Landini Tractor Series 2 2-045 STD To 2-055 GE (RS13) Operators Manual 6627124A2 2017
7,392
Brand: Landini
Model: Landini Series 2 2-045 STD ; 2-050 STD ; 2-055 STD ; 2-045 GE ; 2-050 GE 2-055 GE Tractor
Engine:
Yanmar 4 TNV 84 - KLAN Engine - 2-045 STD ; 2-045 GE
Yanmar 4 TNV 88 - KLAN Engine - 2-050 STD ; 2-050 GE
Yanmar 4 TNV 84T-ZXKL Engine - 2-055 STD ; 2-055 GE
Part Number: 6627124A2
Publication Date: 2017
Number of Pages: 230 Pages
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty Service
Safety
Safety Notes
Regular Use
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Warning And Caution
Safety - Decals
Safety - Following A Safety Program
Safety Frame
Safety - Cab
Safety Precautions
Personal Protection Devices (Dpi)
Check Your Equipment
Cleaning The Tractor
Save The Environment
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor.
Working In Safety
Beware Of Other People
Risk Of Overturning
To Avoid Side Overturning
To Avoid Back Overturning
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Highway Code Regulations
Safety - After Use
Further Notes
Tractor Stability
Tractor's Lifting Points
Tractor Access
Fuel Tank Filling
Wedges
Risks From Noise
Positions Of The Safety Decals
Controls - Cab
General Layout Of Controls
Operator's Seat
Seat Belt
Operator's Presence Switch (If Provided)
Cab Roof Components
Cab Ventilation
Controls For Cab Temperature
Setup With Heating Only
Setup With Cab Air Conditioning
Use Of The Air Conditioning System
Radio
Auxiliary Power Socket (12 V)
Miscellaneous
Instruments And Programming
Instruments - Instrument Panel
Operation
General Operation
Run In Procedure
Starting Procedure
Starting The Tractor
Stopping The Tractor
Turning Off The Engine
Running In
Cold Temperature Operation
Cold Weather Starting (Cold Engine)
Parking The Tractor
Battery Master Disconnect Switch
Transmission - Configurations
Gearbox
Ground Speed Table
Precautions When Using The Pto
Power Take-Off
Front Power Take-Off
Front Hitch And Pto
Brakes
Differential Lock
Four-Wheel Drive
Stationary Function
Auxiliary Control Valves
Three-Point Linkage
Mechanically Controlled Hitch
Towing Attachments
Rops Frame
Tractor Transport
Tyres, Wheels, Ballasting
Tyre Inflation Specifications
Tyre Pressures, Load Capacities And Service
Tyre Inflation Procedure
Tyre And Wheel Service
Tyre Installation
Wheel Removing Procedure
Setting The Front Wheel Toe-In
Front Axle - Steering Stops
Track Adjustment
Front To Rear Tyre Size Combinations
Regular Service Intervals
Routine Maintenance Table
Recommendations Before You Service
Lubrication And Maintenance
Running In
Fuel Tank Filling
Access For Inspection And Maintenance
Maintenance At Request
General Lubrication
Drain Air From The Fuel System
General Maintenance
Preparing For Long Idle Periods
Removing The Tractor From Storage
Fire Prevention
General Maintenance Of The Cab
Electric System
Electric System - Battery
Battery System Servicing
Beams
Fuses And Relays
Specifications
Weights And Dimensions
Radio Specifications
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Implement Attachment Points
Regulation (Eu) N. 167/2013
Alphabetical Index
Air Conditioner
Ballast
Battery
Battery
Beams
Brake Adjustment
Brake Bleeder
Brakes
Cab Ventilation
Cleaning
Controls - Cab
Controls, General Layout
Cooling
Decal Positions, Weo Countries
Differential Lock
Electric System
Engine, Maintenance
Engine Oil, Level Check And Replacement
Engine, Starting And Stopping
Equipment, Check
Front Hitch
Fuel
Fuel, Draining Air From The Fuel System
Fuses And Relays
Gearbox
General Lubrication
General Maintenance
How To Transport The Tractor
Instrument Cluster
Instrument Panel
Instruments
Load Capacity Of Tyres
Lubricants
Maintenance
Maintenance
Maintenance, Every Day Or At Request
Maintenance, General Information
Maintenance, Running-In Period
Miscellaneous
Operation
Parking The Tractor
Periodical Maintenance Guide
Power Take-Off
Precautions
Pre-Delivery Claims
Protection From Noise
Protective Clothing
Radio
Risk Of Overturning
Risks From Noise
Road Transport
Running In
Running In
Running In Of Tractor
Running In, Recommendations
Safety
Safety
Safety - Cab
Safety Decal Locations - All Markets
Safety Frame
Safety Notes
Safety, Working In Safety
Safe Use Of The Tractor
Seat, Adjustment
Seat Belt
Specifications
Starting Procedure
Stationary, Function
Stationary, Tractor
Stopping The Engine
Systems, Checks
Technical Specifications
Three-Point Linkage
Towing Attachments
Tractor, Turning Off The Engine
Tyre Maintenance
Tyre Mounting
Tyre Pressures
Tyres
Use Of The Tractor
Use Of The Tractor On Public Roads
Warning And Caution
Warranty
Working In Safety
https://drive.google.com/file/d/1zTNgc_GA_SOenPTBSoptoTq2yv-_RpI4/view?usp=drivesdk
