Landini Tractor Series 5-5HC 5-100 5-110 5-120 (RS2B) Service Manual 6703065A2 2024
118
6,911
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini Series 5-5HC 5-100 ; 5-110 ; 5-120 Tractor
Engine: FPT F36 Engine
Part Number: 6703065A2
Publication Date: 2024
Number of Pages: 2966 Pages
Serie 5 - 5HC
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
1001 - Safety
Foreword
Technical Notes
Maintain The Tractor Safely
Danger Signs
Tightening Torques
1500 - Specific Equipment Catalogue
Specific Equipment
Equipment For Mechanical Components
Equipment For Hydraulic Components
2000 - Engine
Technical Specifications
Annexes
2002 - Exhaust Gas Treatment System
Safety
Ats System
Regeneration Strategies
3004 - Other Tanks
3005 - Fuel Tank
Fuel Tank Components With Guard
4001 - Electrical System
Introduction
Safety
Fuses And Relays
Component Location
Wiring Harnesses Locations
Information On Wiring Diagrams
Electrical Diagrams - Version Dynamic
Electrical Diagrams - Version Active
4002 - Instrument Cluster Setup And Calibrations
General Instrument Cluster Specifications
Calibrations By The Instrument Cluster
Rear Power Take-Off Calibration
Calibration With The Diagnostic Tool
5000 - Steering - Operation
Power Steering
Description Of The Hydraulic Circuit
6000 - Transmission
- Operation
Description And Operation
Section Views
6001 - Engine - Transmission Coupling
Section And Exploded Views
Clutch Levers Adjustment Procedure
Pto Clutch Lever Adjustment
(Version With Mechanical Reverse Shuttle)
Clutch Pedal Adjustment
6002 - Engine-Gearbox Assembly
Section Views And Operation
6006 - Gearbox And Ranges
Section Views
Gearbox
Speed Ranges
6007 - Robotized Gearbox
Robotized "Roboshift" Gearbox
6012 - Rear Differential
Bevel Gear Unit And Differential
Rear Differential Section View
Rear Differential Exploded View
6014 - Four-Wheel Drive
Four-Wheel Drive
6015 - Rear Final Drives
Operation
Section Views
6019 - Rear Power Take-Off
Section And Perspective Views
Rear Pto
6021 - Front Axle
Front Axle - Setup Without Brakes
Front Axle - Setup With Brakes
Suspended Front Axle
7000 - Brakes
- Operation
Description
Front Brakes (Optional)
Rear Brakes
Bleeding Air From The Brake Circuit (Without Trailer)
7001 - Pedal Brakes
Pedal Brakes
Braking With One Pedal Only
Simultaneous Braking With Latched Pedals
Brake Pedals Travel Check
7002 - Parking Brake
Park Lock
Parking Brake Test And Adjustment
7004 - Brakes - Trailer Braking System
Hydraulic Braking System
Air Braking System
8000 - Hydraulic System
- Operation
Filters Of The Hydraulic System
Power Steering Control Valve
Solenoid Valves Pack For Uses Controls
Hydraulic Shuttle Solenoid Valves Pack
Hydraulic Shuttle Solenoid Valves Pack With Hml
Rear Pto Solenoid Valves Pack
Rear Control Valves
Mechanically Controlled Rear Hydraulic Hitch
Electronically Controlled Rear Hydraulic Hitch
Suspended Axle Control Solenoid Valves Pack
Trailer Brake Control Valve
Midmount Control Valve
Iso Hydraulic Diagrams
Functional Hydraulic Diagrams
8001 - Troubleshooting
Hydraulic System Diagnostic Tests
Diagnosis And Troubleshooting
8005 - Front Hitch
Sections And Perspective Views
Exploded Views
Hydraulic Circuit Of The Hitch
8007 - Rear Hitch
Safety
Procedures
9004 - Air Conditioning System
9005 - Operator’s Seat
Safety
Annexes
10000 - Control Units Alarm Diagnostics
Can Bus System
Can Error Handling
Instrument Cluster Control Unit Ec1
Transmission Control Unit Ec4 - Without Robotized Gearbox
Robotized Gearbox Transmission Control Unit Ec4-Rs
Engine Control Unit Ec6
Hitch Control Unit Ec9
Telematics Control Unit Ec41
Isobus And Suspended Axle Control Unit Ec43
Robotized Gearbox Control Unit Ec44
“Smartpilot” Joystick Ec45
11000 - Disassembly Procedures
Front Axle
Bonnet
Adblue Tank
Steering Column And Power Steering System
Four-Wheel Drive
Rear Differential
Engine-Transmission Assembly With Hydraulic Reverse Shuttle
Engine-Gearbox Assembly With Hydraulic Reverse Shuttle And Hml
Engine-Gearbox Assembly With Mechanical Reverse Shuttle
Gearbox
Robotized Gearbox
Rear Power Take-Offwith Electro-Hydraulic Engagement
Rear Power Take-Off With Mechanical Engagement
Rear Power Take-Off With Electro-Hydraulic Engagement And Hml
Rear Final Drives
Front Hitch And Power Take-Off
Rear Hitch
Annexes
Engine Workshop Manual
Operator Seat Manual
