Landini Tractor 7 Series 7-210 7-230 7-240 V-Shift (RPE7) Service Manual 6735461A1 2023
118
7,392
Brand: Landini
Type of Manual: Service Manual, Hydraulic And Electrical Schematic
Model: Landini 7 Series V-Shift Tractor
7-210 V-Shift ; 7-230 V-Shift ; 7-240 V-Shift
Engine: FPT NEF 67 Engine
Part Number: 6735461A1
Publication Date: 2023
Number of Pages: 4774 Pages
Introduction
Liability
Purpose of the manual
Copyright
Table of Contents
1001 - Safety
Introduction
Technical notes
Maintain the tractor in a safe way
Danger signs
Tightening torques
2000 - Engine
Technical specifications
Annexes
2002 - Exhaust gas post-treatment system
Safety
ATS system
AdBlue®
2003 - Engine removal
Safety
3500 - Tank
Safety
Procedures
4001 - Electric system
Safety
Fuses and relays
Operator's interface overview
Sockets overview
Lights overview
Component sheets
Wiring harnesses locations
Wiring diagrams
4002 - Instrument cluster set-up and calibrations
Calibration from the instrument cluster
Calibrations with the diagnostic tool
5000 - Steering system - Operation
Power steering system
Description of the hydraulic system
5001 - Steering column and power steering system
Sections and perspective views
Safety
6000 - Transmission
Hydrostatic unit
Mechanic unit
Annexes
6001 - Engine - transmission coupling
Torsional coupling
6021 - Front axle
Annexes
6025 - Front hitch and PTO
Safety
Front hitch maintenance
Front PTO maintenance
7000 - Brakes and “EAZY GRIP” Operation
Brake circuit
Hydraulic trailer brake
Trailer brake system, EEC type
Trailer brake system of the ITALY “Cuna” type
TRAILER BRAKE SYSTEM, (EU) 2015/68 TYPE
Brake bleed nipples
Distributor valve
Trailer air brakes
ISO and functional diagrams - air braking system
System components
“Eazy grip” centralised wheel inflation system
System components
7003 - Adjustments and inspections
Safety
Brakes
Diagnostic tests of the air brake system
“Pick-Up Hitch”
8000 - Hydraulic components Operation
Hydraulic circuit
Hydraulic pumps
Pressure control unit
Clutches solenoid valves unit
Hydrostatic unit
Cut-off valve
“Smart Power Zero” hydraulic unit
Dynamic priority valve
Hydraulic manifolds
Hydraulic trailer braking
Rear control valves
Suspended Cab
Suspended axle
Front hitch
Midmount control valve
“POWER BEYOND”
Transmission breather and oil filling
8001 - Troubleshooting of the hydraulic system
Fault diagnostics
Fault diagnostics
9000 - Cab
Air conditioning system
Compressor
Condenser
Tank/Dryer
Evaporator
Thermostatic expansion valve
Evaporator temperature sensor
Air conditioning pressure switch
Mixed air temperature sensor
Cab external temperature sensor
Cab inner temperature sensor
Sun radiation sensor
Air conditioning control panel
9001 - Adjustment/Regulation
Safety
Adjustments
Adjustments
9002 - Cab removal
Safety
CAB
9004 - Air conditioning system
Safety
Electrical system maintenance
Pressure tests
Diagnostics and troubleshooting
9005 - Operator seat
Safety
Description
Annexes
10000 - Control units alarms diagnostics
CAN Bus system
Error handling via CAN
Instrument cluster control unit EC1
Engine control unit EC6
Hitch and lights management control unit EC9
Suspended axle control unit EC10
Armrest control unit EC15
Midmount valves control unit EC16
Air conditioning control unit EC17
Vehicle VDC control unit EC23
GPS antenna EC27
Electronic power steering control unit EC28
Satellite autoguide monitor X25 EC31
Trailer braking control unit EC35
Transmission control unit EC40
Telematics control unit EC41
Suspended cab and ISOBUS control unit EC43
“EazyGrip” control unit EC801
