Landini Tractor MISTRAL AMERICA 40 45 50 Service Manual 3676163M1 EN
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini MISTRAL AMERICA 40, MISTRAL AMERICA 45, MISTRAL AMERICA 50 Tractor
Part Number: 3676163M1
Publication Date: 2004
Number of Pages: 462 Pages
- Introduction
- Liability
- Purpose Of The Manual
- Copyright
- General Information
Safety Notes
General Instructions
Symbols
Danger Signs
Sealing And Fixing Sealants
Lubricants And Fuels
Conventional Units Of Measurement
Standard Driving Torque Values
- Engine
General Features
Main Specifications
Driving Torques
Specific Equipment
Sections
Lubrication, Cooling And Fuelling Circuit Diagrams
Engine Troubleshooting
Engine Splitting And Remounting
Compression Test
Engine - Overhaul
Injector Nozzle And Injection Pressure Measuring And Monitoring
Injection Timing Adjustment And Monitoring
Idling Rate Adjustment (Minimum And Maximum)
How To Check The Cooling System And Radiator To Find Leaks
Sensor Inspection
Cylinder Head Inspections, Measurements And Repairs
Crankcase And Cylinder Liner Inspections, Measurements And Repairs
Rocker Arm Inspections, Measurements And Repairs
Piston And Piston Ring Inspections, Measurements And Repairs
Connection Rod Inspections, Measurements And Repairs
Camshaft Inspections, Measurements And Repairs
Drive Shaft Inspections, Measurements And Repairs
Gear Inspections, Measurements And Repairs
Oil Pump Inspections, Measurements And Repairs
Yanmar Injection Pump
Injection Pump - Overhaul
Regulator Unit - Overhaul
- Clutch
General Specifications Of The Lx 9”/9” Clutch
Specific Equipment
Sections
Troubleshooting For The Clutch Assembly
Where The Sealant Is Applied For The Clutch Housing On The Transmission Housing
Clutch Splitting-Remounting
Control Adjustment Gearshift Clutch
Control Adjustment Power Take-Off Clutch
- (12 + 12) And (16 + 16) Mechanical Gearbox
Main Specifications Of The Gearbox And Final Drive
Main Specifications Of Reverse Shuttle
Main Specifications Of The Supplementary Final Drive (16 + 16 Version)
Sections
Description And Operation.
Troubleshooting For The Gearbox, Final Drive And Reverse Shuttle
Troubleshooting For The Supplementary Final Drive (16-16 Version)
Where The Sealant Is Applied For The Gearbox-Rear Transmission Housing
Gearbox Transmission Housing Splitting-Remounting
Gearbox Transmission Housing - Overhaul
Clutch Housing - Overhaul
- Rear Differential Axle
Main Specifications Of The Bevel Gear Pair And Differential
Sections
Troubleshooting For The Bevel Gear Pair And Differential
Troubleshooting For The Side Final Drives
Rear Transmission Housing - Overhaul
Right Or Left Side Final Drive Housing- Assembly Splitting Remounting
Driving Wheel Shaft - Overhaul
Bevel Gear Pair Adjustment
- Front Axle
Main Specifications
Specific Equipment
Sections
Troubleshooting For The Front Axle Diff Lock Device
Front Axle
Front Axle Differential And Bevel Gear Pair Support
Front Bevel Gear Pair - Overhaul
Front Diff Lock - Overhaul
Wheel Hub - Overhaul
Front Final Drive - Splitting Remounting
Front Final Drive - Overhaul
Axle Steering Cylinder - Splitting Remounting
- Power Take-Off
Main Specifications
Sections
Troubleshooting For The Mechanically Engaged Power Take-Off
Where The Sealant Is Applied On The Power Take-Off Cover
Mechanically Engaged Power Take-Off Overhaul
- Hydraulic Circuits - Rear Power Lift
Main Specifications - Rear Hydraulic Power Lift
Specific Equipment
Sections And Perspective Views
Description Of The Operating Mode Of The Hydraulic Power Lift
Description Of The Operating Mode Of The Hydraulic Power Lift’s Valve System
Power Lift’s Valve System - Overhaul
Valve System Of The Hydraulic Power Lift - Hydraulic Tests
Power Lift - Adjustments
Hydraulic Power Lift - Operating Pressure Test
- Hydraulic Circuits - Auxiliary Control Valves
Main Specifications
- Steering System
Main Specifications
Sections And Exploded Views
Operating Pressure Tests
- Brakes
Main Specifications
Sections
Brake System Troubleshooting
Where The Sealant Is Applied On The Brake Assembly And Side Final Drives On The Transmission Housing
Right Or Left Brake Splitting- Remounting
Adjustments
- Electrical System - Instruments
Instruments
Transmitters, Sensors And Switches
Maintenance
- Electrical System - Components
Control Panel With Analogue Instrument
Light Switch
Hazard Light Switch
Rotating Beam Switch.
Ignition Switch
Controls On The Right-Hand Side
Diff Lock Control Button
Controls On The Left-Hand Side
Maintenance
- Electrical System - Ignition System
Technical Specifications
Troubleshooting
Tests
Starter Motor. Splitting-Remounting
- Electrical System - Recharging System
Tests And Troubleshooting
Alternator. Splitting-Remounting
- Electrical System - Battery
Battery Splitting-Remounting
Maintenance And Battery Inspection
Common Causes Of Battery Faults
- 1050 Gb.Pdf
Electrical System - Electrical Circuits
Brand: Landini
- Introduction
- Liability
- Copyright
Safety Notes
Symbols
Danger Signs
- Engine
General Features
Main Specifications
Driving Torques
Specific Equipment
Sections
Compression Test
Engine - Overhaul
Sensor Inspection
- Clutch
Specific Equipment
Sections
Sections
Sections
- Front Axle
Main Specifications
Specific Equipment
Sections
Front Axle
- Power Take-Off
Main Specifications
Sections
Specific Equipment
Main Specifications
- Steering System
Main Specifications
- Brakes
Main Specifications
Sections
Adjustments
Instruments
Maintenance
Light Switch
Hazard Light Switch
Ignition Switch
Maintenance
Troubleshooting
Tests
- 1050 Gb.Pdf
- Landini Tractor 105,115,130,145,165 Service Manual
- Landini 8860 Parts Catalog
- Landini 9880 Parts Catalog
- Landini 8500 Accessories And Application Miscellaneous Parts Catalog
- Landini 105,115,130,145,165 Service Manual
- Landini 7860 Parts Catalog
- Landini 14500 Accessories And Application Miscellaneous Parts Catalog
- Landini 6500 Accessories And Application Miscellaneous Parts Catalog
- Landini Power_Farm_95 Parts Catalog
- Landini 6880 Parts Catalog
- Landini Mistral_55 Parts Catalog
- Landini 105 115 130 145 165 Service Manual
- Landini 8830 Accessories And Application Miscellaneous Parts Catalog
- Landini 7880 Parts Catalog
- Landini Tractor Legend 105 - 165 Training Manual and Wiring Diagram
