118
7,392
Landini Tractor Powerfarm 100 110 120 (RP23) Operators Manual 6715318A2 2022
Brand: Landini
Model: Landini Powerfarm 100 ; Powerfarm 110 ; Powerfarm 120 Tractor
Engine: Perkins 1104 Tier 3A Engine
Part Number: 6715318A2
Publication Date: 2022
Number of Pages: 358 Pages
Section 1 Contents
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty Service
Safety
Section 2 Safety Notes
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Warning And Caution
Safety - Decals
Safety - Following A Safety Program
Safety - Cab
Safety Precautions
Personal Protection Equipment (Ppe)
Cleaning The Tractor
Save The Environment
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor.
Working In Safety
Beware Of Other People
Risk Of Overturning
To Avoid Side Overturning
To Avoid Back Overturning
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Highway Code Regulations
Safety - After Use
Further Notes
Tractor Stability
Tractor's Lifting Points
Tractor Access
Fuel Tank Filling
Wedges
Risks From Noise
Prevention Against Burns
Hazardous Substances
Positions Of The Safety Decals
Section 3 Controls - Cab
General Layout Of Controls
Controls On The Left Side Of The Driver's Seat.
Controls On The Left Side Of The Control Turret
Drive Direction Reversing Lever (Setup With Mechanical Reverse Shuttle)
Reverse Shuttle Lever (Set-Up With Hydraulic Reverse Shuttle)
Tractor Warning Lamp Usage
Implement Warning Lamps (If Equipped)
Rotating Beacon
Slow Moving Vehicle (Smv) Symbol
Front Right Controls On Instrument Turret
Steering Column Adjustment
Pedal Controls
Auxiliary Power Socket (12 V)
Miscellaneous
External Controls
Operator's Seat
Seat Belt
Seat Belt
Instructor Seat
Operator Present Sensor
Central Controls On Control Turret
Rear Window Wiper
Cab Roof Components
Cab Ventilation
Controls For Cab Temperature
Setup With Heating Only
Setup With Cab Air Conditioning
Use Of The Air Conditioning System
Radio
Additional Cab Features
Section 4 Instruments And Programming
Instruments - Instrument Panel
Display Operation
Alarm Management Priority Display
Main Display
Clock/Work Timer
Rear Electronic Hitch
Engagement/Disengagement Threshold Of Auto Pto
Service Interval
Alarm From Operator Present Sensor On Seat
Air Brakes Pressure
Counters
Calibrations
Engine Controller Menu
Adjustment Of Screen, Lamps And Indicators Brightness
Selection Of Rear Pto Engagement Curve
Alarms
Transmission Display Area
Power Take-Off Menu
Accessories Menu
• Implement Width
• Euro/Nao Market
• Clock
• Service Interval
• Functionality (Indicator Lights/Indicators/Display On Lcd)
Selected Pto Speed Rate
Management Of Operator Present Control
Section 5 Operation
General Operation
Run In Procedure
Starting Procedure
Tractor Start-Up
Stopping The Tractor
Engine Stopping
Running In
Cold Temperature Operation
Cold Weather Starting (Temperatures Below 0°C)
Parking The Tractor
Transmission - Configurations
Speed Tables
Gearshift Clutch
Reverse Shuttle Control Lever
Setup With Hydraulic Reverse Shuttle
Gearshift Lever
Operation Of Power Shuttle Gearbox (Setup With Hydraulic Reverse Shuttle)
Starting The Tractor With The Clutch Pedal
Changing Gear With The Declutch Button
Changing Gear With The Clutch Pedal
Engagement Of Powershift Ranges
Use Of Reverse Shuttle Under Load
Use Of Reverse Shuttle With Clutch Pedal
Power Take-Off
Synchronised Power Take-Off (If Equipped)
Brakes
Hydraulic Trailer Brake
Differential Lock
Two-Wheel Drive
Engine Set Point
Tractor Transport
Tow Equipment - Front Pull Hook
Drawbar
Height Adjustable Hitch.
Rear Tow Hitch And Drawbar - Categories
Rear Tow Hook - Adjustments
Towable Weights
Rear Hitch (Mechanical Control)
• Sensitivity Adjustment
• Down Speed Control
• Top Link Of The Mechanical Hitch
• External Control For Hitch (If Equipped)
Rear Hitch (Electronic Control)
Auxiliary Control Valves
Use Of The Auxiliary Control Valves
Quick Couplers
Connecting Rear Hoses
Free Rear Discharge
Rear Three-Point Hitch
Section 6 Tyres - Wheels - Ballasting
Tyre Inflation Specifications
Tyre Pressures, Load Capacities And Service
Tyre Inflation Procedure
Tyre And Wheel Service
Tyre Installation
Wheel Removing Procedure
Setting The Front Wheel Toe-In
Front Axle - Steering Stops
Track Adjustment
Front And Rear Wheels Bolt Torques
Front Fenders
Tractor Ballast
Section 7 Maintenance
Routine Maintenance Table
Recommendations Before You Service
Running In
Servicing Intervals
Fuel Tank Filling
Bleeding Air From The Fuel System
Access For Inspection And Maintenance
Variable Maintenance (Every 10 Hours Or Daily)
Cab Filter - Maintenance On Request
Preparing For Long Idle Periods
Fire Prevention
Section 8 Electric System
Fuses And Relays
7-Pin Power Socket For Trailer
Diagnostic Connector
Section 9 Specifications - Alphabetical Index
Weights And Dimensions
Electric System
Radio Specifications
Pedal Cable
Rear Axle
Front Axle
Differential Lock
Power Take-Off
Brakes
4wd Front Axle
Power Steering System
Hydraulic Circuit
Hitch
Three-Point Linkage
Bonnet
Electric System
Optional Extras
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Implement Attachment Points
Alphabetical Index
Regulation (EU) no. 167/ 2013 to latest amendment 2019/ 519
