Martin Welker
104
231,017
Landini Tractor REX 75V to 85S VIGNETO Service Manual 3693998M1 EN
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini Tractor
REX 75V VIGNETO, REX 75S VIGNETO
REX 80V VIGNETO, REX 80S VIGNETO
REX 85V VIGNETO, REX 85S VIGNETO
Part Number: 3693998M1
Publication Date: 2007
Number of Pages: 950 Pages
- Table Of Contents
- Chapter 1 : Introduction
Section 1 : How To Consult The Manual
Section 2 : Tractor Identification
Section 3 : Working In Safety
Section 4 : Pre-Delivery Inspection And Maintenance
Section 5 : Conversion Tables
Section 6 : Sealants
Section 7 : Driving Torques
Section 8 : General Assembly Instructions
- Chapter 2 : Engine
Section 1 : Precautions And Safety Recommendations
Section 2 : Technical Specifications
Section 3 : Driving Torques
Section 4 : Engine Timing
- Chapter 3 : Clutch
Section 2 : General Description
Section 3 : Technical Specifications
Section 4 : Inspections
Section 5 : Special Tools
- Chapter 4 : Transmission
Section 4 : Guide Lines For Disassembly, Re-Assembly And Adjustments
- Chapter 5 : 4wd Axle
Section 1 : Precautions And Safety Recommendations.
Section 4 : Guidelines For Adjustments
- Chapter 6 : Power Take-Off
Section 4 : Guidelines For Disassembly, Re-Assembly And Adjustments.
- Chapter 7 : Hydraulic Circuit
Section 4 : Hydraulic Braking System
Section 5 : Main Components Of The Low Flow Circuit
Section 6 : Main Components Of The Low Flow Circuit
Section 7 : Operating Pressure Tests
Section 8 : Special Tools
- Chapter 8 : Mechanical Power Lift
Section 4 : Inspections, Adjustments And Troubleshooting
- Chapter 9 : Electronic Power Lift
Section 4 : Hydraulic Circuit
Section 5 : Electrical System
Section 6 : Functionality Tests
Section 7 : Check-Control And Troubleshooting
Section 8 : Hydraulic Tests
Section 9 : Special Tools
- Chapter 10 : Electrical System
Section 3 : Technical Specifications And Diagrams
Section 4 : Main Components
Section 5 : Description Of The Wiring Lines
Section 6 : Wiring Lines
Section 7 : Assembly Diagrams
- Chapter 11 : Ac System
Section 4 : Air Conditioning System (Ac)
Section 5 : How To Empty And Recharge The System
- Chapter 12 : Special Tools
Section 1 : 02 Dt Myt A
Section 2 : 02 Dt Myt B
Section 3 : 02 Dt Myt C
Section 4 : 02 Cmb Rex A
Section 5 : 02 Cmb Rex B
Section 6 : 03 Cmb Rex
Section 7 : 31 Dif Lg
Section 8 : 01 Dif Myt
Section 9 : 02 Dif Myt A
Section 10 : 02 Dif Myt B
Section 11 : 01 Fri Myt
Section 12 : 01 Fri Rex
Section 13 : 122 Idr Gl
Section 14 : 125 Idr Gl
Section 15 : 02 Idr Myt
Section 16 : 03 Idr Myt
Section 17 : 05 Idr Myt
Section 18 : 01 Idr Rex
Section 19 : 02 Idr Rex
Section 20 : 03 Idr Rex
Section 21 : 05 Idr Rex
Section 22 : Cr 342 A
Section 23 : Cr 342 B
Section 24 : Cr 347
Section 25 : R 502 A
Section 26 : R 502 B
