulic System
Safety
Technical Data
Trouble-Shooting Diagnosis
Hydraulic System Diagnostic Tests
9000 - Cab
Technical Data
Air Conditioning System
Compressor
Condenser
Evaporator
Air Conditioning Pressure Switch
Mixed Air Temperature Sensor With Automatic A/C Only
Cab External Temperature Sensor With Automatic A/C Only
Cab Inside Temperature Sensor With Automatic A/C Only
Solar Sensor With Automatic A/C Only
Automatic A/C Control Panel
Manual A/C Control Panel
9004 - Air Conditioning System
Safety
System Servicing
Pressure Tests
Diagnostics And Troubleshooting
9005 - Operator's Seat
Safety
Description
Annexes
10000 - Control Units Alarm Diagnostics
Can Bus System
Error Handling Via Can
Instrument Cluster Control Unit Ec1
Transmission Control Unit Ec4
Engine Control Unit Ec6
Hitch And Light Management Control Unit Ec9
Suspended Axle Control Unit Ec10
Armrest Control Unit Ec15
Midmount Valves Control Unit Ec16
Ec17 Air Conditioning Control Unit
Tecu Isobus Control Unit Ec24
Gps Antenna Ec27
Electronic Power Steering Control Unit Ec28
Satellite Guidance Monitor X25 Ec31
Trailer Braking Control Unit Ec35
Telematics Control Unit Ec41
10010 - Programming Diag4 Control Units
Technical Data
Connection Of “Diag4 Argotractors” Electronic Diagnostic Tool To The Tractor
Software Updating Procedure Of Dsm Monitor
11000 - Disassembly Procedures
Safety
Preliminary Operations
Tanks
Steering Column
Front Hitch And Front Pto
Front Axle
Shuttle Assembly
Range Assembly
Rear Hitch
Rear Pto
Creeper Unit (If Fitted)
4wd Unit
Rear Final Drives
Annexes
Engine Manual
Front Axle Manual
Operator’s Seat Manual
