Martin Welker
104
230,792
Landini Tractor ALPINE 65 75 85 Service Manual 3676095M1 EN
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini ALPINE 65, ALPINE 75, ALPINE 85 Tractor
Part Number: 3676095M1
Publication Date: 2005
Number of Pages: 444 Pages
- Introduction
- Liability
- Purpose Of The Manual
- Copyright
- General Information
Safety Notes
General Instructions
Symbols
Danger Signs
Sealing And Fixing Sealants
Lubricants And Fuels
Conventional Units Of Measurement
Standard Driving Torque Values
- Engine
General Features
Engine Views
Sections
Diagrams And Circuits
Engine Troubleshooting
Compression Test
Adjustments And Tests
Injection Pump Tuning
- Clutch
General Specifications Of The Lx (Ox) 12” Clutch
General Specifications Of The Hi-Lo System
Description And Operation Of The Clutch And Hi-Lo System
Controls
Sections
Clutch Housing Sealant Application Diagram
Clutch Assembly Troubleshooting
Clutch Removal-Refitting
Clutch Housing - Overhaul
Clutch Housing With Hi-Lo - Overhaul
- Speedfive And Powerfive Mechanical Gearbox
Main Specifications Of The Speedfive Gearbox And Final Drive
Main Specifications Of Reverse Shuttle
Main Specifications Of Super Final Drive
Description And Operation Of The Speedfive Gearbox
Main Specifications Of Powerfive Gearbox
Description And Operation Of The Powerfive Gearbox
Controls
Sections
Perspective Views
Gearbox Housing Sealant Application Diagram
Gearbox, Range Reduction And Reverse Shuttle And Reverse Shuttle Troubleshooting
Super Final Drive Troubleshooting
Gearbox Removal-Refitting
Gearbox Housing - Overhaul
Gear Lever Support Housing
- Rear Axle And Side Final Drives
Main Specifications Of The Standard Bevel Gear Pair And Differential
Main Specifications Of Standard Side Final Drives
Main Specifications Of Gt Bevel Gear Pair And Differential
Main Specifications Of Gt Side Final Drives
Bevel Gear Pair And Differential Troubleshooting
Side Final Drives Troubleshooting
Controls
Perspective Views
Differential Housing Sealant Application Diagram
Standard Side Final Drive Housing Sealant Application Diagram
Gt Side Final Drive Housing Sealant Application Diagram
Rear Differential Housing Removal-Refitting
Rear Differential Housing - Overhaul
Standard Side Final Drive - Overhaul
Gs Side Final Drive
- Front Axle
Main Specifications Of Front Axle
Controls
Sections
Differential Assembly - Overhaul
- Power Take-Off
Main Specifications Of Rear Power Take-Off
Controls
Sections
Power Take-Off Cover Sealant Application Diagram
Power Take-Off
- Hydraulic Circuits - Rear Power Lift
Main Technical Specifications Of Hydraulic Systems
Hydraulic Circuit General Description
Low Flow Rate Circuit Description
High Delivery Circuit Description «
Steering Circuit Description
Hydraulic Pump Description And Operation
Hydraulic Unit With Three Solenoid Valves
Hydraulic Unit With Four Solenoid Valves
Hydraulic Unit With Four Solenoid Valves For Fast Run
Hydraulic Unit With Five Solenoid Valves
Differential Lock Feeding Circuit Description (Front/Rear)
Pto And Pto Brake Feeding Circuit Description
Hi-Lo Hydraulic Feeding Circuit Description
Spring-On Feeding Circuit Description
Trailer Brake Valve
Trailer Brake Valve (Italian Version)
Trailer Brake Valve (Export Version)
Supplementary Distributor Description And Operation
Hydraulic-Mechanical Power Lift
Hydraulic-Mechanical Power Lift Overhaul
Hydraulic Distributor - Overhaul
- Steering System
Main Specifications Of The Hydrostatic Steering
Sections And Prospective Views
Orbitrol - Overhaul
- Brakes
Main Specifications Of Brakes
Controls
Sections
Adjustments
- Electrical System - Instruments
Instruments
Transmitters, Sensors And Solenoid Valves
Maintenance
- Electrical System - Components
Control Panel With Analogue/Digital Instrument
Hazard Light Switch
Rotating Light Switch
Ignition Switch
Light Stalk
Working Light Switch (Version Without Cab)
Right Side Commands (Version Without Electronic Power Lift)
Right Side Commands (Version With Electronic Power Lift)
Controls On The Right Cab Pillar
Cab Components
Iso/Nao Rear Lights
Maintenance
Bulb Specifications Overview
- Electrical System - Ignition System
Tests
Starter Motor. Removal - Refitting
- Electrical System - Recharging System
Tests And Troubleshooting
Alternator. Removal - Refitting
- Electrical System - Battery
Battery Removal - Refitting
Maintenance And Battery Inspection
Common Causes Of Battery Faults
- 1050
Electrical System - Electrical Circuits
- 1100
Cab And A/C System
