Martin Welker
104
230,310
Landini Tractor Rex 4-070 Rex 4-080 Service Manual 6637127A2 EN
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini Rex 4-070, Rex 4-080Tractor
Part Number: 6637127A2
Publication Date: 2022
Number of Pages: 1716 Pages
- Rex 4
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
- 1001 - Safety
Introduction
Technical Notes
Maintain The Tractor In A Safe Way
Danger Signs
Tightening Torques
- 1002 - Specific Equipment Catalogue
Specific Equipment
- 2 - Engine
Technical Specifications
Annexes
- 2002 - Exhaust Gases Treatment System
Safety
Ats System
- 3005 - Fuel Tank
Safety
Procedures
- 4001 - Electric System
Safety
Fuses And Relays
Controls
Sockets
Lights
Component Sheets
Wiring Harnesses Locations
Wiring Diagrams
Complete List Of Connections
- 4002 - Instrument Cluster Set-Up And Calibrations
General Instrument Cluster Specifications
Calibration From The Instrument Cluster
Calibration From The Instrument The Diagnostic Tool
- 5 - Steering System Operation
Power Steering System
Iso And Functional Diagrams
- 5001 - Steering Column And Power Steering System
Sections And Perspective Views
Safety
- 6 - Transmission (Operation)
Description And Operation
- 6001 - Engine - Transmission Coupling
Safety
Procedures
- 6002 - Engine-Transmission Assembly (Power Shuttle And Power Five Versions)
Safety
Guidelines For Disassembly
Guidelines For Re-Assembly And Inspections
- 6002 - Engine-Transmission Assembly (Version Without Power Five)
Safety
Guide Lines For Disassembly, Re-Assembly And Adjustments
- 6006 - Synchronized Gearbox And Ranges
Safety
- 6012 - Rear Differential
Safety
Procedures
- 6018 - Side Final Drives
Safety
Procedures
- 6019 - Rear Pto (2-Speeds Version With Mechanical Engagement)
Safety
Procedures
Guidelines For Re-Assembly, Adjustments And Inspections
- 6019 - Rear Pto (2-Speeds Version With Electro-Hydraulic Engagement)
Safety
Guidelines For Disassembly, Re-Assembly And Adjustment Of The Hydraulic Pto
- 6021 - Front Axle
Safety
Differential Assembly
Front Final Drive Overhaul
- 7 - Brakes Operation
Braking Circuit
4wd During Braking
Trailer Brake System
- 7003 - Brakes (Adjustments And Inspections)
Safety
Procedures
- 8 - Hydraulic Components Operation
Hydraulic Circuit
Pumps
Solenoid Valves Packs
Rear Hydraulic Valve System
Hydraulic Hitch With Mechanical Control
Midmount Control Valves
- 8001 - Hydraulic Components (Inspections And Adjustments)
Troubleshooting
Operating Pressure Tests
- 8007 - Rear Hitch
Safety
Guidelines For The Inspections
Guidelines For Hitch Adjustments
Troubleshooting
- 10000 - Control Units Alarms Diagnostics
Can Bus System
Error Handling Via Can
Instrument Cluster Control Unit Ec1
Transmission Control Unit Ec4
Engine Control Unit Ec6
