Landini Tractor 5-100 5-110 5-120 5-100HC 5-110HC (RS2B) Operators Manual 6691953A6 2024
118
6,911
Brand: Landini
Model: Landini Series 5 Stage V Active / Dynamic Tractor
5-100 ; 5-110 ; 5-120 ; 5-100HC ; 5-110HC
Engine: FPT F36 Engine
Part Number: 6691953A6
Publication Date: 2024
Number of Pages: 482 Pages
Section 1 Contents
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty Service
Safety
Section 2 Safety Notes
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Warning And Caution
Safety - Decals
Safety - Following A Safety Program
Safety - Cab
Safety Frame
Safety Precautions
Personal Protection Equipment (Ppe)
Check Your Equipment
Cleaning The Tractor
Save The Environment
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor.
Working In Safety
Beware Of Other People
Risk Of Overturning
To Avoid Side Overturning
To Avoid Back Overturning
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Highway Code Regulations
Safety - After Use
Further Notes
Tractor Stability
Tractor's Lifting Points
Tractor Access
Fuel Tank Filling
Wedges
Risks From Noise
Prevention Against Burns
Hazardous Substances
Positions Of The Safety Decals
Section 3 Controls
General Layout Of Controls
Main Controls
Main Controls And Monitoring Instruments (Set-Up With Robotic Transmission)
Joystick Controls
Controls On The Left Side Of The Driver's Seat
Controls On The Left Side Of The Control Turret
Led And Backlighting Functions On Switches
Drive Direction Reversing Lever
Set-Up With Mechanical Reverse Shuttle
Set-Up With Hydraulic Reverse Shuttle
Tractor Warning Lamps Operation
Implement Warning Lamps (If Equipped)
Rotating Beacon
Slow Moving Vehicle (Smv) Symbol
Right Controls On Instrument Turret
Adjustment Of Electro-Hydraulic Reverse Shuttle Effectiveness
Battery Master Disconnect Switch
Steering Column Adjustment
Auxiliary Power Socket (12 V)
Miscellaneous
External Controls
Service Usb Connection
Cigarette Lighter Socket
Operator's Seat
Seat Belt
Instructor Seat
Operator Present Sensor
Central Controls On Control Turret
Rear Window Wiper
Cab Roof Components
Cab Ventilation
Front Windscreen Demisting/Defrosting
Controls For Cab Temperature
Set-Up With Cab Air Conditioning
Use Of The Air Conditioning System
Radio
Additional Cab Features
Section 4 Instruments And Programming
Instruments - Instrument Panel
Display Operation
Alarm Management Priority Display
Main Display
Clock/Work Timer
Rear Electronic Hitch
Engagement/Disengagement Threshold Of Auto Pto
Setup Of Limits For Auto Pto Engagement/Disengagement.
Service Interval
Alarm From Operator Present Sensor On Seat
Air Brakes Pressure
Adblue™ Or Def Level
Counters
Calibrations
Engine Controller Menu
Dpf Filter Regeneration
Adjustment Of Screen, Lamps And Indicators Brightness
Constant Engine Rpm Rate
Selection Of Rear Pto Engagement Curve
Selection Of Front Pto Engagement Curve
Aps
Alarms
Transmission Display Area
Accessories Menu
Implement Width
Clock
Service Interval
Functionality (Indicator Lights/Indicators/Display On Lcd)
Selected Pto Speed Rate
Management Of Operator Present Control
Telematics (Fleet Menu)
Section 5 Operation
General Operation
Run In Procedure
Starting Procedure
Tractor Start-Up
Stopping The Tractor
Engine Stopping
Running In
Cold Temperature Operation
Cold Weather Starting (Temperatures Below 0°C)
Parking The Tractor
Transmission - Configurations
Speed Tables
Gearshift Clutch
Reverse Shuttle Control Lever
Setup With Mechanical Reverse Shuttle
Setup With Hydraulic Reverse Shuttle
Gearshift Lever
Operation Of Power Shuttle Gearbox
Starting The Tractor With The Clutch Pedal
Changing Gear With The Declutch Button
Changing Gear With The Clutch Pedal
Use Of The Hi-Lo Function
Use Of Reverse Shuttle Under Load
Use Of Reverse Shuttle With Clutch Pedal
Robotic Transmission - Operating Instructions
Auto Powershift Road (Aps Road)
Semi Auto
Power Take-Off
Rear Power Take-Off Engagement
Synchronised Power Take-Off (If Equipped)
Rear Auto Pto
Front Power Take-Off
Front Hitch
Brakes
Hydraulic Trailer Brake
Control Position For Parking Brake
Stationary
Differential Lock
Two-Wheel Drive
Operating The Four-Wheel Drive
Engine Set Point
Tractor Transport
Rops Frame
Tow Equipment - Front Pull Hook
Drawbar
Pick Up Hitch
Height Adjustable Hitch.
Rear Tow Hitch And Drawbar - Categories
Rear Tow Hook - Adjustments
Towable Weights
Rear Hitch (Mechanical Control)
Sensitivity Adjustment
Down Speed Control
Top Link Of The Mechanical Hitch
External Control For Hitch (If Equipped)
Rear Hitch (Electronic Control)
Electronically Controlled Hitch - Activation
Hitching An Implement
Use During Work
Control Panel
Use Of The Hitch Control Selector
Hitch Activation
Hitch Lock
Hitch Movement
Fast Lowering
Hitch Handling As With The External Controls
Swing Damping Function
Down Speed Control
Maximum Height Setting
Intermix Knob
Floating Mode.
External Hitch Controls
Auxiliary Control Valves
Use Of The Auxiliary Control Valves
Free Discharge
Quick Couplers
Connecting Rear Hoses
Free Rear Discharge
Auxiliary Control Valve With Electro-Hydraulic Divider
Rear Three-Point Hitch
Section 6 Tyres - Wheels - Ballasting
Tyre Inflation Specifications
Tyre Pressures, Load Capacities And Service
Tyre Inflation Procedure
Tyre And Wheel Service
Tyre Installation
Wheel Removing Procedure
Setting The Front Wheel Toe-In
Front Axle - Steering Stops
Track Adjustment
Front And Rear Wheels Bolt Torques
Front Fenders
Tractor Ballast
Section 7 Maintenance
Routine Maintenance Table
Recommendations Before You Service
Running In
Servicing Intervals
Fuel Tank Filling
Bleeding Air From The Fuel System
Adblue® (Urea Solution Aus 32)
Exhaust Gas Post-Treatment System
Access For Inspection And Maintenance
Variable Maintenance (Every 10 Hours Or Daily)
Preparing For Long Idle Periods
Fire Prevention
Section 8 Electric System
Fuses And Relays
7-Pin Power Socket For Trailer
Ebs Power Socket For Trailer Diagnosis (Iso 7638-2)
Iso Socket (Compliant With Standard Iso 11786)
Diagnostic Connector
Section 9 Specifications - Alphabetical Index
Weights And Dimensions
Electric System
Radio Specifications
Clutch
Rear Axle
4wd Front Axle
Differential Lock
Power Take-Off
Brakes
4wd Front Axle
Power Steering System
Hydraulic Circuit
Hitch
Three-Point Linkage
Safety Frame
Bonnet
Electric System
Optional Extras
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Implement Attachment Points
Alphabetical Index
Regulation (Eu) N. 167/2013 At Last Amending 2019/519
