118
6,911
Landini Tractor Series 5 5-085 (RS57) Operators Manual 6674379A3 2024
Brand: Landini
Model: Landini 5-085 Tractor
Engine: FPT F34 Stage V Engine
Part Number: 6674379A3
Publication Date: 2024
Number of Pages: 436 Pages
Section 1 Contents
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty Service
Safety
Section 2 Safety Notes
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Warning And Caution
Safety - Decals
Safety - Following A Safety Program
Safety - Cab
Safety Precautions
Personal Protection Equipment (Ppe)
Cleaning The Tractor
Save The Environment
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor.
Working In Safety
Beware Of Other People
Risk Of Overturning
To Avoid Side Overturning
To Avoid Back Overturning
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Highway Code Regulations
Safety - After Use
Further Notes
Tractor Stability
Tractor's Lifting Points
Tractor Access
Fuel Tank Filling
Wedges
Risks From Noise
Prevention Against Burns
Hazardous Substances
Positions Of The Safety Decals
Positions Of The Safety Decals - Epa Markets
Section 3 Controls - Cab
General Layout Of Controls
Main Instruments And Controls (Set-Up With Mechanical Hitch)
Main Controls (Set-Up With Electronic Lift)
Main Controls And Monitoring Instruments (Set-Up With Robotic Transmission)
Controls Installed Under Cushion
Joystick Controls
Controls On The Left Side Of The Driver's Seat
Controls On The Left Side Of The Control Turret
Led And Backlighting Functions On Switches
Reverse Shuttle Lever
Mechanical Hitch Controls
Tractor Warning Lamps Operation
Implement Warning Lamps (If Equipped)
Rotating Beacon
Slow Moving Vehicle (Smv) Symbol
Right Controls On Instrument Turret
Adjustment Of Electro-Hydraulic Reverse Shuttle Effectiveness
Battery Master Disconnect Switch
Steering Column Adjustment
Power Socket
Miscellaneous
External Controls On Fenders
Service Usb Connection
Cigarette Lighter Socket
Operator's Seat
Seat Belt
Instructor Seat
Operator Present Sensor
Central Controls On Control Turret
Rear Window Wiper
Cab Roof Components
Cab Ventilation
Front Windscreen Demisting/Defrosting
Controls For Cab Temperature
Set-Up With Cab Air Conditioning
Use Of The Air Conditioning System
Radio
Additional Cab Features
Mirror Adjustment
Section 4 Instruments And Programming
Instrument Panel
Display Operation
Alarm Management Priority Display
Main Display
Clock/Work Timer
Rear Electronic Hitch
Engagement/Disengagement Threshold Of Auto Pto
Setup Of Limits For Auto Pto Engagement/Disengagement.
Service Interval
Alarm From Operator Present Sensor On Seat
Air Brakes Pressure
Counters
Calibrations
Engine Controller Menu
Dpf Filter Regeneration
Adjustment Of Screen, Lamps And Indicators Brightness
Constant Engine Rpm Rate
Selection Of Rear Pto Engagement Curve
Selection Of Front Pto Engagement Curve
Aps
Alarms
Transmission Display Area
Accessories Menu
Implement Width
Power Take-Off Type
Sales Market Euro/Epa
Clock
Service Interval
Remote Diagnostics (If Available)
Functionality (Indicator Lights/Indicators/Display On Lcd)
Selected Pto Speed Rate
Management Of Operator Present Control
Telematics (Fleet Menu)
Section 5 Operation
General Operation
Run In Procedure
Starting Procedure
Tractor Start-Up
Stopping The Tractor
Engine Stopping
Running In
Cold Temperature Operation
Cold Weather Starting (Temperatures Below 0°C)
Parking The Tractor
Transmission - Configurations
Speed Tables
Gearshift Clutch
Reverse Shuttle Control Lever
Setup With Mechanical Reverse Shuttle
Setup With Hydraulic Reverse Shuttle
Gearshift Lever
Operation Of Power Shuttle Gearbox
Starting The Tractor With The Clutch Pedal
Changing Gear With The Declutch Button
Changing Gear With The Clutch Pedal
Use Of The Hi-Lo Function
Use Of Reverse Shuttle Under Load
Use Of Reverse Shuttle With Clutch Pedal
Robotic Transmission - Operating Instructions
Auto Powershift Road (Aps Road)
Semi Auto
Power Take-Off
Rear Power Take-Off Engagement
Synchronised Power Take-Off (If Equipped)
Rear Auto Pto
Front Power Take-Off (If Equipped)
Front Hitch (If Equipped)
Brakes
Hydraulic Trailer Brake
Control Position For Parking Brake
Stationary
Differential Lock
Two-Wheel Drive
Operating The Four-Wheel Drive
Engine Set Point
Tractor Transport
Tow Equipment - Front Pull Hook
Drawbar
Pick Up Hitch
Height Adjustable Hitch.
Rear Tow Hitch And Drawbar - Categories
Rear Tow Hook - Adjustments
Towable Weights
Rear Hitch (Mechanical Control)
Sensitivity Adjustment
Down Speed Control
Top Link Of The Mechanical Hitch
External Control For Hitch (If Equipped)
Rear Hitch (Electronic Control)
Electronically Controlled Hitch - Activation
Hitching An Implement
Use During Work
Control Panel
Use Of The Hitch Control Selector
Hitch Activation
Hitch Lock
Hitch Movement
Fast Lowering
Hitch Handling As With The External Controls
Swing Damping Function
Down Speed Control
Maximum Height Setting
Intermix Knob
Floating Mode.
External Hitch Controls
Auxiliary Control Valves
Use Of The Auxiliary Control Valves
Quick Couplers
Connecting Rear Hoses
Disconnecting Hoses And Implements
Free Rear Discharge
Auxiliary Control Valve With Electro-Hydraulic Divider
Rear Three-Point Hitch
Section 6 Tyres - Wheels - Ballasting
Tyre Inflation Specifications
Tyre Pressures, Load Capacities And Service
Tyre Inflation Procedure
Tyre And Wheel Service
Tyre Installation
Wheel Removing Procedure
Setting The Front Wheel Toe-In
Front Axle - Steering Stops
Track Adjustment
Front And Rear Wheels Bolt Torques
Front To Rear Tyre Size Combinations
Front Fenders
Tractor Ballast
Section 7 Maintenance
Routine Maintenance Table
Recommendations Before You Service
Running In
Servicing Intervals
Fuel Tank Filling
Bleeding Air From The Fuel System
Access For Inspection And Maintenance
Useful Information On Maintenance
Variable Maintenance (Every 10 Hours Or Daily)
Cab Filter - Variable Maintenance
Preparing For Long Idle Periods
Fire Prevention
Section 8 Electric System
Fuses And Relays
7-Pin Power Socket For Trailer
Auxiliary Power Socket
Ebs Power Socket For Trailer Diagnosis (Iso 7638)
Diagnostic Connector
Section 9 Specifications - Alphabetical Index
Weights And Dimensions
Electric System
Clutch
Rear Axle
4wd Front Axle
Differential Lock
Power Take-Off
Brakes
Front Axle 4wd
Power Steering System
Hydraulic Circuit
Hitch
Three-Point Linkage
Safety Frame
Bonnet
Electric System
Optional Extras
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Implement Attachment Points
Alphabetical Index
Regulation (Eu) N.167/2013 At Last Amending 2019/519
A
Air Conditioner
Alphabetical Index
Aps (Droop Potentiometer)
Auto Pto
B
Ballast
Brakes, Operation
C
Cab Ventilation
Check Your Equipment
Cleaning
Controls
Controls - Cab
D
Differential Lock
Dpf
Dpf Filter Regeneration,
Drawbar
Drive Direction Reversing Lever
E
Electric System
Electronic Control
Engine, Starting And Stopping
External Controls
F
Filling Up
Fire Prevention
Fuel
Fuses And Relays
G
General Layout
H
How To Transport The Tractor
I
Indicator Lights
Instrument Panel
J
Joystick Controls
L
Load Capacity Of Tyres
Lubricants
M
Maintenance
Maintenance
Maintenance, General Information
Maintenance, Running-In Period
Mechanical Control
Mirror Adjustment
Miscellaneous
O
Operation
Operation Of The Four-Wheel Drive
P
Parking The Tractor
Pick Up Hitch
Power Take-Off, Precautions
Precautions
Pre-Delivery Claims
Protection From Noise
Protective Clothing
R
Radio
Rear Hitch
Rear Power Take-Off
Remote Hydraulics Operation
Risk Of Overturning
Risks From Noise
Road Transport
Running In
Running In
S
Safety
Safety - Cab
Safety Notes
Safety, Working In Safety
Seat, Adjustment
Seat Belt
Selection Of Pto Engagement Curve
Specifications
Starting Procedure
Stationary
Stationary Button
Stationary, Tractor
Steering Wheel
Systems, Checks
T
Technical Specifications
Tractor,
Trailer Brake
Turning Off The Engine
Two-Wheel Drive
Tyre Maintenance
Tyre Mounting
Tyre Pressures
Tyres, Wheels, Ballasting
U
Use Of Adjustment Of Powershuttle Effectiveness
Use Of The Tractor
Use Of The Tractor On Public Roads
V
W
Warranty
Working In Safety
