118
6,911
Landini Tractor Series 5-085 (RS57) Service Manual 6699388A2 2024
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini Series 5-085 Tractor
Engine: FPT F34 Engine
Part Number: 6699388A2
Publication Date: 2024
Number of Pages: 2540 Pages
Serie 5-085
Introduction
Liability
Purpose Of The Manual
Copyright
General Index
1001 - Safety
Foreword
Technical Notes
Maintain The Tractor Safely
Danger Signs
Tightening Torques
1500 - Specific Equipment Catalogue
Specific Equipment
Equipment For Mechanical Components
Equipment For Hydraulic Components
2000 - Engine
Technical Specifications
Annexes
2002 - Exhaust Gas Treatment System
Safety
Ats System
Regeneration Strategies
3005 - Fuel Tank
Fuel Tank Components With Guard
4001 - Electrical System
Introduction
Safety
Fuses And Relays
Component Location
Wiring Harnesses Locations
Information On Wiring Diagrams
Wiring Diagrams
4002 - Instrument Cluster Setup
And Calibrations
General Instrument Cluster Specifications
Calibrations By The Instrument Cluster
Rear Power Take-Off Calibration
Calibration With The Diagnostic Tool
5000 - Steering
- Operation
Power Steering
Description Of The Hydraulic Circuit
6000 - Transmission
- Operation
Description And Operation
Section Views
6001 - Engine - Transmission Coupling
Section And Exploded Views
Clutch Levers Adjustment Procedure
Pto Clutch Lever Adjustment
(Version With Mechanical Reverse Shuttle)
Clutch Pedal Adjustment
6002 - Engine-Gearbox Assembly
Section Views And Operation
6006 - Gearbox And Ranges
Section Views
Gearbox
Speed Ranges
6007 - Robotized Gearbox
Robotized Gearbox "Roboshift"
6012 - Rear Differential
Bevel Gear Unit And Differential
Rear Differential Section View
Rear Differential Exploded View
6014 - Four-Wheel Drive
Four-Wheel Drive
6015 - Rear Final Drives
Exploded View
Description
6019 - Rear Power Take-Off
Section And Perspective Views
Rear Pto
6021 - Front Axle
Front Axle With Brakes And Differential Lock
Front Axle Without Brakes An Without Diff Lock
7000 - Brakes
- Operation
Description
Front Brakes (Optional)
Rear Brakes
Bleeding Air From The Brake Circuit (Without Trailer)
7001 - Pedal Brakes
Pedal Brakes
Single-Pedal Braking
Simultaneous Braking With Latched Pedals
Brake Pedal Travel Check
7002 - Parking Brake
Park Lock
Parking Brake Test And Adjustment
7004 - Brakes - Trailer Braking System
Hydraulic Braking System
8000 - Hydraulic System
- Operation
Filters Of The Hydraulic System
Power Steering Control Valve
Electro-Hydraulic Packs
Rear Control Valves
Mechanically Controlled Rear Hydraulic Hitch
Electronically Controlled Rear Hydraulic Hitch
Trailer Brake Control Valve
Midmount Control Valve
Iso Hydraulic Diagrams
Functional Diagrams
8001 - Troubleshooting
Diagnostic Testing Of The Hydraulic System
Diagnostics And Troubleshooting
8005 - Front Hitch
Sections And Perspective Views
Exploded Views
Hydraulic Circuit Of The Hitch
Front Hitch (Aigner Version)
8007 - Rear Hitch
Safety
Procedures
Diagnosis And Troubleshooting
9004 - Air Conditioning System
9005 - Operator’s Seat
Safety
Annexes
10000 - Control Units Alarm Diagnostics
Can Bus System
Can Error Handling
Instrument Cluster Control Unit Ec1
Transmission Control Unit Ec4 - Without Robotized Gearbox
Robotized Gearbox Transmission Control Unit Ec4-Rs
Engine Control Unit Ec6
Hitch Control Unit Ec9
Telematics Control Unit Ec41
Robotized Gearbox Control Unit Ec44
“Smartpilot” Joystick Ec45
11000 - Disassembly Procedures
Bonnet
Front Axle
Four-Wheel Drive
Steering Column And Power Steering System
Engine-Gearbox Assembly With Hydraulic Reverse Shuttle
Engine-Gearbox Assembly With Hydraulic Reverse Shuttle And Hml
Engine-Gearbox Assembly With Mechanical Reverse Shuttle
Gearbox
Robotized Gearbox
Rear Differential
Rear Final Drives
Rear Power Take-Off With Electro-Hydraulic Engagement
Rear Power Take-Off With Electro-Hydraulic Engagement And Hml
Rear Power Take-Off With Mechanical Engagement
Rear Hitch
Front Hitch And Power Take-Off
Annexes
Engine Workshop Manual
Operator Seat Manual
Front Hitch Manual (Aigner Version)
Rear Hitch Manual
