Martin Welker
104
230,792
Landini Tractor MISTRAL 40 45 50 55 Service Manual 6500562M1 EN
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini Tractor
MISTRAL 40, MISTRAL 45, MISTRAL 50, MISTRAL 55
Part Number: 6500562M1
Publication Date: 2009
Number of Pages: 416 Pages
- Introduction
- Liability
- Purpose Of The Manual
- Copyright
- Table Of Contents
- Safety, General Information
Safety Notes
General Instructions
Symbols
Danger Signs
Lubricants And Fuels
- Engine
Main Technical Specifications
Driving Torque Values
Specific Equipment
Splitting-Re-Assembling And Timing Injection Pump
Splitting-Re-Assembling The Engine (Version Without Cab)
Splitting-Re-Assembling The Engine Version With Cab)
Engine Troubleshooting
- Fuel System Operation
Exploded Views
Description And Operation
- Wiring Diagrams
Wiring Diagrams Models 40-45-50 And Model 55
A3
- Battery
Main Specifications
Battery Removal - Re-Connection
Battery Maintenance And Inspection
Common Causes Of Battery Faults
- Steering Operation
Sections And Exploded Views
- Steering Circuit
Main Specifications
Operating Pressure Tests
- Transmission Operation
Sections
- Mechanical Gearbox
Main Specifications
Where The Sealant Is Applied For The Gearbox-Rear Transmission Housing
Splitting-Re-Assembly Of Gearbox Transmission Housing
Gearbox Transmission Housing Overhaul
Clutch Housing Overhaul
Troubleshooting For The Gearbox, Creeper And Reverse Shuttle
Troubleshooting For The Creeper (16-16 Version)
- Clutch
Main Specifications
Specific Equipment
Where Sealant Is Applied For The Clutch Housing On The Transmission Housing
Clutch Removal-Re-Assembly (Tractor Version Without Cab)
Gearshift Clutch Control Adjustment
Pto Clutch Control Adjustment
Troubleshooting For The Clutch Assembly
- Rear Differential Housing
Main Specifications
Where Sealant Is Applied For The Gearbox-Rear Transmission Housing
Removal-Re-Assembly Of The Rh Or Lh Side Final Drive Housing
Rear Transmission Housing Overhaul
Driving Wheel Shaft Overhaul
Bevel Gear Pair Adjustment
Troubleshooting For The Bevel Gear Pair And Differential
Troubleshooting For The Side Final Drives
- Power Take-Off
Main Specifications
Where Sealant Is Applied On The Power Take-Off Cover
Overhail Of Mechanically Engaged Power Take-Off
Troubleshooting For The Mechanically Engaged Power Take-Off
- Front Power Take-Off
Main Specifications
Splitting-Re-Assembly Of Front Power Take-Off
Verification Of Front Power Take-Off Engagement/Disengagement
- Front Axle
Main Specifications
Specific Equipment
Splitting-Re-Assembly Of Front Axle
Splitting-Re-Assembly Of Front Axle Differential And Bevel Gear Pair Support
Front Bevel Gear Pair Overhaul
Front Diff Lock Overhaul
Wheel Hub Overhaul
Splitting-Re-Assembly Of Front Final Drive
Front Final Drive Overhaul
Splitting-Re-Assembly Of Axle Steering Cylinder
Troubleshooting For The Front Axle Diff Lock Device
- Brakes Operation
Sections
- Main Brake And Parking Brake
Main Specifications
Where Sealant Is Applied On The Brake Assembly And Side Final Drives On The Transmission Housing
Splitting-Re-Assembly Of Rh Or Lh Brake
Adjustments
Brake System Troubleshooting
- Hydraulic Components Operation
Sections And Perspective Views
Description And Operation Of The Hydraulic Power Lift
Description Of The Operating Mode Of The Hydraulic Power Lift's Valve System
- Auxiliary Control Valves
Main Specifications
- Rear Power Lift
Main Specifications
Specific Equipment
Power Lift - Adjustments
Hydraulic Power Lift - Operating Pressure Test
Splitting-Remounting The Power Lift
Power Lift Troubleshooting
- Front Power Lift
Main Specifications
Splitting-Re-Assembly Of The Front Power Lift
- Cab
Specific Equipment
Splitting-Re-Assembly Of The Cab
- Engine Controller
Engine Controller Alarm Codes, Electric Circuits Of Engines Mod. 55
A3
