Landini Tractor 6-135 6-145 6-155 ROBO-SIX Service Manual 6723716A1 EN
- Download this document, you need 10000 Gallons
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini 6 Robo-Six Series Tractor
6-135 ROBO-SIX, 6-145 ROBO-SIX, 6-155 ROBO-SIX
Part Number: 6723716A1
Publication Date: 2023
Number of Pages: 3662 Pages
- Serie 6 Robo-Six
Introduction
Liability
Purpose Of The Manual
Copyright
Table Of Contents
- 1001 - Safety
Introduction
Technical Notes
Maintain The Tractor In A Safe Way
Danger Signs
Tightening Torques
- 1500 - Specific Equipment Catalogue
Specific Equipment
- 2000 - Engine
Technical Specifications
Annexes
- 2002 - Exhaust Gas Treatment System
Safety
Ats System
Adblue®
Ats Management
- 3500 - Tank
Fuel Tank Components
Adblue® Tank Components
- 4001 - Electric System
Safety
Fuses And Relays
Operator's Interface Overview
Sockets Overview
Lights Overview
Component Sheets
Wiring Harnesses Locations
Wiring Diagrams
- 4002 - Instrument Cluster Set-Up And Calibrations
Calibration From The Instrument Cluster
Suspended Axle Calibration
Calibrations With The Diagnostic Tool
- 5000 - Steering System - Operation
Power Steering System
Description Of The Hydraulic System
- 6000 - Transmission - Operation
“Powershift” Unit
Shuttle Assembly
Gearbox
Four-Wheel Drive
Bevel Gear Pair And Differential
Rear Final Drives
Rear Pto
- 7000 - Brakes - Operation
Brake Circuit
Hydraulic Trailer Brake
Distribution Valve
Trailer Air Brakes
- 7003 - Adjustments And Inspections
Safety
Brakes
Diagnostic Tests Of The Air System
“Pick-Up Hitch”
- 8000 - Hydraulic Circuit - Operation
Hydraulic Circuit
Hydraulic Pumps
Hydraulic Power Packs
Priority Valve
Hydraulic Trailer Braking
Rear Control Valves
Suspended Axle
Front Hitch
Midmount Control Valve
Rear Hydraulic Unions
Transmission Breather And Oil Filling
- 8001 - Troubleshooting - Hydraulic Circuit
Safety
Troubleshooting
Hydraulic System Diagnostic Testing
- 9000 - Cab
Air Conditioning System
Compressor
Condenser
Evaporator
Air Conditioning Pressure Switch
Mixed Air Temperature Sensor With Automatic A/C Only
Cab External Temperature Sensor With Automatic A/C Only
Cab Inner Temperature Sensor With Automatic A/C Only
Sun Radiation Sensor With Automatic A/C Only
Automatic A/C Control Panel
Manual A/C Control Panel
- 9004 - Air Conditioning System
Safety
Electrical System Maintenance
Pressure Tests
Troubleshooting
- 9005 - Operator Seat
Safety
Description
Annexes
- 10000 - Control Units Alarms Diagnostics
Can Bus System
Error Handling Via Can
Instrument Cluster Control Unit Ec1
Transmission Control Unit Ec4
Engine Control Unit Ec6
Hitch And Lights Management Control Unit Ec9
Suspended Axle Control Unit Ec10
Armrest Control Unit Ec15
Midmount Valves Control Unit Ec16
Air Conditioning Control Unit Ec17
Tecu Isobus Controller Ec24
Gps Antenna Ec27
Electronic Power Steering Control Unit Ec28
Satellite Autoguide Monitor X25 Ec31
Trailer Braking Control Unit Ec35
- 11000 - Disassembly Procedures
Safety
Preliminary Operations
Tanks And Reservoirs
Steering Column
Hitch And Front Pto
Front Axle
“Powershift” Unit
Shuttle Assembly
Range Assembly
Rear Hitch
Rear Power Take-Off
Creeper Unit (If Fitted)
4wd Unit
Rear Final Drives
- Annexes
Engine Manual
Front Axle Manual
Operator's Seat Manual
Brand: Landini
- Serie 6 Robo-Six
Introduction
Liability
Copyright
Table Of Contents
- 1001 - Safety
Introduction
Technical Notes
Danger Signs
Tightening Torques
Specific Equipment
- 2000 - Engine
Annexes
Safety
Ats System
Adblue®
Ats Management
- 3500 - Tank
Safety
Fuses And Relays
Sockets Overview
Lights Overview
Component Sheets
Wiring Diagrams
“Powershift” Unit
Shuttle Assembly
Gearbox
Four-Wheel Drive
Rear Final Drives
Rear Pto
Brake Circuit
Distribution Valve
Trailer Air Brakes
Safety
Brakes
“Pick-Up Hitch”
Hydraulic Circuit
Hydraulic Pumps
Priority Valve
Rear Control Valves
Suspended Axle
Front Hitch
Safety
Troubleshooting
- 9000 - Cab
Compressor
Condenser
Evaporator
Safety
Pressure Tests
Troubleshooting
Safety
Description
Annexes
Can Bus System
Gps Antenna Ec27
Safety
Steering Column
Hitch And Front Pto
Front Axle
“Powershift” Unit
Shuttle Assembly
Range Assembly
Rear Hitch
Rear Power Take-Off
4wd Unit
Rear Final Drives
- Annexes
Engine Manual
Front Axle Manual
- Landini Tractor 105,115,130,145,165 Service Manual
- Landini 8860 Parts Catalog
- Landini 9880 Parts Catalog
- Landini 8500 Accessories And Application Miscellaneous Parts Catalog
- Landini 105,115,130,145,165 Service Manual
- Landini 7860 Parts Catalog
- Landini 14500 Accessories And Application Miscellaneous Parts Catalog
- Landini 6500 Accessories And Application Miscellaneous Parts Catalog
- Landini Power_Farm_95 Parts Catalog
- Landini 6880 Parts Catalog
- Landini Mistral_55 Parts Catalog
- Landini 105 115 130 145 165 Service Manual
- Landini 8830 Accessories And Application Miscellaneous Parts Catalog
- Landini 7880 Parts Catalog
- Landini Tractor Legend 105 - 165 Training Manual and Wiring Diagram
