Landini Tractor Landpower II 125 135 145 165 (RP75 HML) Service Manual 6697393A1 2020
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini Landpower II Tractor
Landpower 125 ; Landpower 135 ; Landpower 145 ; Landpower 165
Engine: FPT NEF Engine
F4CE9684L - Landpower 125
F4CE9684P - Landpower 135
F4CE9684J - Landpower 145
F4CE9684H - Landpower 165
Part Number: 6697393A1
Publication Date: 2020
Number of Pages: 1310 Pages
1_General
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
2_Engine
Contents
Technical Specifications
Annexes
5_Steering System Operation
Power Steering
6_Transmission Operation
Transmission 5
Transmission With Mechanical Reverse Shuttle 11
Transmission With Hml Power Reverse Shuttle 19
Gearbox 31
Speed Ranges 40
Four-Wheel Drive 49
Bevel Gear Pair And Differential 55
Side Final Drives 61
Rear Power Take-Off 67
Front Axle 77
Gearbox
Speed Ranges
Four-Wheel Drive
Side Final Drives
Rear Power Take-Off
Front Axle
7_Brakes Operation
Contents
Brakes
Power Brake Pump
Standard Brake Pump
Trailer Brake System
Troubleshooting
Diagnostic Tests Of The Air System
8_Hydraulic Components Operation
Contents
Pumps
Solenoid Valves Controller For Users Control
Hml Reverse Shuttle Solenoid Valves Pack
Solenoid Valves Pack For Pto Control
Hydraulic Hitch With Mechanical Control
Auxiliary Spool Valves (Set-Up With Mechanical Hitch)
Electronically Controlled Hydraulic Hitch
Auxiliary Spool Valves (Set-Up With Electronic Hitch)
10_Can Line Controllers Operation
Contents
Introduction
Error Handling Via Can
Safety
Check-Control And Troubleshooting
Descriptions And Diagrams
Basic Checks
1001_Safety
General Instructions
Symbols
Danger Signs
Tightening Torques
3005_Tanks And Reservoirs
Contents
Safety
4001_Descriptions - Wiring Diagrams - Connectors
Contents
Safety
Symbols And Names
Fuses And Relays
Controls
Sockets
Light Units
Topographic Diagrams
Complete List Of Connections
4002_Programming The Instrument Cluster
Programming
5001_Steering Column And Power Steering System
Safety
5002_Power Steering System
6002_Engine Gearbox Assembly (Set-Up With Hml Power Reverse Shuttle)
Contents
Safety
Sections And Perspective Views
Engine-Gearbox Assembly
6002_Engine-Gearbox Assembly (Set-Up With Mechanical Reverse Shuttle)
Contents
Safety
6006_Gearbox And Ranges
Contents
Safety
Gearbox
6012_Rear Differential
Technical Specifications 3
Sections And Perspective Views 6
Safety 8
Rear Differential Assembly 9
Troubleshooting For The Bevel Gear Pair And Differential 21
Safety
6014_4wd Housing
Safety
4wd Housing
Diagnosis Of Malfunction In Locking Device Of Front Differential
6018_Side Final Drives
Safety 9
Rear Final Drives 10
Safety
Rear Final Drives
6019_Rear Power Take-Off
Contents
Safety
Rear Power Take-Off
6021_Argo Front Axle
Safety
Front Axle
6021_Carraro Front Axle
Carraro Front Axle
Annexes
8001_Hydraulic Components Inspections And Adjustments
Troubleshooting
8005_Front Hitch And Pto (Only For Hydraulic System With Gear Pump)
Safety
Front Hitch And Pto
8007_Rear Hitch
Mechanically Controlled Hydraulic Hitch
9005_Operator's Seat
Safety
Operator's Seat
Annexes
10002_Hitch Controller Calibration, Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Contents
Safety
General Information About The Rear Hitch Controller
Functional Tests
Adjustments
Error Codes - Electrical Diagnosis
Error Codes - Settings And Programming
10004_Power Take-Off Controller Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Safety
Electronic Control Of Rear Power Take-Off
10006_Transmission Controller Calibration, Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Contents
Safety
Electronic Control Unit
Clutch Pedal Calibration
Transmission Calibration
10009_Instrument Cluster Controller Description And Wiring Diagrams
Contents
Safety
Brand: Landini
1_General
Introduction
Liability
Copyright
Table Of Contents
2_Engine
Contents
Annexes
Power Steering
Transmission 5
Gearbox 31
Speed Ranges 40
Four-Wheel Drive 49
Front Axle 77
Gearbox
Speed Ranges
Four-Wheel Drive
Side Final Drives
Rear Power Take-Off
Front Axle
7_Brakes Operation
Contents
Brakes
Power Brake Pump
Standard Brake Pump
Troubleshooting
Contents
Pumps
Contents
Introduction
Safety
Basic Checks
1001_Safety
Symbols
Danger Signs
Tightening Torques
Contents
Safety
Contents
Safety
Symbols And Names
Fuses And Relays
Controls
Sockets
Light Units
Programming
Safety
Contents
Safety
Contents
Safety
Contents
Safety
Gearbox
Safety 8
Safety
6014_4wd Housing
Safety
4wd Housing
Safety 9
Safety
Rear Final Drives
Contents
Safety
Rear Power Take-Off
Safety
Front Axle
Carraro Front Axle
Annexes
Troubleshooting
Safety
Front Hitch And Pto
8007_Rear Hitch
Safety
Operator's Seat
Annexes
Contents
Safety
Functional Tests
Adjustments
Safety
Contents
Safety
Contents
Safety
- Landini Tractor 105,115,130,145,165 Service Manual
- Landini 8860 Parts Catalog
- Landini 9880 Parts Catalog
- Landini 8500 Accessories And Application Miscellaneous Parts Catalog
- Landini 105,115,130,145,165 Service Manual
- Landini 7860 Parts Catalog
- Landini 14500 Accessories And Application Miscellaneous Parts Catalog
- Landini 6500 Accessories And Application Miscellaneous Parts Catalog
- Landini Power_Farm_95 Parts Catalog
- Landini 6880 Parts Catalog
- Landini Mistral_55 Parts Catalog
- Landini 105 115 130 145 165 Service Manual
- Landini 8830 Accessories And Application Miscellaneous Parts Catalog
- Landini 7880 Parts Catalog
- Landini Tractor Legend 105 - 165 Training Manual and Wiring Diagram
