Martin Welker
104
230,792
Landini Tractor Rex 4-070V to 4-120GT Service Manual 6635336A2 EN
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini Tractor
Rex 4V Series: Rex 4-070V, Rex 4-080V, Rex 4-090V, Rex 4-100V, Rex 4-110V
Rex 4GT Series: Rex 4-070GT, Rex 4-080GT, Rex 4-090GT, Rex 4-100GT, Rex 4-110GT, Rex 4-120GT
Rex 4F Series: Rex 4-070F, Rex 4-080F, Rex 4-090F, Rex 4-100F, Rex 4-110F, Rex 4-120F
Part Number: 6635336A2
Publication Date: 2021
Number of Pages: 2716 Pages
- Cop-Intro
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
- 1001 Safety
Safety
- 2 Engine
- 3005 Reservoir
Reservoir
- 4001 Descriptions - Wiring Diagrams - Connectors
- 4002 Instrument Cluster Setup
- 5 Steering System - Operation
Steering System Operation
- 5001 Steering Column And Power Steering System
- 6 Transmission - Operation
Transmission With Mechanical Reverse Shuttle
Transmission With Hydraulic Reverse Shuttle
Gearbox
Speed Ranges
Park Lock
Bevel Gear Pair And Differential
Side Final Drives
Rear Power Take-Off
Front Axle With Four Driving Wheels
Front Axle With Two Driving Wheels
- 6001 Engine - Transmission Coupling
- 6002 Engine Gearbox Assembly - (Version With Mechanical Reverse Shuttle)
Engine Gearbox Assembly (Version With Mechanical Reverse Shuttle)
- 6002 Engine Gearbox Assembly - (Setup With Hydraulic Reverse Shuttle Without Hml)
Engine Gearbox Assembly (Setup With Hydraulic Reverse Shuttle Without Hml)
- 6002 Engine Gearbox Assembly - (Setup With Hydraulic Reverse Shuttle With Hml)
Engine Gearbox Assembly (Setup With Hydraulic Reverse Shuttle With Hml)
- 6006 Synchronised Gearbox And Ranges
- 6012 Rear Differential
Rear Differential
- 6018 Side Final Drives
Side Final Drives
- 6019 Rear Power Take-Off - (2 Speeds Setup With Mechanical Engagement)
Rear Power Take-Off (2 Speeds Setup With Mechanical Engagement)
- 6019 Rear Power Take-Off - (Setup With 2 Speeds With Electro-Hydraulic Engagement Without Hml)
Rear Power Take-Off (Setup With 2 Speeds With Electro-Hydraulic Engagement Without Hml)
- 6019 Rear Power Take-Off - (Setup With 2 Speeds With Electro-Hydraulic Engagement With Hml)
Rear Power Take-Off (Setup With 2 Speeds With Electro-Hydraulic Engagement With Hml)
- 6019 Rear Power Take-Off - (4 Speeds Setup With Mechanical Engagement)
Rear Power Take-Off (4 Speeds Setup With Mechanical Engagement)
- 6019 Rear Power Take-Off - (Setup With 4 Speeds With Electro-Hydraulic Engagement Without Hml)
Rear Power Take-Off (Setup With 4 Speeds With Electro-Hydraulic Engagement Without Hml)
- 6019 Rear Power Take-Off - (Setup With 4 Speeds With Electro-Hydraulic Engagement With Hml)
Removal Of Clutch Unit And Internal Overhaul 6
Removal Of The Transmitter Gears, 4-Speed Pto 9
Disassembly Of The Lower Shaft 11
Re-Assembly Of The Lower Shaft 12
Re-Assembly Of The Transmitter Gears, 4-Speed Pto 12
Pto Speed Sensor 14
Adjustment Of The Pto Speed Sensor 14
Adjustment Of Pto Safety Valve (Only For Version With Synchro Pto) 15
Rear Power Take-Off (Setup With 4 Speeds With Electro-Hydraulic Engagement With Hml)
- 6021 Front Axle
Front Axle
- 7 Brakes - Operation
Brakes Operation
- 7003 Brakes - Overhaul And Adjustments
Brakes Overhaul And Adjustments
- 8 Hydraulic Components - Operation
Hydraulic Components Operation
- 8001 Hydraulic Components - Inspections And Adjustments
Hydraulic Components Inspections And Adjustments
- 8005 Front Hitch And Pto
Front Hitch And Pto
- 8007 Rear Hitch
Rear Hitch
- 10 Can Line Controllers - Operation
Can Line Controllers Operation
- 10002 Hitch Controller - Calibration, Descriptions, Wiring Diagrams, Error Codes, Troubleshooting
Hitch Controller Calibration, Descriptions, Wiring Diagrams, Error Codes, Troubleshooting
- 10003 Suspended Axle Controller - Calibration, Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Suspended Axle Controller Calibration, Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
- 10005 Engine Controller - Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Engine Controller Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
- 10006 Transmission Controller - Calibration, Descriptions, Wiring Diagrams, Error Codes, Troubleshooting
Transmission Controller Calibration, Descriptions, Wiring Diagrams, Error Codes, Troubleshooting
- 10008 Ac Controller - Descriptions And Wiring Diagrams
A/C Controller Descriptions And Wiring Diagrams
- 10009 Instrument Cluster Controller - Descriptions And Wiring Diagrams
Instrument Cluster Controller Descriptions And Wiring Diagrams
- 10015 Cat4 Cab - Descriptions And Wiring Diagrams
Cat4 Cab Descriptions And Wiring Diagrams
