118
7,392
Landini Tractor Rex 3-060 3-070 3-080 F-GE (RS61) Operators Manual 6671250A4 2020
Brand: Landini
Model: Landini Rex 3-060 F/GE ; Rex 3-070 F/GE ; Rex 3-080 F/GE Tractor
Rex 3-060 F ; Rex 3-070 F ; Rex 3-080 F
Rex 3-060 GE ; Rex 3-070 GE ; Rex 3-080 GE
Part Number: 6671250A4
Publication Date: 2020
Number of Pages: 366 Pages
Section 1 contents
Tractor identification
Introduction
Warranty, pre-delivery inspections and installation
Warranty claim
Spare parts warning
If you move
Post-warranty service
Safety
Section 2 Safety notes
Alarm and safety texts and symbols
Safety - tractor and implement
Safety - Introduction
Safety - Advice for the operator
Safety - Danger, warning and caution
Safety - Decals
Safety - Following a safety program
Safety frame
Safety - Cab
Safety precautions
Personal protection equipment (PPE)
Check your equipment
Cleaning the tractor
Save the environment
Safety - Tractor maintenance
Safety - Starting up
Working in safety
Follow the rules when using your tractor.
Working in safety
Beware of other people
Risk of overturning
To avoid side overturning
To avoid back overturning
Dangerous operations
To engage the power take-off
Implements and attachments
Road transport
Highway Code regulations
Safety - After use
Further notes
Tractor stability
Tractor's lifting points
Tractor access
Fuel tank filling
Wedges
Risks from noise
Positions of the safety decals
Section 3 Controls - Cab
Main controls
Controls on the left side of the driver's seat
Controls on control turret
Controls on the right side of the driver's seat
LED and backlighting functions on switches
Mechanical hitch controls
Tractor Warning Lamp Usage
Turn indicator operation (North America version)
Implement Warning Lamps (if Equipped)
Rotating Beacon
Slow Moving Vehicle (SMV) Symbol
Ignition switch
Battery master disconnect switch
Steering column adjustment
Auxiliary power socket (12 V)
Operator's seat
Seat in the setup with air suspension - MT type
Seat belt
Operator present sensor
Low cab
Low cab roof components
Cab ventilation
Cab temperature controls
Controls of users in low cab
Low cab rear window
Standard cab
Standard cab ventilation
Set-up with standard cab air conditioning
Use of the air conditioning system - standard cab
Radio
Section 4 Instruments and Programming
Instruments - Instrument panel
Indicator lights
Display operation
Alarm management priority display
Main display
Clock/Work timer
Service interval
Alarm from operator present sensor on seat
Counters
Engine controller menu
DPF Filter regeneration
Adjustment of screen, lamps and indicators brightness
Constant engine RPM rate
Alarms
Transmission display area
Power take-off menu
Accessories menu
Implement width
Euro/NAO market
Clock
Service interval
Functionality (indicator lights/indicators/display on LCD)
Selected PTO speed rate
Management of operator present control
Section 5 Operation
General Operation
Run In Procedure
Starting procedure
Starting the tractor
Accelerator pedal
Stopping the tractor
Turning off the engine
Running in
Cold Temperature Operation
Cold weather starting (cold engine)
Parking the tractor
Transmission - configurations
Gearbox
Speed tables
Precautions when using the PTO
Rear Power Take-Off
PTO overspeed
Front power take-off (if equipped)
Front hitch (if equipped)
Brakes
Parking brake
Hydraulic trailer brake
Control position for parking brake
Stationary
Use of the differential lock
Operating the four-wheel drive
Engine set point
Tractor transport
ROPS frame
Tow equipment - Front pull hook
Drawbar
Height adjustable hitch
Rear tow hook - Adjustments
Towable weights
Rear hitch (mechanical control)
Sensitivity adjustment
Down speed control
Top link of the mechanical hitch
Auxiliary hydraulic control valves
Quick couplers
Connecting rear hoses
Disconnecting hoses and implements
Rear Three-Point Hitch
Three-point linkage
Section 6 Tyres - Wheels - Ballasting
Tyre Inflation Specifications
Tyre pressures, Load Capacities And Service
Tyre inflation procedure
Tyre and wheel service
Tyre installation
Wheel removing procedure
Setting The Front Wheel Toe-In
Front axle - steering stops
Track adjustment
Front and rear wheels bolt torques
Front to rear tyre size combinations
Front fenders
Tractor ballast
Section 7 Maintenance
Routine maintenance table
Recommendations before you service
Running in
Servicing intervals
Miscellaneous checks
Lubrication/Greasing
General tractor inspection
Fuel tank filling
Engine oil specifications
Approved fuels
Protective agent for the cooling system
Fuel tank filling
Access for inspection and maintenance
Useful information on maintenance
Variable maintenance (every 10 hours or daily)
Cab filter - Variable maintenance
General maintenance
Preparing for long idle periods
Fire prevention
Useful information on engine failures
Section 8 Electric system
Battery
Battery system servicing
Beams
Bulb replacement
Fuses and relays
7-pin power socket for trailer
EBS power socket for trailer diagnosis (ISO 7638)
Diagnostic connector
Section 9 Specifications - Alphabetical index
Weights and dimensions
Electric system
Radio specifications
Clutch
Noise levels
Vibration levels
Issue of authorization
Weights
Lubricants and fuels chart
Implement attachment points
Alphabetical index
Regulation (EU) n. 167/2013 at last amending 2019/519
