Martin Welker
104
230,792
Landini Tractor 4-060 4-070 4-080 Operators Maintenance Manual 6670715A4
Brand: Landini
Type of Manual: Operators Maintenance Manual
Model: Landini 4-060 4-070 4-080 Tractor
Part Number: 6670715A4
Publication Date: 2023
Number of Pages: 362 Pages
Tractor Identification
Introduction
Warranty, Pre-Delivery Inspections And Installation
Warranty Claim
Spare Parts Warning
If You Move
Post-Warranty
Service
Safety
Safety Notes
Alarm And Safety Texts And Symbols
Safety - Tractor And Implement
Safety - Introduction
Safety - Advice For The Operator
Safety - Danger, Warning And Caution
Safety - Decals
Safety - Following A Safety Program
Safety
Safety — Cab
Safety Precautions
Personal Protection Equipment (Ppe)
Cleaning The Tractor
Save The Environ No En T
Safety - Tractor Maintenance
Safety - Starting Up
Working In Safety
Follow The Rules When Using Your Tractor
Working In Safety
Beware Of Other People
Risk Of Overturning
To Avoid Side Overturning
To Avoid Back Overturning
Dangerous Operations
To Engage The Power Take-Off
Implements And Attachments
Road Transport
Highway Code Regulations
Safety - After Use
Further Notes
Tractor Stability
Tractors Lifting Points
Tractor Access
Fuel Tank Filling
Wed G E S
Risks From Noise
Positions Of The Safety Decals
Positions Of Safety Decals - Only North American Markets
Controls - Cab
General Layout Of Controls
Controls On The Left Side Of The Driverls
Controls On The Left Side Of The Control Turret
Commutators
Led And Backlighting Functions On Switches
Drive Direction Reversing Lever (Setup With Mechanical
Reverse
Shuttle)
Reverse Shuttle Lever (Set-Up With Hydraulic
Tractor Warning Lamp Usage
Implement Warning Lamps (If Equipped)
Rotating Beacon
Slow Moving Vehicle (Smv) Symbol
Front Right Controls On Instrument Turret
Shuttle)
Of Reverse
Battery Master Disconnect Switch
Shuttle
Use Of Of Effectiveness
Steering Column Adjustment
Auxiliary Power Socket
Miscellaneous
Operator's Seat
Seat Belt
Instructor Seat
(12 V)
Operator Present
Sensor
Central Controls On Control Turret
Rear Window Wiper
Cab Roof Components
Cab Ventilation
Controls For Cab Temperature
Setup With Heating Only
Setup With Cab Air Conditioning
Use Of The Air Conditioning System
Radio
Cab Features
Additional
Instruments And Programming
Instruments - Instrument Panel
Display Operation
Alarm Management Priority Display
Main Display
Clock/Work Timer
Service Interval
Air Brakes Pressure
Counters
Engine Controller Menu
Dp F Filter Regeneration
Adjustment Of Screen, Lamps And Indicators Brightness
Constant Engine Rpm Rate
Alarms
Transmission Display Area
Power Take-Off Menu
Accessories Menu
Implement Width
Euro/Nao Market
Clock
Service Interval
Remote Diagnostics
Functionality (Indicator Lights/Indicators/Display On Lcd)
Selected Speed Rate
Management Of Operator Present Control
Operation
General Operation
Run In Procedure
Starting Procedure
Tractor Start-Up
Stopping The Tractor
Engine Stopping
Cold Temperature Operation
Parking The Tractor
Transmission - Configurations
Speed Tables
Gearshift Clutch
Reverse Shuttle Control
Gearshift Lever
Rear Power Take-Off
Synchronized Power Take-Off (If Equipped)
External Pto Controls
The Pto
Precautions When Using
B Kes
Hydraulic Trailer Brake
Control Position For Parking Brake
Stationary
Use Of The Differential Lock
Operating The Drive
Engine Set Point
Tractor Transport
Rops Frame
Tow Equipment - Front Pull Hook
Drawbar
Height Adjustable Hitch
Rear Tow Hook - Adjustments
Towable Weights
Rear Hitch (Mechanical Control)
Ergonomic Lift System
Sensitivity Adjustment
Down Speed Control
Top Link Of The Mechanical Hitch
External Contro For Hitch (If Equipped)
Auxiliary Control
Ives
Quick Couplers
Connecting Rear Hoses
Disconnecting Hoses And Implements
Free Rear Discharge
Rear Hitch
Tyres - Wheels - Ballasting
Tyre Inflation Specifications
Tyre Pressures, Load Capacities And
Tyre Inflation Procedure
Tyre And Service
Tyre Installation
Wheel Removing Procedure
Setting The Front Wheel Toe-In
Front Axle - Steering Stops
Track Adjustment
Front Rear
Bolt Torques
Front Fenders
Tractor Ballast
Maintenance
Routine Maintenance
Table
Recommendations Before You
Lubrication And Maintenance
Running In
Servicing Intervals
Miscellaneous Checks
Lubrication/Greasing
General Tractor Inspection
Lubricants And Fuels
Engine Oil Specifications
Approved Fuels
Service
Protective Agent For The Cooling System
Fuel Tank Filling
Access For Inspection And Maintenance
Variable Maintenance (Every 10 Hours Or Daily)
Cab Filter - Variable Maintenance
General
Preparing For Long
Fire
Idle
Periods
Electric System
Battery
Battery System Servicing
Beams
Bulb Replacement
Fuses And Relays
7-Pin Power Socket For Trailer
Ebs Power Socket For Trailer Diagnosis
Diagnostic Connector
(Iso 7638)
Specifications - Alphabetical Index
Weights And Dimensions
Radio Specifications
Clutch
Rear Axle
4wd Front Axle
Differential Lock
Power Take-Off
B Ra Kes
4wd Front Axle
Power Steering System
Hydraulic Circuit
Hitch
Three-Point Linkage
Bonnet
Fuses
Optional Extras
Noise Levels
Vibration Levels
Issue Of Authorization
Weights
Lubricants And Fuels Chart
Implement Attachment Points
Alphabetical Index
Regulation (Eu) N 167/2013 At Last Amending 2019/519
