Landini Tractor 7 Series Robo-Six SWB (RPD8) Service Manual 6720650A2 2022
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini 7 Series Robo-Six SWB Tractor
7-170 ROBO-SIX ; 7-180 ROBO-SIX
Engine: FPT NEF 67 Engine
Part Number: 6720650A2
Publication Date: 2022
Number of Pages: 4650 Pages
Introduction
Liability
Purpose of the manual
Copyright
Table of Contents
1001 - Safety
Introduction
Technical notes
Maintain the tractor in a safe way
Danger signs
Tightening torques
2 - Engine
Technical specifications
Annexes
2002 - Exhaust gases treatment system
Safety
ATS system
AdBlue®
2003 - Engine removal
Safety
3005 - Tank
Safety
Procedures
4001 - Electric system
Safety
Fuses and relays
Operator's interface overview
Sockets overview
Lights overview
Component sheets
Wiring harnesses locations
Wiring diagrams
Complete list of connections
4002 - Instrument cluster set-up and calibrations
Calibration from the instrument cluster
Calibrations with the diagnostic tool
5 - Steering system - Operation
Power steering system
Description of the hydraulic system
5001 - Steering column and power steering system
Sections and perspective views
Safety
6 - Transmission - Operation
Annexes
6021 - Front axle
Safety
Front axle
Annexes
6025 - Front hitch and PTO
Safety
Front hitch maintenance
Front PTO maintenance
7 - Brakes - Operation
Brake circuit
Hydraulic trailer brake
Trailer brake system, EEC type
Trailer brake system of the ITALY “Cuna” type
Trailer brake system EU type 2015/68
Brake bleed nipples
On-off valve
Trailer air brakes
ISO and functional diagrams - air braking system
System components
Troubleshooting
Diagnostic tests of the air system
7003 - Adjustments and inspections
Safety
Brakes
“Pick-Up Hitch”
8 - Hydraulic circuit - Operation
Hydraulic circuit
Hydraulic pumps
PowerShift clutches management control unit
Ranges management control unit
Cut-off valve
Dynamic priority valve
Signal line manifold
Cooling system by-pass valve
Hydraulic trailer braking
Rear auxiliary control valves
Suspended axle
Front hitch
Midmount control valve
Rear hydraulic unions
Transmission breather and oil filling
8001 - Troubleshooting of the hydraulic system
Troubleshooting
Hydraulic system diagnostic testing
8003 - Piston pump
Safety
Procedure for piston pump
9 - Cab
A/C system
Compressor
Condenser
Evaporator
Air conditioning pressure switch
Mixed air temperature sensor With automatic A/C only
Cab external temperature sensor With automatic A/C only
Cab inner temperature sensor With automatic A/C only
Sun radiation sensor With automatic A/C only
Automatic A/C control panel
Manual A/C control panel
9002 - Cab removal
Safety
9004 - A/C system
Safety
Electrical system maintenance
Pressure tests
Troubleshooting
9005 - Operator seat
Safety
Description
Annexes
10000 - Control units alarms diagnostics
CAN Bus system
Error handling via CAN
Instrument cluster control unit EC1
Engine control unit EC6
Hitch and lights management control unit EC9
Suspended axle control unit EC10
Armrest control unit EC15
Midmount valves control unit EC16
Air conditioning control unit EC17
GPS antenna EC27
Electronic power steering control unit EC28
Satellite autoguide monitor X25 EC31
Trailer braking control unit EC35
Transmission control unit EC40
Suspended cab and ISOBUS control unit EC43
Brand: Landini
Introduction
Liability
Copyright
Table of Contents
1001 - Safety
Introduction
Technical notes
Danger signs
Tightening torques
2 - Engine
Annexes
Safety
ATS system
AdBlue®
Safety
3005 - Tank
Safety
Procedures
Safety
Fuses and relays
Sockets overview
Lights overview
Component sheets
Wiring diagrams
Safety
Annexes
6021 - Front axle
Safety
Front axle
Annexes
Safety
Brake circuit
Brake bleed nipples
On-off valve
Trailer air brakes
System components
Troubleshooting
Safety
Brakes
“Pick-Up Hitch”
Hydraulic circuit
Hydraulic pumps
Cut-off valve
Suspended axle
Front hitch
Troubleshooting
8003 - Piston pump
Safety
9 - Cab
A/C system
Compressor
Condenser
Evaporator
9002 - Cab removal
Safety
9004 - A/C system
Safety
Pressure tests
Troubleshooting
Safety
Description
Annexes
CAN Bus system
GPS antenna EC27
- Landini Tractor 105,115,130,145,165 Service Manual
- Landini 8860 Parts Catalog
- Landini 9880 Parts Catalog
- Landini 8500 Accessories And Application Miscellaneous Parts Catalog
- Landini 105,115,130,145,165 Service Manual
- Landini 7860 Parts Catalog
- Landini 14500 Accessories And Application Miscellaneous Parts Catalog
- Landini 6500 Accessories And Application Miscellaneous Parts Catalog
- Landini Power_Farm_95 Parts Catalog
- Landini 6880 Parts Catalog
- Landini Mistral_55 Parts Catalog
- Landini 105 115 130 145 165 Service Manual
- Landini 8830 Accessories And Application Miscellaneous Parts Catalog
- Landini 7880 Parts Catalog
- Landini Tractor Legend 105 - 165 Training Manual and Wiring Diagram
