Martin Welker
104
230,792
Landini Tractor 4-060 to 4-105 Service Manual 6526589M3 EN
Download this document, you need 6000 Gallons
Brand: Landini
Type of Manual: Service Manual, Hydraulic and Electrical Diagrams
Model: Landini 4 Series Tractor
4-060 4-070 4-075 4-080 4-090 4-100 4-105
Part Number: 6526589M3
Publication Date: 2021
Number of Pages: 2020 Pages
- Cover Page
- Introduction
- Liability
- Purpose Of The Manual
- Copyright
- Table Of Contents
- 1001 - Safety
General Instructions
Symbols
Danger Signs
- 2 - Engine
Technical Specifications
- 3005 - Fuel Tank
Safety
Procedures
- 4001 - Descriptions - Wiring Diagrams - Connectors
Safety
Symbols And Names
Fuses And Relays (Deutz Engines)
Fuses And Relays (Perkins Engine)
Controls
Sockets
Light Units
Description And Diagrams
Complete List Of Connections
- 4002 - Instrument Cluster Setup
General Instrument Cluster Specifications
- 5 - Steering System Operation
- 5001 - Steering Column And Power Steering System
Safety
Procedures
- 5002 - Power Steering System
Procedures
- 6 - Transmission Operation
Transmission With Mechanical Reverse Shuttle
Transmission With Hydraulic Reverse Shuttle
Gearbox
Speed Ranges
Four-Wheel Drive
Bevel Gear Pair And Differential
Side Final Drives
Rear Power Take-Off
Front Axle
- 6001 - Transmission-Engine Coupling
Sections And Perspective Views
Safety
Procedures
- 6002 - Engine Gearbox Assembly (Version With Hydraulic Reverse Shuttle)
Safety
Procedures
- 6002 - Engine Gearbox Assembly (Version With Mechanical Reverse Shuttle)
Safety
Procedures
- 6006 - Synchronised Gearbox And Ranges
Safety
Procedures
- 6012 - Rear Differential
Safety
Procedures
- 6018 - Side Final Drives
Safety
Procedures
- 6019 - Rear Power Take-Off
Safety
Procedures
- 6021 - Front Axle
Safety
Procedures
- 7 - Brakes Operation
Braking Circuit
Brake Pumps
4wd During Braking
Trailer Brake System
Pneumatic Trailer Brakes
Troubleshooting
Diagnostic Tests Of The Air System
- 7003 - Brakes Overhaul And Adjustments
Safety
Procedures
- 8 - Hydraulic Components Operation
Hydraulic Circuit
Pumps
Solenoid Valves Controller For Users Control
Reverse Shuttle Solenoid Valves Pack (Only For Version With Hydraulic Reverse Shuttle)
Hydraulic Power Pack For Pto Control (Version For Mechanical Reverse Shuttle)
Solenoid Valves Pack For Pto Control (Version With Hydraulic Reverse Shuttle)
Hydraulic Hitch With Mechanical Control
Electronically Controlled Hydraulic Hitch
Auxiliary Control Valves
Electro-Hydraulic Flow Selector
Front Monobloc Valve
- 8001 - Hydraulic Components Inspections And Adjustments
Procedures
Troubleshooting
Operating Pressure Tests
- 8005 - Hitch And Front Pto
Safety
Procedures
- 8007 - Rear Hitch
Safety
Procedures
- 10 - Can Line Controllers Operation
Introduction
Safety
Check-Control And Troubleshooting
Descriptions And Diagrams
- 10002 - Hitch Controller Calibration, Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Safety
General Information About The Rear Hitch Controller
Rear Hitch Calibration
Error Codes - Electrical Diagnosis
Error Codes - Settings And Programming
- 10005 - Engine Controller Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Safety
General Information About The Engine Controller
Troubleshooting With A Diagnostic Code
- 10006 - Transmission Controller Calibration, Error Codes,Troubleshooting, Descriptions, Wiring Diagrams
Safety
General Information On Electronic Transmission Control
Pedal Calibration
Transmission Calibration
Transmission Calibration Errors
- 10008 - A/C Controller Descriptions And Wiring Diagrams
General Information About The A/C Controller
Calibration Of Heating Valve Motor
- 10009 - Instrument Cluster Controller Error Codes, Troubleshooting, Descriptions, Wiring Diagrams
Safety
General Information About The Instrument Cluster Controller
- 10010 - Controller Programming Diag4 Argo Tractors
Description
